Hi guys,
I am having some problems when I want to send a JSON to the server.
I have this code:
#include <ESP8266.h>
#include <SoftwareSerial.h>
#define SSID "..."
#define PASSWORD "..."
#define HOST_NAME "jsonplaceholder.typicode.com"
#define HOST_PORT (80)
SoftwareSerial mySerial(2, 3); /* RX:D3, TX:D2 */
ESP8266 wifi(mySerial);
bool setupSuccess = false;
struct Data {
char title[64];
char body[64];
Serial.println("-Setup begin\n");
Serial.println("--Checking wifi connection");
delay(1500);
showIPStatus();
String IPStatus = wifi.getIPStatus().substring(7,8);
Serial.println("STA: "+ IPStatus);
if( IPStatus == "2" || IPStatus == "3"){
Serial.println("\nConnected\n");
disableMux();
setupSuccess = true;
Serial.println("\nNot connected");
if(connectWifi())
Serial.println("\n-Setup end\n");
if(setupSuccess){
sendData();
//postData();
while(1);
bool startTCPConn(){
Serial.print("--Starting TCP connection: ");
mySerial.println("AT+CIPSTART=\"TCP\",\"jsonplaceholder.typicode.com\",80"); //start a TCP connection.
if (mySerial.find("OK")) {
Serial.println("OK");
else{
Serial.println("ERR");
return false;
Serial.print("--Checking TCP connection: ");
if(wifi.getIPStatus().substring(7,8) == "3"){
return true;
return false;
void postData(){
if(startTCPConn()){
char *postRequest = "POST /posts HTTP/1.1\r\nHost: jsonplaceholder.typicode.com\r\nContent-Type: application/json\r\n\r\n{\"title\":\"testing\",\"body\":\"arduinogato\",\"userId\":89}";
String sendCmd = "AT+CIPSEND="; //determine the number of caracters to be sent.
mySerial.print(sendCmd);
mySerial.println(strlen(postRequest));
Serial.print("SIZE: ");
if (mySerial.find(">")) {
Serial.println("--Posting data..");
Serial.println("Sending: ");
Serial.print(postRequest);
mySerial.print(postRequest);
if (mySerial.find("SEND OK")) {
Serial.println("\nPost OK");
//waitForResponse("CLOSED",10000);
while(1) {
char c = mySerial.read() ;
Serial.print(c);
mySerial.println("AT+CIPCLOSE");
Serial.println("Sending error");
void sendData(){
if(startTCPConn()){
Data data;
//Send data
char *hello = "GET /posts/99 HTTP/1.1\r\nHost: jsonplaceholder.typicode.com\r\n\r\n";
mySerial.println(strlen(hello));
Serial.println("--Sending data..");
mySerial.print(hello);
Serial.println("Packet sent");
while(mySerial.available()){
Serial.println(mySerial.readString());
void showIPStatus(){
Serial.println(wifi.getIPStatus());
void createTCPConnection(){
if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
Serial.print("create tcp ok\r\n");
Serial.print("create tcp err\r\n");
bool connectWifi(){
Serial.println("\nConnecting\n");
Serial.print("Setting AP + Station mode: ");
if (wifi.setOprToStationSoftAP()) {
Serial.print("\nJoining Access Point: ");
if (wifi.joinAP(SSID, PASSWORD)) {
Serial.println("IP: ");
Serial.println(wifi.getLocalIP().c_str());
delay(1500);
disableMux();
return true;
Serial.print("ERROR\r\n");
return false;
bool disableMux(){
Serial.print("\n--Disabling MUX: ");
if (wifi.disableMUX()) {
return true;
return false;
boolean waitForResponse(String target, unsigned long timeout)
unsigned long startTime = millis();
String responseBuffer;
char charIn;
//keep checking for ESP response until timeout expires
while ((millis() - startTime) < timeout)
if (mySerial.available())
charIn = mySerial.read();
responseBuffer += charIn;
if (responseBuffer.endsWith(target))
return 1; //true
if (!responseBuffer.endsWith(target))
Serial.print("---ERROR ");
Serial.println(responseBuffer);
return 0; //false
Serial.print("---SUCCESS ");
return 1; //true
//reset the esp8266 module
void reset() {
mySerial.println("AT+RST");
delay(3000);
Serial.println("Module Reset");
When I execute this code (sendData()):
if(setupSuccess){
sendData();
//postData();
while(1);
It works fine and I receive:
+IPD,874:HTTP/1.1 200 OK
Date: Thu, 29 Jun 2017 02:53:52 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 224
Connection: keep-alive
Set-Cookie: __cfduid=d0292901803486d2d3b179def5ac2485c1498704832; expires=Fri, 29-Jun-18 02:53:52 GMT; path=/; domain=.typicode.com; HttpOnly
X-Powered-By: Express
Vary: Origin, Accept-Encoding
Access-Control-Allow-Credentials: true
Cache-Control: public, max-age=14400
Pragma: no-cache
Expires: Thu, 29 Jun 2017 06:53:52 GMT
X-Content-Type-Options: nosniff
Etag: W/"e0-aXopzb0YfAN1tmSD/RVNZPaEz8g"
Via: 1.1 vegur
CF-Cache-Status: HIT
Server: cloudflare-nginx
CF-RAY: 37659910f45e6575-SYD
"userId": 10,
"id": 99,
"title": "temporibus sit alias delectus eligendi possimus magni",
"body": "quo deleniti praesentium dicta non quod\naut est molestias\nmolestias et officia quis nihil\nitaque dolorem quia"
The problem is when I execute this (postData()):
if(setupSuccess){
//sendData();
postData();
while(1);
When I get the response and I read it in this way:
while(1) {
Serial.print(c);
I receive this:
--Starting TCP connection: OK
--Checking TCP connection: OK
--Posting data..
Sending:
{"title":"testing","body":"arduinogato","userId":89}
Post OK
+IPD,630:HTTP/1.1 201 Created
Date: Thu, 29 Jun 2017 02:56:18 GMT
Content-Length: 15
Set-Cookie: __cfduid=d3f5421b925be79ab723b48bc4a7c80ea1498704977; expires=Fri, 29-Jun-18 02:56:17 GMT; path=/; domain=.typicode.com; HttpOnly
Vary: Origin, X-HTTP-Method-Override, Accept-Encoding
Cache-Control: no-cache
Pragma: no-cache
Expires: -1
Etag: W/"f-4jjw4Y8q22Yv1PV9m28FczJgjzk"
Via: 1.1 vegur
CF-RAY: 37659c9ed5790b14-SYD
"id": 101
+IPD,334:HTTP/1.1 400 Bad Request
Content-Type: text/html
Content-Length: 177
Connection: close
Server: -nginx
CF-RAY: -
<html>
<head><title>400 Bad Request</title></head>
<body bgcolor="white">
<center><h1>400 Bad Request</h1></center>
<hr><center>cloudflare-nginx</center>
</body>
</html>
CLOSED
If I send the same request through postman:
Postman-Token: 27da982b-4471-d125-d8bf-7ce74ed48271
I receive this:
"title": "testing",
"body": "arduinogato",
"userId": 89,
"id": 101
Do you know why it is happening?
Cheers,
Lucas.
