ESP8266, Neo 6m with blynk
I’m trying to create gps project using esp8266 and neo 6m with blynk, when I upload the code the neo 6m start blinking but in the serial monitor it’s written ( no gps detected: check wiring). But the connection is right and code.
CODE & DIAGRAM
IMG_5126
#include <SoftwareSerial.h>
#define BLYNK_PRINT Serial
//Install the following Libraries
#include <TinyGPS++.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
//GPS RX to D1 & GPS TX to D2 and Serial Connection
const int RXPin = 4, TXPin = 5;
const uint32_t GPSBaud = 9600;
SoftwareSerial gps_module(RXPin, TXPin);
TinyGPSPlus gps;
WidgetMap myMap(V0); //V0 - virtual pin for Map
BlynkTimer timer;
//Variable  to store the speed, no. of satellites, direction
float gps_speed;
float no_of_satellites;
String satellite_orientation;
#define BLYNK_TEMPLATE_ID "************"
#define BLYNK_TEMPLATE_NAME "************"
#define BLYNK_AUTH_TOKEN "******************"
char auth[] = "******************";
char ssid[] = "****************";
char pass[] = "****************";
//unsigned int move_index;
unsigned int move_index = 1;
  gps_module.begin(GPSBaud);
  Blynk.begin(auth, ssid, pass);
  timer.setInterval(5000L, checkGPS);
void checkGPS(){
  if (gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
      Blynk.virtualWrite(V4, "GPS ERROR");
  while (gps_module.available() > 0)
    //displays information every time a new sentence is correctly encoded.
    if (gps.encode(gps_module.read()))
    displayInfo();
  Blynk.run();
  timer.run();
void displayInfo()
  if (gps.location.isValid())
    //Storing the Latitude. and Longitude
    float latitude = (gps.location.lat());
    float longitude = (gps.location.lng());
    //Send to Serial Monitor for Debugging
    Serial.print("LAT:  ");
    Serial.println(latitude, 6);  // float to x decimal places
    Serial.print("LONG: ");
    Serial.println(longitude, 6);
    Blynk.virtualWrite(V1, String(latitude, 6));
    Blynk.virtualWrite(V2, String(longitude, 6));
    myMap.location(move_index, latitude, longitude, "GPS_Location");
    //get speed
    gps_speed = gps.speed.kmph();
    Blynk.virtualWrite(V3, gps_speed);
    //get number of satellites
    no_of_satellites = gps.satellites.value();
    Blynk.virtualWrite(V4, no_of_satellites);
    // get the satellite orientation/direction
    satellite_orientation = TinyGPSPlus::cardinal(gps.course.value());
    Blynk.virtualWrite(V5, satellite_orientation);
