Hello all
I am building a NTP clock using NodeMCU with WS2812B. I have built the LED array and was testing it before I can get the NTP part included in the sketch. I have just used a count up to display on a 4 - 7 segment type LED strips. The code i guess is understandable even by beginners and novice ( like me as well).
Testing:
I had both the hour tenths and hour unit to work fine, but when i included the Minutes tens and minutes unit digit had a error as mentioned below. I guess its got some thing to do with the boot, and no clue about it. Look forward to your guidance and assistance. Thank you in advance. Keep well and Stay Safe. Regards
The Error message on my Serial Monitor:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
My Code:
#define FASTLED_ESP8266_RAW_PIN_ORDER
#include<ESP8266WiFi.h>
#include <FastLED.h>
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
#define PIN D5
#define NUM_LEDS 44
CRGB leds[NUM_LEDS];
int speedx = 10;
int brightness = 120;
int colors;
int blinkers; int colorval = 195; int briteval = 200;
int i; int j; int z; int l = 0; int ledcount = 0; int segled = 21; int numbers = 0;
int nos = 0; int hourt; int hrt; int hru;
FastLED.addLeds<WS2812, PIN, GRB>(leds, NUM_LEDS);
doClockDisplay();
if(nos>99){
nos=0;
void doClockDisplay() {
hrt = nos / 10; // hour tens digit
hru = nos % 10; // hour unit digit
for (z = 1; z <= 4; z += 1) {
if (z == 1) {
hourt = hrt;
ledcount = 0;
if (z == 2) {
hourt = hru;
ledcount = ledcount + 22;
Serial.print(nos);
Serial.print("-->");
Serial.print(hrt);
Serial.print(":");
Serial.println(hru);
switch (hourt) {
case 0:
// 0
for (int i = 0 + ledcount; i < 18 + ledcount; i += 1) {
leds[i] = CHSV( colorval, 255, briteval );
for (int i = 18 + ledcount; i < 21 + ledcount; i += 1) {
leds[i] = CHSV(0, 0, 0);
FastLED.show();
case 1:
// 1
for (int i = 3 + ledcount; i < 9 + ledcount; i += 1) {
leds[i] = CHSV( colorval, 255, briteval);
for (int i = 0 + ledcount; i < 3 + ledcount; i += 1) {
leds[i] = CHSV( 0, 0, 0);
for (int i = 9 + ledcount; i < 21 + ledcount; i += 1) {
FastLED.show();
case 2:
// 2
for (int i = 0 + ledcount; i < 6 + ledcount; i += 1) {
for (int i = 9 + ledcount; i < 15 + ledcount; i += 1) {
for (int i = 15 + ledcount; i < 18 + ledcount; i += 1) {
for (int i = 6 + ledcount; i < 9 + ledcount; i += 1) {
FastLED.show();
case 3:
// 3
for (int i = 0 + ledcount; i < 12 + ledcount; i += 1) {
for (int i = 12 + ledcount; i < 18 + ledcount; i += 1) {
FastLED.show();
case 4:
// 4
for (int i = 15 + ledcount; i < 21 + ledcount; i += 1) {
FastLED.show();
case 5:
// 5
for (int i = 6 + ledcount; i < 12 + ledcount; i += 1) {
for (int i = 3 + ledcount; i < 6 + ledcount; i += 1) {
for (int i = 12 + ledcount; i < 15 + ledcount; i += 1) {
FastLED.show();
case 6:
// 6
for (int i = 6 + ledcount; i < 21 + ledcount; i += 1) {
FastLED.show();
case 7:
// 7
for (int i = 0 + ledcount; i < 9 + ledcount; i += 1) {
FastLED.show();
case 8:
// 8
for (int i = 0 + ledcount; i < 21 + ledcount; i += 1) {
FastLED.show();
case 9:
// 9
FastLED.show();
nos=nos+1;
