ESP8266 simple output write does not work?
I use a mod of the blink program to drive an ESP8266 output dependent of the state of a declared input pin. While the output does work when assigned to the blink program, when using a condition dependant on the state of a declared input pin the corresponding output does not react.
What do I stupidly do wrong?
int outPin=13;
int inPin=14;
  pinMode(outPin, OUTPUT);
  digitalWrite(outPin, LOW);
  pinMode(inPin, INPUT);
  if(inPin==HIGH)
  {delay(50);
  digitalWrite(outPin, HIGH); }  // Turn the LED on (Note that LOW is the voltage level
                                    // but actually the LED is on; this is because
   if(inPin==LOW)                                 // it is acive low)
  {delay(50);
  digitalWrite(outPin, LOW); } // Turn the LED off by making the voltage HIGH
You're not reading the pin, you're comparing the pin number.
GrooveFlotilla:
OMG :grin:
thanks
