While trying to setup a web server which tracks the sensor data from a DHT22 temperature and humidity sensor, my NodeMCU ESP8266 keeps getting these panic interrupts:
User exception (panic/abort/assert)
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Panic core_esp8266_main.cpp:137 __yield
>>>stack>>>
*cut for clarity*
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
Decoding the stack gives:
*Decoding stack results* 0x402069ce: **DHT::read(bool)** at C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library-1.4.2\**DHT.cpp** line **252** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x40100b50: **malloc(size_t)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **821** 0x40100b88: **realloc(void*, size_t)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **853** 0x40100b50: **malloc(size_t)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **821** 0x40100b88: **realloc(void*, size_t)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **853** 0x40100b88: **realloc(void*, size_t)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **853** 0x402074a1: **String::changeBuffer(unsigned int)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**WString.cpp** line **202** 0x40206b24: **DHT::readHumidity(bool)** at C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library-1.4.2\**DHT.cpp** line **150** 0x40207588: **String::copy(char const*, unsigned int)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**WString.cpp** line **225** 0x401001ce: **readDHT22Humidity()** at C:\Users\Robert\Documents\Arduino\nodemcu_kas_v3/**nodemcu_kas_v3.ino** line **19** 0x40201086: **operator()(AsyncWebServerRequest*)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/**WString.h** line **277** 0x4020319a: **AsyncWebServerRequest::addInterestingHeader(String const&)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/**WString.h** line **79** 0x402075c1: **String::String(char const*)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**WString.cpp** line **41** 0x40206452: **AsyncCallbackWebHandler::canHandle(AsyncWebServerRequest*)** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/**WebHandlerImpl.h** line **125** 0x402010dc: **std::_Function_handler >::_M_invoke(const std::_Any_data &, AsyncWebServerRequest *&&)** at c:\users\robert\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\bits/**invoke.h** line **103** 0x4020621c: **AsyncCallbackWebHandler::handleRequest(AsyncWebServerRequest*)** at c:\users\robert\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\bits/**std_function.h** line **617** 0x4020455d: **AsyncWebServerRequest::_removeNotInterestingHeaders()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/**WString.h** line **79** 0x402066c0: **AsyncWebServer::_attachHandler(AsyncWebServerRequest*)** at c:\users\robert\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\bits/**std_function.h** line **680** 0x40204680: **AsyncWebServerRequest::_parseLine()** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src\**WebRequest.cpp** line **581** 0x40208124: **String::trim()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/**WString.h** line **277** 0x4020784c: **String::concat(char const*)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**WString.cpp** line **317** 0x4020474a: **AsyncWebServerRequest::_onData(void*, unsigned int)** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src\**WebRequest.cpp** line **124** 0x401003dd: **millis()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_wiring.cpp** line **193** 0x4020492c: **std::_Function_handler >::_M_invoke(const std::_Any_data &, void *&&, AsyncClient *&&, void *&&, unsigned int &&)** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src\**WebRequest.cpp** line **76** 0x40201f7c: **AsyncClient::_recv(std::shared_ptr&, tcp_pcb*, pbuf*, long)** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncTCP-master\src/**ESPAsyncTCP.h** line **103** 0x40201fdc: **AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, long)** at c:\users\robert\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\bits/**shared_ptr_base.h** line **1324** 0x4021c825: **tcp_input** at core/**tcp_in.c** line **501** 0x40219fad: **ip4_input** at core/ipv4/**ip4.c** line **1467** 0x40100947: **umm_free_core(umm_heap_context_t*, void*)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **549** 0x40212cb1: **ethernet_input_LWIP2** at netif/**ethernet.c** line **188** 0x40212ab0: **esp2glue_ethernet_input** at glue-lwip/**lwip-git.c** line **116** 0x4023ae1d: **ethernet_input** at glue-esp/**lwip-esp.c** line **365** 0x4023ae2f: **ethernet_input** at glue-esp/**lwip-esp.c** line **373** 0x40100b00: **umm_init()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\**umm_malloc.cpp** line **476** 0x401000ac: **app_entry_redefinable()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **325** 0x40212b08: **esp2glue_netif_set_up1down0** at glue-lwip/**lwip-git.c** line **493** 0x40212c00: **esp2glue_netif_update** at glue-lwip/**lwip-git.c** line **418** 0x4023ad14: **netif_set_addr** at glue-esp/**lwip-esp.c** line **588** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x40212de1: **memp_free** at core/**memp.c** line **383** 0x402065e1: **AsyncWebServer::addHandler(AsyncWebHandler*)** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/**StringArray.h** line **32** 0x402138ec: **tcp_free** at core/**tcp.c** line **216** 0x40213b06: **tcp_listen_with_backlog_and_err** at core/**tcp.c** line **915** 0x40213b37: **tcp_listen_with_backlog** at core/**tcp.c** line **828** 0x40201a1d: **AsyncServer::begin()** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncTCP-master\src\**ESPAsyncTCP.cpp** line **1131** 0x4020710c: **Print::println()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/**Print.h** line **57** 0x4020661d: **AsyncWebServer::begin()** at C:\Users\Robert\Documents\Arduino\libraries\ESPAsyncWebServer-master\src\**WebServer.cpp** line **84** 0x401002c8: **ets_post(uint8, ETSSignal, ETSParam)** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **181** 0x401002e9: **esp_schedule()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **128** 0x4020845e: **loop_wrapper()** at C:\Users\Robert\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\**core_esp8266_main.cpp** line **205**
The piece of code where it seems to go wrong is in the request for the sensor data:
String readDHT22Humidity() {
float h = dht.readHumidity();
//float h = 20.0;
if (isnan(h)) {
Serial.println("Failed to read from DHT22 sensor!");
return "";
else {
Serial.println(h);
return String(h);
Using float h = 20 makes the code run fine, but dht.readHumidity() results in the exception. I have looked at the references and it seems that the memory allocation is off. Adding ICACHE_RAM_ATTR to the String function doesn't help (neither does IRAM_ATTR) .
Can anyone help me out with this?
