Esp8266 software serial not reading from device
hello
i have a distance measuring device connected to my esp8266. i have uploaded this code and can successfully communicate via rs232 through PUTTY windows terminal (can communicate in both directions between esp8266 and PUTTY, and also between PUTTY and my device). however, i do not read any information when i hook up my device to the same esp8266 rs232 port. the device data detail are 9600 baud, 8 bit, 1 start, parity:none, 1 stop, no flow control.
i can hook up my device to PUTTY windows terminal and read it fine. this is a sample of what it outputs at 4hz:
D 0000.032 0001.267:
my code, serial monitor, and device are all set to communicate at 9600 baudrate.
Where did i go wrong?
// ESP8266 SoftwareSerial test
#include <SoftwareSerial.h>
#define baudrate 9600//57600//38400//9600//115200
// pins Rx D5 (14) and Tx D6(12)
//SoftwareSerial mySerial(14, 12); // RX, TX
  while (!Serial) {  }
  Serial.println("ESP SoftwareSerial  test!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(baudrate);//9600);
  Serial.print("Serial test - Serial 1 at  baudrate ");
  Serial.println(baudrate);
  //while(1) mySerial.write('X');  // send continuous test
  if (mySerial.available())
    Serial.write(mySerial.read());
  while (Serial.available())
    mySerial.write(Serial.read());
I suggest you read the forum guidelines and post your code accordingly using code tags. Doing this will make your code much easier to read and people helping you.
edited, sorry, didn't see the code tag
Are you using the correct library. As I understand it (no experience on my part) the library had to be updated when the ESP8266 was made available to the Arduino community.
to my knowledge this is correct...
