after I upload my code to my esp the serial monitor shows {Connection to "wifi-name" failed
Retrying in "500" milliseconds}
Debug:
0It�I�dM�$<���***** Arduino IoT Cloud - configuration info *****
Device ID: id
Thing ID: id
MQTT Broker: mqtts-up.iot.arduino.cc:8884
WiFi status ESP: 6
etc.
code
pastebin
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/2413a6ab-2daf-4c8d-a323-7845e5cfcbd2
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
int potentiometer;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
pinMode(A0,INPUT);
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
potentiometer = analogRead(A0);
Since Potentiometer is READ_WRITE variable, onPotentiometerChange() is
executed every time a new value is received from IoT Cloud.
void onPotentiometerChange() {
// Add your code here to act upon Potentiometer change
Okay so the problem is, that if I try to upload with analogRead() and pinmode, it fails, but without these two lines it works.
