ESP8266 - Serve 4 gigabyte file from web server
I have my ESP8266 connected to my home wifi network, acting as a web server. I have an SDcard reader connected with 6 wires, containing an SDcard formatted with FAT32, and I'm writing code that will reliably read very big files from the SDcard and serve them to a remote client over HTTP.
My record so far is a 28-megabyte file. Right now I'm trying to serve a 37 MB file.
Eventually I want my code to be able to reliably send a 4 gig file. What's the biggest file anyone's ever served from an SDcard to a remote client over HTTP?
When serving very big files from the ESP8266, one of the things you need to handle is that 'myFile.available()' will fail before all 4 gigs of the file have been read. When this happens, you need to close the file, re-open it and then seek to where you left off.
If this 37 MB files sends properly then I'm trying 150 MB next. I'm aiming to get it up to 4 gigs.
If I can get it up to 4 gigs, then the next thing I'll try to do is serve two 4-gig files together as if they're one 8-gig file.
Your topic has been moved to a more suitable location on the forum. Please read the sticky topics in Uncategorized - Arduino Forum why you should not post in "Uncategorized".
I was looking through the categories for something like "esp8266" or "sdcard" or "wifi" but I couldn't find a suitable one. In future I'll try harder.
the read speed of SD card in SPI mode and the speed of the esp8266 will make it take a very very very long time. maybe days
Don't worry too much :wink: There is a storage category (for e.g. SD card) and there is a generic microcontrollers category (for e.g. the ESPs). Is this was a mix, I thought that networking etc. was suitable.
When I get it working reliably I'll then try speed it up.
I'm getting 45 kilobytes per second so we're only talking about 5 or 6 hours per gigabyte.
6 x 4 is 24 :slight_smile:
I'd be interested to see how you are doing this. Can you share a schematic and your code?
You should consider the hardwire connections, if not already. If SPI is busy with the SD card, the wiznet module or whatever you use, disabled. So it should be different bus.
Juraj wrote:
6 x 4 is 24
Not sure what point you're making here
45 kbps per second = 162 megabytes per hour = 6 hours per gigabyte.
I might be able to get it a fair bit faster than that though.
I followed the hardware design on this site: https://www.instructables.com/PocketServer-Turn-Your-ESP8266-Into-an-HTML-Web-Se/
But I'm rewriting all the code.
I'll share the code after I've successfully transferred a very big file without errors.
Okay I have two new tactics:
(1) Every half a megabyte, close the file, then re-open it and seek to the previous position.
(2) Every couple of megabytes, pause the TCP transmission for 1 second.
This seems to be much more reliable for sending big files. Just now I successfully downloaded a 64 MB file from the web server, and the SHA256 hash matches so it's not corrupt. I used 'curl' at the Linux command line as follows:
 curl http://192.168.109.71/meg64.bin -o meg64.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 64.0M  100 64.0M    0     0   144k      0  0:07:33  0:07:33 --:--:--  138k
So I downloaded 64 MB in 7 min 33 sec, giving an average speed of 144 kB/s. At this speed it would take 2 hr 1 min to download a gigabyte.
I'm going to tweak the code a little before I try to download a 512 MB file.
I'm getting closer to cracking this now after having found out how to wait for ACK's before sending more data:
Just now I downloaded a 128 MB file in 13min 25sec at an average of 162 kBps.
$ curl http://192.168.167.71/meg128.bin | sha256sum
100  128M  100  128M    0     0   162k      0  0:13:25  0:13:25 --:--:--  186k
The hash matches so no corruption.
I'm going to try get it a little faster before I try 256 MB.
And just now I did 256 megabytes in 28min 6sec (average = 155 kBps).
$ curl http://192.168.167.71/meg256.bin | sha256sum
100  256M  100  256M    0     0   155k      0  0:28:06  0:28:06 --:--:--  170k
08d79c1ce01752446c43ab55b56215546945d53023c58b6c87b8fb8d8ff596ee  -
The hash matches. No corruption.
we can just cheer
go fgotham go
