[HTTP] GET... failed, error: connection failed
#include <Arduino.h>
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <ESPAsyncWebServer.h>
#include <ESPAsyncTCP.h>
#include "LittleFS.h"
#include <SPI.h>
#include <MFRC522.h>
#include <ESP8266HTTPClient.h>
// Definisi PIN
#define SS_PIN D8
#define RST_PIN D3
#define BUZZER_PIN D1
#define LED_GREEN_PIN D0
#define LED_RED_PIN D4
// SCK PIN D5
// MOSI PIN D6
// MISO PIN D7
const char* PARAM_INPUT_1 = "ssid";
const char* PARAM_INPUT_2 = "pass";
const char* PARAM_INPUT_3 = "ip";
const char* PARAM_INPUT_4 = "gateway";
String HOST_NAME = "http://ramacloud.000webhostapp.com"; // change to your PC's IP address
String PATH_NAME = "/insert_temp.php";
String jsonString;
// Objek untuk RFID
MFRC522 rfid(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
byte nuidPICC[4];
// Objek untuk server web
AsyncWebServer server(80);
// Variabel untuk menyimpan nilai dari formulir HTML
String ssid;
String pass;
String ip;
String gateway;
// Path file untuk menyimpan nilai input secara permanen
const char* ssidPath = "/ssid.txt";
const char* passPath = "/pass.txt";
const char* ipPath = "/ip.txt";
const char* gatewayPath = "/gateway.txt";
// IP dan gateway lokal
IPAddress localIP;
IPAddress localGateway;
IPAddress subnet(255, 255, 0, 0);
// Variabel timer
unsigned long previousMillis = 0;
const long interval = 10000;
// Variabel LED state
String ledState;
// Flag untuk restart
boolean restart = false;
// Inisialisasi LittleFS
void initFS() {
if (!LittleFS.begin()) {
Serial.println("Terjadi kesalahan saat menginisialisasi LittleFS");
Serial.println("LittleFS berhasil diinisialisasi");
// Membaca file dari LittleFS
String readFile(fs::FS &fs, const char *path) {
Serial.printf("Membaca file: %s\r\n", path);
File file = fs.open(path, "r");
if (!file || file.isDirectory()) {
Serial.println("- Gagal membuka file untuk dibaca");
return String();
String fileContent;
while (file.available()) {
fileContent = file.readStringUntil('\n');
file.close();
return fileContent;
// Menulis file ke LittleFS
void writeFile(fs::FS &fs, const char *path, const char *message) {
Serial.printf("Menulis file: %s\r\n", path);
File file = fs.open(path, "w");
if (!file) {
Serial.println("- Gagal membuka file untuk ditulis");
return;
if (file.print(message)) {
Serial.println("- File berhasil ditulis");
Serial.println("- Gagal menulis file");
file.close();
// Inisialisasi WiFi
bool initWiFi() {
if (ssid == "" || ip == "") {
Serial.println("SSID atau alamat IP tidak terdefinisi.");
return false;
WiFi.mode(WIFI_STA);
localIP.fromString(ip.c_str());
localGateway.fromString(gateway.c_str());
if (!WiFi.config(localIP, localGateway, subnet)) {
Serial.println("Gagal mengkonfigurasi STA");
return false;
WiFi.begin(ssid.c_str(), pass.c_str());
Serial.println("Menghubungkan ke WiFi...");
delay(20000); // Delay panjang agar WiFi dapat terhubung
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Gagal terhubung.");
return false;
return true;
// Penanganan permintaan HTTP untuk membaca RFID
void handleOnRequest(AsyncWebServerRequest *request) {
String uidHex = "";
for (byte i = 0; i < rfid.uid.size; i++) {
uidHex += String(rfid.uid.uidByte[i] < 0x10 ? "0" : "");
uidHex += String(rfid.uid.uidByte[i], HEX);
// request->send(200, "application/json", jsonString);
AsyncWebServerResponse *response = request->beginResponse(200, "application/json", jsonString);
response->addHeader("Content-Type", "application/json");
response->addHeader("Authorization", "Bearer YourAccessToken");
response->addHeader("Access-Control-Allow-Origin", "*");
// Kirim respons kembali ke ESP8266
request->send(response);
// Buat URL lengkap dengan parameter UID
String url = HOST_NAME + PATH_NAME + "?UID=" + uidHex;
// Kirim permintaan HTTP GET ke server PHP
WiFiClient client;
HTTPClient http;
http.begin(client, url);
int httpCode = http.GET();
if (httpCode > 0) {
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
if (httpCode == HTTP_CODE_OK) {
String payload = http.getString();
Serial.println(payload);
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
SPI.begin();
rfid.PCD_Init();
pinMode(BUZZER_PIN, OUTPUT);
pinMode(LED_GREEN_PIN, OUTPUT);
pinMode(LED_RED_PIN, OUTPUT);
initFS();
ssid = readFile(LittleFS, ssidPath);
pass = readFile(LittleFS, passPath);
ip = readFile(LittleFS, ipPath);
gateway = readFile(LittleFS, gatewayPath);
Serial.println(ssid);
Serial.println(pass);
Serial.println(ip);
Serial.println(gateway);
if (initWiFi()) {
server.on("/", HTTP_GET, handleOnRequest);
server.serveStatic("/", LittleFS, "/");
server.begin();
Serial.println("Mengatur AP (Access Point)");
WiFi.softAP("ESP-WIFI-MANAGER", NULL);
IPAddress IP = WiFi.softAPIP();
Serial.print("IP AP: ");
Serial.println(IP);
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(LittleFS, "/wifimanager.html", "text/html");
server.on("/", HTTP_POST, [](AsyncWebServerRequest * request) {
int params = request->params();
for (int i = 0; i < params; i++) {
AsyncWebParameter *p = request->getParam(i);
if (p->isPost()) {
if (p->name() == PARAM_INPUT_1) {
ssid = p->value().c_str();
Serial.print("SSID diatur menjadi: ");
writeFile(LittleFS, ssidPath, ssid.c_str());
if (p->name() == PARAM_INPUT_2) {
pass = p->value().c_str();
Serial.print("Password diatur menjadi: ");
writeFile(LittleFS, passPath, pass.c_str());
if (p->name() == PARAM_INPUT_3) {
ip = p->value().c_str();
Serial.print("Alamat IP diatur menjadi: ");
Serial.println(ip);
writeFile(LittleFS, ipPath, ip.c_str());
if (p->name() == PARAM_INPUT_4) {
gateway = p->value().c_str();
Serial.print("Gateway diatur menjadi: ");
writeFile(LittleFS, gatewayPath, gateway.c_str());
restart = true;
request->send(200, "text/plain", "Selesai. ESP akan restart, hubungkan ke router Anda dan buka alamat IP: " + ip);
server.begin();
if (restart) {
delay(5000);
ESP.restart();
if (rfid.PICC_IsNewCardPresent()) {
if (rfid.PICC_ReadCardSerial()) {
String uidHex = "";
DynamicJsonDocument doc(1024);
doc["UID"] = uidHex;
doc["refresh"] = 100;
String jsonString;
serializeJson(doc, jsonString);
digitalWrite(BUZZER_PIN, HIGH);
digitalWrite(LED_GREEN_PIN, HIGH);
digitalWrite(LED_RED_PIN, LOW);
rfid.PICC_HaltA();
rfid.PCD_StopCrypto1();
digitalWrite(LED_GREEN_PIN, LOW);
digitalWrite(LED_RED_PIN, HIGH);
digitalWrite(BUZZER_PIN, LOW);
