esp8266 not work as access point
Hi all.
I try to make esp8266 connected on mega 2560 to works as AP , but received this
"AT+CWSAP?
SET NEW AP
AT+CWSAP="ESP_AP","123456789",6,4
ERROR
AT+RST
OK
öz‚€ÿ€@à ÈúDLJSÀ€Hè
[Vendor:www.ai-thinker.com Version:0.9.2.4]
ready
And AP not visible , tried with many devices to find it in networks.
If i use it like a web server connected to my router works well.
Anybody have some ideea?
Many thanks in advance
this is the code
  • Make an Access Point
#include <ESP8266_TCP.h>
// ESP8266 Class
ESP8266_TCP wifi;
// Define SSID, Password and Channel that provide for Access Point
#define ssid "ESP_AP"
#define pass "123456789"
#define channel 6
// Connect this pin to reset pin on ESP8266
#define PIN_RESET 6
delay(3000);
// We use Serial1 to interface with ESP8266
// and use Serial to debugging
Serial1.begin(9600);
wifi.begin(&Serial1, &Serial, PIN_RESET);
/* If your board has only 1 serial port
  • or you didn't need to debugging, try this.
  • Serial.begin(115200);
  • wifi.begin(&Serial, PIN_RESET);
// Check that ESP8266 is available
if(wifi.test())
wifi.openAccessPoint(ssid, pass, channel);
Serial.println("pornesc ap");
// ESP8266 isn't available
Serial.println("Check module connection and restart to try again...");
if you want to use access point, you must set CWMODE to 2 or 3 before you call CWSAP.
AT+CWMODE=2
