Hell, I have been looking for a way to see serial monitor data that I would See in the Arduino IDE but within the web page of the Esp8266. Everything so far I have found is mostly for Ethernet, bluetooth or sensors. I'm just trying to see the whole thing. Is this possible and How can I do something like this? Please help me to figure this out.
Joseph
hammy
February 15, 2022, 5:57pm
2
What you want to do is not very clear . Try and be a bit more specific about what you actually want to see and on what device .
You need to look up web server , web client examples - I think that’s what you need .
ec2021
February 15, 2022, 6:02pm
3
Are you intending to copy Serial output to a remote TCP client?
Hello, Sorry If I'm unclear what I'm trying to ask. I have a bunch of data always in Serial monitor thought the arduino IDE. The problem is my arduino not always plugged into my computer to see that information. I would love to display that Serial monitor information that I'm seeing in the IDE to display within the webpage of the webserver of the Esp8266. Currently I only have a couple things displaying and only part of it I display. But I would love to display it all as it is shown in the Serial monitor of the Arduino IDE.
Joseph
What is it that you want to display ?
In essence there is no limit to how much data that can be displayed on a web page served up by a webserver running on the ESP8266
This data could be displayed continuously or updated on demand
ec2021
February 15, 2022, 6:23pm
6
You can do this with a webpage or use a TCP connection as a terminal like the Serial monitor. This depends on whether you want to use a standard browser or a terminal program like PuTTY.
I have done it for PuTTY so that I can handle my ESP32 from remote as if it was connected to Serial (with the exception of uploading a sketch of course, which requires OTA functionality).
Hey Bob nice to you man. I wanted to display Whatever from the serial monitor If i refresh The page. Showing continuously might freak out the esp8266 repeatly refreshing fast. Don't quote me on that sense I have never done this before.
Joseph
hello ec2021, I just wanted to display on the webpage as I do see it on the arduino ide no difference. I don't want it to change nothing Just for monitoring.
Joseph
Juraj
February 15, 2022, 6:34pm
9
f it doesn't have to be a web page, but you want to do OTA terminal, then I have the TelnetStream library in Library Manager
True. But If Ineed to access it from any computer or browser that is not my own. I do not want to download programs on someone elses system just to see my info.
Joseph
ec2021
February 15, 2022, 6:40pm
11
I would recon that it is interesting to know
how many lines you want to display on the page
about the expected update rate of the data
about any requirements regarding the formatting of the data
how long a specific information shall be visible on the page
which all may have an influence on how to set up the web page ...
Basically I'm setting up a home lab with lights, motion sensor, plugs and what not on it. the esp8266 just reads everything if it is on/off or if a device is not connecting and says failed. That is all.
Joseph
simple to use solution
google is always worth a quick try with keywords "github Arduino" + your word of interest
best regards Stefan
If you use TelnetStream on the ESP8266 then you can potentially access the "Serial Monitor" from anywhere in World using a device capable of connecting to the Internet and running a telnet client, which Windows can do
UKHeliBob:
telnet needs more expertise than webserial
IP-adress/webserial
and you are done with accessing webserial
Can you post a link to how to start and adjust a telnet client?
best regards Stefan
ec2021
February 15, 2022, 10:14pm
16
I have not investigated into it but there is actually a Telnet lib for ESP8266/ESP32:
https://www.arduino.cc/reference/en/libraries/esp-telnet/
With Windows 10 one may run cmd.exe and call
"telnet 192.168.4.1" ((hostname), port default is 23 or
"telnet 192.168.4.1 23" (hostname port) or
"telnet" and then "open hostname" or "open hostname port"
If disabled there is an explanation how to enable Telnet on Windows 10:
https://winbuzzer.com/2020/05/12/how-to-enable-the-telnet-client-in-windows-10-xcxwbt/
(Sorry @StefanL38 , I was typing the answer while you posted ... )
I was asking not precise enough:
Can you post a link where using a Windows 10 telnet-client is explained for beginners?
step by step.
best regards Stefan
Who needs a link ?
On the PC
Run PuTTY
Select telnet and the port number defaults to 23
Enter the IP address of the target board and click Open
the telnet terminal is running now
or
open a CMD prompt
type telnet followed by the IP address of the target board and press Return
the telnet terminal is now running
After installing the TelnetStream library from the Library Manager all you need to do in the sketch is to #include "TelnetStream.h" then use `TelnetStream.print() instead of or as well as Serial.print() (or any of the other print commands, including Serial.printf() ) and you are in business
Is setting up and using WebSerial that easy ?
I have just installed the WebSerial library from the Library Manager and the Demo example will not compile for an ESP32 board due to
C:\Users\Bob2\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/AsyncWebSocket.cpp:1272: undefined reference to `SHA1Init'
and
C:\Users\Bob2\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/WebAuthentication.cpp:73: undefined reference to `mbedtls_md5_starts'
Any ideas ?
ec2021
February 15, 2022, 10:48pm
19
StefanL38:
telnet-client
I just took this example from github
TelnetServerWithWiFiManager.ino
downloaded these Libs
#include "ESPTelnet.h"
#include "WiFiManager.h"
commented " // ESP.reset();" out in line 59 (as it does not compile for my ESP32, but could change it to ESP.restart(); if required ....), added SSID and Pwd of my WiFi network:
and connected via telnet from Windows 10
The ESP32 connected to WiFi and I could connect with its IP (took several seconds to connect). Now anything send to the ESP32 via Serial is copied to Telnet.
The same with PuTTY:
Here is a amended code from https://github.com/LennartHennigs/ESPTelnet that works fine with telnet:
// ESP8266 only - as WiFiManager is not working (yet) on ESP32
#define PORTAL_TIMEOUT 10 * 60 // seconds
#define AP_NAME "MY CAPTIVE PORTAL"
#define AP_PASSWORD ""
#define SERIAL_SPEED 9600
#define WIFI_SSID "Lu"
#define WIFI_PASSWORD "AllesNeu&2019"
ESPTelnet telnet;
IPAddress ip;
WiFiManager wifiManager;
void setupSerial(long speed, String msg = "") {
Serial.begin(speed);
while (!Serial) {
delay(200);
if (msg != "") Serial.println(msg);
bool isConnected() {
return (WiFi.status() == WL_CONNECTED);
void useWiFiManager() {
// wifiManager.resetSettings(); // this will delete all credentials
wifiManager.setDebugOutput(false);
wifiManager.setConfigPortalTimeout(PORTAL_TIMEOUT);
wifiManager.setAPCallback([] (WiFiManager *myWiFiManager) {
Serial.println("- No known wifi found");
Serial.print("- Starting AP: ");
Serial.println(myWiFiManager->getConfigPortalSSID());
Serial.println(WiFi.softAPIP());
// enable autoconnect
if (!(AP_PASSWORD == "" ?
wifiManager.autoConnect(AP_NAME) :
wifiManager.autoConnect(AP_NAME, AP_PASSWORD))
Serial.println("- Failed to connect and hit timeout");
ESP.restart();
void errorMsg(String error, bool restart = true) {
Serial.println(error);
if (restart) {
Serial.println("Rebooting now...");
delay(2000);
ESP.restart();
delay(2000);
void setupTelnet() {
// passing on functions for various telnet events
telnet.onConnect(onTelnetConnect);
telnet.onConnectionAttempt(onTelnetConnectionAttempt);
telnet.onReconnect(onTelnetReconnect);
telnet.onDisconnect(onTelnetDisconnect);
// passing a lambda function
telnet.onInputReceived([](String str) {
// checks for a certain command
if (str == "ping") {
telnet.println("> pong");
Serial.println("- Telnet: pong");
Serial.print("- Telnet: ");
if (telnet.begin()) {
Serial.println("running");
Serial.println("error.");
errorMsg("Will reboot...");
// (optional) callback functions for telnet events
void onTelnetConnect(String ip) {
Serial.print(ip);
Serial.println(" connected");
telnet.println("\nWelcome " + telnet.getIP());
telnet.println("(Use ^] + q to disconnect.)");
void onTelnetDisconnect(String ip) {
Serial.print(ip);
Serial.println(" disconnected");
void onTelnetReconnect(String ip) {
Serial.print(ip);
Serial.println(" reconnected");
void onTelnetConnectionAttempt(String ip) {
Serial.print(ip);
Serial.println(" tried to connected");
setupSerial(SERIAL_SPEED, "Telnet Test");
Serial.print("- Wifi: ");
useWiFiManager();
if (isConnected()) {
ip = WiFi.localIP();
Serial.print(" ");
Serial.println(ip);
setupTelnet();
errorMsg("Error connecting to WiFi");
String myString = "";
telnet.loop();
// send serial input to telnet as output
if (Serial.available()) {
char c = Serial.read();
if (c < ' ') {
telnet.println(myString);
myString = "";
} else myString += c;
I made the change mentioned above and also in the loop() to gather a complete line which is send via telnet with println() to achieve the correct linefeed in the telnet window. (It says ESP8266 only, but it works on ESP32 Dev kit.
Using Win10 I just had to open cmd.exe, and call "telnet 192.168.1.175" to connect. Unfortunately the disconnect command did not work, but one can just close the telnet window ...
UKHeliBob:
On the PC
PuTTY needs to be installed.
As a total newcomer I did not even know that telnet uses port 23
So you encountered one of the many cases where I as a real newcomer had a lot of problems to get democode to work
I downloaded the webserial-library as a zip-file new (I use webserialPro)
I added the zipfile library
opened the demofile
and it compiled just fine
F:\2022-01-30\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware F:\2022-01-30\arduino-1.8.19\hardware -hardware F:\2022-01-30\arduino-1.8.19\portable\packages -hardware F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\hardware -tools F:\2022-01-30\arduino-1.8.19\tools-builder -tools F:\2022-01-30\arduino-1.8.19\hardware\tools\avr -tools F:\2022-01-30\arduino-1.8.19\portable\packages -built-in-libraries F:\2022-01-30\arduino-1.8.19\libraries -libraries F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_416627 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\mkspiffs\0.2.3 -verbose F:\2022-01-30\arduino-1.8.19\portable\sketchbook\libraries\WebSerial\examples\Demo\Demo.ino
F:\2022-01-30\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware F:\2022-01-30\arduino-1.8.19\hardware -hardware F:\2022-01-30\arduino-1.8.19\portable\packages -hardware F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\hardware -tools F:\2022-01-30\arduino-1.8.19\tools-builder -tools F:\2022-01-30\arduino-1.8.19\hardware\tools\avr -tools F:\2022-01-30\arduino-1.8.19\portable\packages -built-in-libraries F:\2022-01-30\arduino-1.8.19\libraries -libraries F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_416627 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\tools\mkspiffs\0.2.3 -verbose F:\2022-01-30\arduino-1.8.19\portable\sketchbook\libraries\WebSerial\examples\Demo\Demo.ino
Using board 'esp32' from platform in folder: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "F:\\2022-01-30\\arduino-1.8.19\\portable\\sketchbook\\libraries\\WebSerial\\examples\\Demo\\partitions.csv" copy /y "F:\\2022-01-30\\arduino-1.8.19\\portable\\sketchbook\\libraries\\WebSerial\\examples\\Demo\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\partitions.csv" copy "F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\partitions.csv"
Detecting libraries used...
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.2.7 WiFi@1.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFi@1.0]
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Alternatives for AsyncTCP.h: [AsyncTCP@1.1.1 AsyncTCP-old@1.1.1]
ResolveLibrary(AsyncTCP.h)
-> candidates: [AsyncTCP@1.1.1 AsyncTCP-old@1.1.1]
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Alternatives for ESPAsyncWebServer.h: [ESPAsyncWebServer-old@1.2.3 ESPAsyncWebServer@1.2.3 ESPAsyncWebServer-master@1.2.3]
ResolveLibrary(ESPAsyncWebServer.h)
-> candidates: [ESPAsyncWebServer-old@1.2.3 ESPAsyncWebServer@1.2.3 ESPAsyncWebServer-master@1.2.3]
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\ESPAsyncWebServer\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Alternatives for FS.h: [FS@1.0]
ResolveLibrary(FS.h)
-> candidates: [FS@1.0]
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\ESPAsyncWebServer\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\FS\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Alternatives for WebSerial.h: [WebSerial@1.3.0]
ResolveLibrary(WebSerial.h)
-> candidates: [WebSerial@1.3.0]
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\ESPAsyncWebServer\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\FS\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\WebSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o nul
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\ETH.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\AsyncTCP\src\AsyncTCP.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\AsyncEventSource.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\AsyncWebSocket.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\SPIFFSEditor.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\WebHandlers.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\WebRequest.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\WebResponses.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer\src\WebServer.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\FS\src\FS.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\FS\src\vfs_api.cpp
Using cached library dependencies for file: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\WebSerial\src\WebSerial.cpp
Generating function prototypes...
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\ESPAsyncWebServer\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\FS\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\WebSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"F:\\2022-01-30\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\AsyncTCP\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\ESPAsyncWebServer\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\FS\\src" "-IF:\\2022-01-30\\arduino-1.8.19\\portable\\Sketchbook\\libraries\\WebSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp.o"
Compiling libraries...
Compiling library "WiFi"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiClient.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFi.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\ETH.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiAP.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiScan.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiServer.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiSTA.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiMulti.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WiFi\WiFiUdp.cpp.o
Compiling library "AsyncTCP"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\AsyncTCP\AsyncTCP.cpp.o
Compiling library "ESPAsyncWebServer"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\WebAuthentication.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\AsyncEventSource.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\AsyncWebSocket.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\WebHandlers.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\WebRequest.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\SPIFFSEditor.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\WebResponses.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\ESPAsyncWebServer\WebServer.cpp.o
Compiling library "FS"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\FS\vfs_api.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\FS\FS.cpp.o
Compiling library "WebSerial"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_214768\libraries\WebSerial\WebSerial.cpp.o
Compiling core...
Using precompiled core: C:\Users\dipl-\AppData\Local\Temp\arduino_cache_416627\core\core_d42b15f7ba4b30add9fd29e25ff1107b.a
Linking everything together...
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc" -nostdlib "-LF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/lib" "-LF:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/ld" -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\sketch\\Demo.ino.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\ETH.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiClient.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiServer.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WiFi\\WiFiUdp.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\AsyncTCP\\AsyncTCP.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\AsyncEventSource.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\AsyncWebSocket.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\SPIFFSEditor.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\WebAuthentication.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\WebHandlers.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\WebRequest.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\WebResponses.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\ESPAsyncWebServer\\WebServer.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\FS\\FS.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\FS\\vfs_api.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768\\libraries\\WebSerial\\WebSerial.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_cache_416627\\core\\core_d42b15f7ba4b30add9fd29e25ff1107b.a" -lgcc -lesp_websocket_client -lwpa2 -ldetection -lesp_https_server -lwps -lhal -lconsole -lpe -lsoc -lsdmmc -lpthread -llog -lesp_http_client -ljson -lmesh -lesp32-camera -lnet80211 -lwpa_supplicant -lc -lmqtt -lcxx -lesp_https_ota -lulp -lefuse -lpp -lmdns -lbt -lwpa -lspiffs -lheap -limage_util -lunity -lrtc -lmbedtls -lface_recognition -lnghttp -ljsmn -lopenssl -lcore -lfatfs -lm -lprotocomm -lsmartconfig -lxtensa-debug-module -ldl -lesp_event -lesp-tls -lfd -lespcoredump -lesp_http_server -lfr -lsmartconfig_ack -lwear_levelling -ltcp_transport -llwip -lphy -lvfs -lcoap -lesp32 -llibsodium -lbootloader_support -ldriver -lcoexist -lasio -lod -lmicro-ecc -lesp_ringbuf -ldetection_cat_face -lapp_update -lespnow -lface_detection -lapp_trace -lnewlib -lbtdm_app -lwifi_provisioning -lfreertos -lfreemodbus -lethernet -lnvs_flash -lspi_flash -lc_nano -lexpat -lfb_gfx -lprotobuf-c -lesp_adc_cal -ltcpip_adapter -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/Demo.ino.elf"
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\esptool_py\\3.0.0/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/Demo.ino.bin" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/Demo.ino.elf"
esptool.py v3.0-dev
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/gen_esp32part.exe" -q "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/Demo.ino.partitions.bin"
Multiple libraries were found for "WiFi.h"
Used: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: F:\2022-01-30\arduino-1.8.19\libraries\WiFi
Multiple libraries were found for "AsyncTCP.h"
Used: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\AsyncTCP
Not used: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\AsyncTCP-old
Multiple libraries were found for "ESPAsyncWebServer.h"
Used: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer
Not used: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer-old
Not used: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer-master
Using library WiFi at version 1.0 in folder: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library AsyncTCP at version 1.1.1 in folder: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\AsyncTCP
Using library ESPAsyncWebServer at version 1.2.3 in folder: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\ESPAsyncWebServer
Using library FS at version 1.0 in folder: F:\2022-01-30\arduino-1.8.19\portable\packages\esp32\hardware\esp32\1.0.6\libraries\FS
Using library WebSerial at version 1.3.0 in folder: F:\2022-01-30\arduino-1.8.19\portable\Sketchbook\libraries\WebSerial
"F:\\2022-01-30\\arduino-1.8.19\\portable\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-size" -A "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_214768/Demo.ino.elf"
Sketch uses 815670 bytes (62%) of program storage space. Maximum is 1310720 bytes.
Global variables use 38656 bytes (11%) of dynamic memory, leaving 289024 bytes for local variables. Maximum is 327680 bytes.
best regards Stefan
