Hey! I was able to get ESP8266 working with Arduino Mega. My configuration has it set up as a server. I can connect to the server on a computer or Android device, however connecting on an iOS device or using the Safari browser on a Mac does not work.
Digging deeper and attempting to send a bare GET request through a bash terminal, I was presented with the following error:
curl: (1) Received HTTP/0.9 when not allowed
From my understanding, the issue is that iOS and Safari want to use HTTP/1.0 to connect to the server, however the server is responding in HTTP/0.9? I don't have that much networking experience and am rather new to ESP8266.
For those interested, here is the code I am running on the Arduino:
#define serialCommunicationSpeed 115200
#define DEBUG true
#include <Wire.h>
#include <DS3231.h>
DS3231 clock;
RTCDateTime dt;
Serial.begin(serialCommunicationSpeed);
Serial.println("Serial ok");
Serial1.begin(serialCommunicationSpeed);
clock.begin();
clock.setDateTime(__DATE__, __TIME__);
InitWifiModule();
pinMode(11,OUTPUT);
Serial.print("Compiled at ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Serial.print("Debug mode is ");
Serial.println(DEBUG);
Serial.println("Now entering main loop...");
if(Serial1.available())
if(Serial1.find("+IPD,"))
Serial.println("Request Recieved");
dt = clock.getDateTime();
delay(10);
int connectionId = Serial1.read()-48;
String webpage = "<html><body><p>ESP8266Server/";
webpage.concat("Server Clock: ");
webpage.concat(dt.year);
webpage.concat("-");
webpage.concat(dt.month);
webpage.concat(dt.day);
webpage.concat(" ");
webpage.concat(dt.hour);
webpage.concat(":");
webpage.concat(dt.minute);
webpage.concat(dt.second);
webpage.concat("</p></body></html>");
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=webpage.length();
cipSend +="\r\n";
String commands = sendData(cipSend,300,DEBUG);
if(commands.indexOf("beep") > -1){
tone(11,500,1000);
sendData(webpage,1000,DEBUG);
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId; // append connection id
closeCommand+="\r\n";
sendData(closeCommand,3000,DEBUG);
String sendData(String command, const int timeout, boolean debug)
String response = "";
Serial.print("Command: " + command);
Serial1.print(command);
long int time = millis();
while( (time+timeout) > millis())
while(Serial1.available())
char c = Serial1.read();
response+=c;
if(debug)
Serial.print(response);
return response;
void InitWifiModule()
sendData("AT+RST\r\n", 2000, DEBUG);
sendData("AT+CWJAP=\"WIFI NAME CENSORED\",\"WIFI PASS CENSORED\"\r\n", 2000, DEBUG);
delay (3000);
sendData("AT+CWMODE=1\r\n", 1500, DEBUG);
delay (1500);
sendData("AT+CIFSR\r\n", 1500, DEBUG);
delay (1500);
sendData("AT+CIPMUX=1\r\n", 1500, DEBUG);
delay (1500);
sendData("AT+CIPSERVER=1,80\r\n", 1500, DEBUG);
Serial.println("Server initialized, good to go! ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~");
The idea with my program is to provide commands in the url, like this: SERVERIP/command. Because I am simply searching the serial for the command, a POST request will also work. This system works perfectly fine on Google Chrome. I don't want to mess with TCP clients or other ways of communicating with the project if I can help it as I am developing an app for this and sending GET requests to a server is much easier and simpler. The app is made in MIT App Inventor because it's what I know how to use
. I have made a post on their forums as well to see if it's possible to get it to accept HTTP/0.9. Any help is appreciated.
