esp8266 problem
hi everyone
i'm trying to control led on and off time by using millis() with nodemcu-esp8266 and RemoteXY app
i used a code i found on internet which it's work very well with arduino uno and potentiometer but it doesn't work with esp8266
video link of the process Gofile - Free Unlimited File Sharing and Storage
the codes that i used
1- with UNO
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
int ledPin =  8;      // the number of the LED pin
int ledState = LOW;             // ledState used to set the LED
unsigned long previousMillis = 0;        // will store last time LED was updated
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  lcd.init();
  lcd.backlight();
  long OnTime = analogRead(A0);
  long OffTime = analogRead(A1);
  Serial.println(OnTime);
  Serial.println(OffTime);
  // check to see if it's time to change the state of the LED
  if ((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
    ledState = LOW;  // Turn it off
    previousMillis = currentMillis;  // Remember the time
    digitalWrite(ledPin, ledState);  // Update the actual LED
  else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
    ledState = HIGH;  // turn it on
lcd.setCursor(0,0);
  lcd.print("on time = ");
    lcd.print(OnTime);
  lcd.setCursor(0,1);
  lcd.print("off time = ");
    lcd.print(OffTime);
2- with esp8266 and RmoteXY app
   -- test --
   This source code of graphical user interface
   has been generated automatically by RemoteXY editor.
   To compile this code using RemoteXY library 2.4.3 or later version
   download by link http://remotexy.com/en/library/
   To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
     - for ANDROID 4.3.1 or later version;
     - for iOS 1.3.5 or later version;
   This source code is free software; you can redistribute it and/or
   modify it under the terms of the GNU Lesser General Public
   License as published by the Free Software Foundation; either
   version 2.1 of the License, or (at your option) any later version.
//        RemoteXY include library          //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP8266WIFI_LIB_POINT
#include <ESP8266WiFi.h>
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_WIFI_SSID "RemoteXY"
#define REMOTEXY_WIFI_PASSWORD "12345678"
#define REMOTEXY_SERVER_PORT 6377
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255, 3, 0, 22, 0, 113, 0, 8, 13, 1,
  4, 0, 11, 12, 12, 64, 2, 26, 2, 0,
  19, 87, 22, 11, 2, 26, 31, 31, 79, 78,
  0, 79, 70, 70, 0, 4, 0, 41, 12, 12,
  64, 2, 26, 129, 0, 37, 78, 18, 6, 24,
  111, 102, 102, 32, 116, 105, 109, 101, 0, 129,
  0, 6, 78, 22, 6, 24, 111, 110, 32, 116,
  105, 109, 101, 0, 67, 5, 6, 5, 20, 5,
  2, 26, 11, 67, 5, 38, 5, 20, 5, 2,
  26, 11, 129, 0, 11, 11, 11, 3, 1, 115,
  101, 99, 111, 110, 100, 0, 129, 0, 43, 11,
  11, 3, 1, 115, 101, 99, 111, 110, 100, 0
// this structure defines all the variables of your control interface
struct {
  // input variable
  int8_t slider_on_time; // =0..100 slider position
  uint8_t switch_1; // =1 if switch ON and =0 if OFF
  int8_t slider_off_time; // =0..100 slider position
  // output variable
  char text_on_time[11];  // string UTF8 end zero
  char text_off_time[11];  // string UTF8 end zero
  // other variable
  uint8_t connect_flag;  // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
//           END RemoteXY include          //
#include <Wire.h>
int ledPin =  D3;   //led pin to D2
int ledState = LOW;
  RemoteXY_Init ();
  pinMode(ledPin, OUTPUT);
lcd.init();
  lcd.backlight();
  RemoteXY_Handler ();
  long Ont;
  long Offt;
  long OnTime = Ont;
  long OffTime = Offt;
  Ont = map (RemoteXY. slider_on_time , 0 , 100 , 0 , 5000 ) ;
  float ont = (float)Ont;                                          //convert long to float
  float v1_1n = ont / 1000;
  dtostrf(v1_1n, 0, 1, RemoteXY.text_on_time);                     //convert float to char
  Offt = map (RemoteXY. slider_off_time , 0 , 100 , 0 , 5000 ) ;
  float offt = (float)Offt;                                     //convert long to float
  float  v1_2n = offt / 1000;
  dtostrf(v1_2n, 0, 1, RemoteXY.text_off_time);                  //convert float to char
  else {
    digitalWrite(ledPin, 0);
lcd.setCursor(0,0);
    lcd.print(v1_1n);
  lcd.setCursor(0,1);
    lcd.print(v1_2n);
and the millis code i used with codes above is
int ledPin1 =  12;      // the number of the LED pin
int ledState1 = LOW;             // ledState used to set the LED
unsigned long previousMillis1 = 0;        // will store last time LED was updated
long OnTime1 = 250;           // milliseconds of on-time
long OffTime1 = 750;          // milliseconds of off-time
int ledPin2 =  13;      // the number of the LED pin
int ledState2 = LOW;             // ledState used to set the LED
unsigned long previousMillis2 = 0;        // will store last time LED was updated
long OnTime2 = 330;           // milliseconds of on-time
long OffTime2 = 400;          // milliseconds of off-time
  // set the digital pin as output:
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  if((ledState1 == HIGH) && (currentMillis - previousMillis1 >= OnTime1))
    ledState1 = LOW;  // Turn it off
    previousMillis1 = currentMillis;  // Remember the time
    digitalWrite(ledPin1, ledState1);  // Update the actual LED
  else if ((ledState1 == LOW) && (currentMillis - previousMillis1 >= OffTime1))
    ledState1 = HIGH;  // turn it on
  if((ledState2 == HIGH) && (currentMillis - previousMillis2 >= OnTime2))
    ledState2 = LOW;  // Turn it off
    previousMillis2 = currentMillis;  // Remember the time
    digitalWrite(ledPin2, ledState2);  // Update the actual LED
  else if ((ledState2 == LOW) && (currentMillis - previousMillis2 >= OffTime2))
    ledState2 = HIGH;  // turn it on
