Esp8266 programming
I have programator board for esp32 wroom boards and it works ok. I want to program esp8266 with same programator. Is that possible? I allready tried connect tx rx and gpio 0 but cant get it to work. Pictures of boards:
I can't say, but as there are a lot of almost identical boards, I think you better check about compatibility with that specific ESP8266 version (ESP-12F?) on the vendor site (do you still have the link?).
Why don't you just get a similar programmer but for ESP8266? I got both types and it is very convenient for work.
Was thinkinh, this board is just ftdi with some other comp. to be breakout board. So if i remove esp32 and with jumper wires connect esp07, there is no issue to use it like programmer. Will try tomorrow. I will connect gpio 15,2,0 and en,tx rx. On breakout board cant find pin reset. It shoud work. Ftdi adapter is able to program this esp07 without problems.
