ESP8266 Scan the wifi network for connected devices
Hi, I want to use an ESP8266 to scan my home wifi network to turn on a lamp if my computer is connected to the wifi
does your computer have a fixed IP address in your home network? it could be a simple ping test to see if it answers.
otherwise you'll probably have to hack your router's web interface to extract the table of Mac Addresses of connected devices and check for your computer's MAC address. Depends how protected that is.
or your computer could have a script when turned on that pings the Arduino to turn the lamp on and another script when you shut it down.
I found this code on https://www.esp8266.com/viewtopic.php?p=41196#p41196
and after tweaking the windows firewall I managed to get it working.
extern "C" {
#include "ping.h"
#include "os_type.h"
#include <ESP8266WiFi.h>
ping_option pingOps; // Struct used by ping_start, see ping.h
static os_timer_t ping_timer;
// Set all your options here:
#define MY_SSID "your_WiFi_SSID_goes_here"
#define PASSWORD "your_password_goes_here"
#define PING_DELAY_S 1 //amount of time between pings and before a ping times out, sec
#define PING_COUNT 4 //count of pings per request
#define DELAY 3000 // Time to wait after completing a full ping request (doing PING_COUNT pings) and before the next one
IPAddress PING_TARGET(192,168,0,1); // The IP address you're trying to ping
// This function is called when ping_timer fires:
static void ICACHE_FLASH_ATTR ping_cb(void *arg)
  os_timer_disarm(&ping_timer);
  Serial.println("---");
  Serial.print("Pinging: ");
  Serial.print(PING_TARGET);
  Serial.println(" with 32 bytes of data:");
  ping_start(&pingOps);
// This function is called when a ping is received or the request times out:
static void ICACHE_FLASH_ATTR ping_recv (void* arg, void *pdata)
  struct ping_resp *pingrsp = (struct ping_resp *)pdata;
  if (pingrsp->bytes > 0)
    Serial.print("Reply from: ");
    Serial.print(": ");
    Serial.print("bytes=");
    Serial.print(pingrsp->bytes);
    Serial.print(" time=");
    Serial.print(pingrsp->resp_time);
    Serial.println("ms");
    Serial.println("Request timed out");
// This function is called after the ping request is completed
// (i.e., after PING_COUNT pings are done)
static void ICACHE_FLASH_ATTR ping_sent (void* arg, void *pdata)
  Serial.print("Ping statistics for: ");
  Serial.println(PING_TARGET);
  Serial.print("Packets: Sent = ");
  Serial.print(pingrsp->total_count);
  Serial.print(", Recieved = ");
  Serial.print(pingrsp->total_count-pingrsp->timeout_count);
  Serial.print(", Lost = ");
  Serial.print(pingrsp->timeout_count);
  Serial.print(" (");
  Serial.print(float(pingrsp->timeout_count)/pingrsp->total_count*100);
  Serial.println("% loss)");
  // Ping request complete, rearm the timer so that a new request is sent in DELAY seconds
  os_timer_arm(&ping_timer, DELAY, 1);
// Function for connecting to the designated WiFi SSID:
void connectToWifi() {
  WiFi.begin(MY_SSID, PASSWORD);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(MY_SSID);
  Serial.print("IP address: ");
  connectToWifi();
  // Setup the ping options:
  pingOps.count = PING_COUNT;
  pingOps.ip = uint32_t(PING_TARGET);
  pingOps.coarse_time = PING_DELAY_S;
  ping_regist_sent(&pingOps, ping_sent);
  ping_regist_recv(&pingOps, ping_recv);
  os_timer_setfn(&ping_timer, (os_timer_func_t *)ping_cb, (void *)0);
  // Timer ping_timer will fire after DELAY seconds elapse, calling function ping_cb
  // The timer is disarmed in the first line of ping_cb, so it doesn't actually fire every DELAY seconds continiously
  // Anything else you want to do!
