Could some one point me to the right solution?
Checking of the version works but the upload of the firmware goes wrong.
11:42:57.856 -> [HTTP-Client][begin] host: qnap port: 8080 url: /share.cgi?ssid=0wlZS01&fid=0wlZS01&filename=firmware.bin&openfolder=forcedownload&ep=
11:42:57.984 -> [String] 'x-ESP8266- ... 1753088
#include <OneWire.h>
#include <DallasTemperature.h>
#include <ArduinoOTA.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <ESP8266httpUpdate.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
const char* ssid = "";
const char* password = "";
const char* domoticzIp = "10.10.10.110";
const int domoticzPort = 8080;
const int ds18b20Pin = D2;
const int sleepDuration = 1e+7; // 1 minutes in microseconds
const char* fwImageURL = "http://qnap:8080/share.cgi?ssid=0wlZS01&fid=0wlZS01&filename=firmware.bin&openfolder=forcedownload&ep="; // update with your link to the new firmware bin file.
const char* fwVersionURL = "http://qnap:8080/share.cgi?ssid=0JdTb0b&fid=0JdTb0b&filename=firmware.version&openfolder=forcedownload&ep="; // update with your link to a text file with new version (just a single line with a number)
const float FW_VERSION = 1.06;
OneWire oneWire(ds18b20Pin);
DallasTemperature sensors(&oneWire);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print("Connecting to WiFi");
Serial.print(".");
Serial.println("\nConnected to WiFi");
// Initialize OTA
ArduinoOTA.setHostname("ESP8266-TEMP1"); // Set a unique hostname for OTA
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
sensors.begin();
// Handle OTA updates
ArduinoOTA.handle();
// Request temperature reading from the DS18B20 sensor
sensors.requestTemperatures();
float temperatureC = round(sensors.getTempCByIndex(0) * 10) / 10;
// Print temperature to Serial Monitor (optional)
Serial.print("Temperature: ");
Serial.print(temperatureC);
Serial.println(" °C");
// Send temperature data to Domoticz
sendDataToDomoticz(temperatureC);
check_OTA();
// Enter Deep Sleep mode
Serial.println("Going into Deep Sleep...");
delay(500); // Allow the serial messages to be sent
ESP.deepSleep(sleepDuration);
void sendDataToDomoticz(float temperature) {
WiFiClient client;
if (client.connect(domoticzIp, domoticzPort)) {
String url = "/json.htm?type=command¶m=udevice&idx=124&nvalue=0&svalue=";
url += String(temperature);
client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + domoticzIp + "\r\n" + "Connection: close\r\n\r\n");
client.stop();
Serial.println("Error connecting to Domoticz");
void check_OTA() {
WiFiClient client;
// setup_wifi(); must be called before check_OTA();
Serial.print("Firmware: ");
Serial.println(FW_VERSION);
Serial.println("Check for OTA");
HTTPClient http;
if (http.begin(client, fwVersionURL)) {
Serial.println("http begin");
int httpCode = http.GET();
Serial.print("httpCode:");
Serial.println(httpCode);
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
String newFWVersion = http.getString();
Serial.print("Server FWVersion: ");
Serial.println(newFWVersion);
Serial.println(" / ");
Serial.print("Current FWVersion: ");
float newVersion = newFWVersion.toFloat();
if (newVersion > FW_VERSION) {
Serial.println("start OTA !");
http.end();
delay(100);
t_httpUpdate_return ret = ESPhttpUpdate.update(client, fwImageURL);
switch (ret) {
case HTTP_UPDATE_FAILED:
Serial.print("HTTP_UPDATE_FAILD Error ");
Serial.print(ESPhttpUpdate.getLastError());
Serial.print(": ");
Serial.println(ESPhttpUpdate.getLastErrorString().c_str());
// Serial.printf("HTTP_UPDATE_FAILD Error (%d): %s\n", ESPhttpUpdate.getLastError(), ESPhttpUpdate.getLastErrorString().c_str());
case HTTP_UPDATE_NO_UPDATES:
Serial.println("HTTP_UPDATE_NO_UPDATES");
case HTTP_UPDATE_OK:
Serial.println("HTTP_UPDATE_OK");
Serial.println("no new version available");
} // end if http.begin
Serial.println("End of OTA");
} // end check_OTA()
