ESP8266 serial.println problem with Arduino Rx
Hello all,
I would like to control the arduino nano with esp8266 via serial (rx/tx)
Im uploaded the arduinoESP IDE webserver exampe to the ESP-01, but changed GPIO control to Serial.println.
At the arduino (nano) side, im uploaded a basic Serial.readString program.
My problem is, when arduino nano serial monitor print the ESP string, its print 3 time.
I mean ESP send oncethis:
Serial.println("on"),
then Arduino serial monitor show this:
on
on
on
Any idea?
Arduino code:
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
ESP code:
#include <ESP8266WiFi.h>
const char* ssid = "***";
const char* password = "***";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  //Serial.println("new client");
  while(!client.available()){
    delay(1);
  String req = client.readStringUntil('\r');
  //Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1){
    val = 0;
    Serial.println("on");
  else if (req.indexOf("/gpio/1") != -1){
    val = 1;
    Serial.println("off");
  else {
    //Serial.println("invalid request");
    client.stop();
    return;
  // Set GPIO2 according to the request
  digitalWrite(2, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  //client.print(s);
  //delay(1);
  //Serial.println("Client disonnected");
Ok, problem solved, my ESP8266 modul was wrong.
You may have been in a situation where the "on" was being echoed back and forth between the arduino and the ESP8266.
