ESP8266 not working
Hello,
I am following this tutorial to try to connect my ESP8266 to the IoT
I connected the sensor as shown in this image
But my sensor is timing out even when I just turned it on. What could cause this?
What sensor?
Where is your code?
What do your debug prints tell you?
Sensor is ESP8266 (it's not a sensor but I don't know how to call it!)
My code is quite long, it's the one in the one in the MAIN_ESP8266 folder that you can download from the link (it's the same you can find under the video I linked; mine has a couple of changes, I'll post them here)
Into the main code, line 32:
const char SSID_ESP[] = "myWifiSSID";         //Give EXACT name of your WIFI
const char SSID_KEY[] = "myWifiPassword";             //Add the password of that WIFI connection
const char* host = "nicosdatabase.altervista.org";  //Add the host without "www" Example: electronoobs.com
String NOOBIX_id = "11111";
String NOOBIX_password = "22222";
String location_url = "/TX.php?id=";
In the connect file, line 7:
  ESP8266.print("AT+CIPSTART=0,\"TCP\",\"www.nicosdatabase.altervista.org\",80\r\n");//connect to your web server
My debugPrint says:
timeout 1
ESP CHECK FAILED
timeout 1
ESP RESET FAILED
(it’s not a sensor but I don’t know how to call it!)
Microcontroller with built-in radio.
Yep! That one!
Are you able to tell me what I did wrong? :stuck_out_tongue:
nicolopadovandev:
No. I can’t see your code.
Update: it doesn't seem to be the code
The blue light on the ESP8266 is constantly off: what does that mean?
