ESP8266 Thing programmed with Arduino IDE not sending Dweet
New here with a programming question. I’ve searched the web and this forum for Arduino/dweet.io examples. I have not found a solution yet and that brings me here hoping for help.
I have the following code taken from other devices I have collecting sensor data. I have it working, with different sensor packages, on an Uno, a Mega, and 2 Photons. I moved it over to a ESP8266 Thing where it collects sensor data from a MPL3115A2 and a water detector. It then sends it to ThingSpeak every 5 minutes. I added the code for sending a dweet, which was borrowed for other working deployments. The code will compile and upload without problems. It will run and update ThingSpeak every 5 minutes as scheduled. It does not feed the data to dweet.io. Qriginal code was based on GET and I also tried using POST without success. I do not have any serial output as I will have to modify the board to enable that function. I’m not sure if I’m missing any INCLUDES such as http. Any help will be appreciated.
#include <ESP8266WiFi.h>
#include <Wire.h>
#include "SparkFunMPL3115A2.h"
#include "ThingSpeak.h"
// WiFi and Channel parameters
const char WIFI_SSID[] = "########";
const char WIFI_PSK[] = "########";
unsigned long CHANNEL_ID = ######;
const char * WRITE_API_KEY = "########";
#define thing_name  "pvzSumpThing"
char SERVER[] = "www.dweet.io";
// Pin definitions
#define waterSensorPin  A0
#define LED_PIN         5
unsigned long previousMillis = 0;
const long interval = 299930;      // read interval(milliseconds)adjusted for drift; 300000ms=5 min
const String sketchVer = "ESP8266 ThingSpeak EM v3.2 (2018-08-07)";
WiFiClient client;
MPL3115A2 myPressure;
float pressure = 0;
float temperature = 0;
float baroin = 0;
float sumpRaw = 0;
String pres;
String temp;
String baro;
String sump;
  pinMode(waterSensorPin, INPUT);    // Analog pin setup for read
  pinMode(LED_PIN, OUTPUT);         // LED pin as output.
  Wire.begin();        // Join i2c bus
  myPressure.begin(); // Get sensor online
  // MPL3115A2 Settings
  myPressure.setModeBarometer(); // Measure pressure in Pascals from 20 to 110 kPa
  myPressure.setOversampleRate(7); // Set Oversample to the recommended 128
  myPressure.enableEventFlags(); // Enable all three pressure and temp event flags
  connectWiFi();
  ThingSpeak.begin(client);
  sensorCalc();
  if (currentMillis - previousMillis >= interval)
    digitalWrite(LED_PIN, HIGH);
    delay(250);
    digitalWrite(LED_PIN, LOW);
    thingspeak();
    sendDweet();
  delay(100);
  delay(900);
void connectWiFi() {
  byte led_status = 0;
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PSK);
  while ( WiFi.status() != WL_CONNECTED ) {
    digitalWrite(LED_PIN, led_status);
    led_status ^= 0x01;
    delay(100);
void sensorCalc() {
  pressure = myPressure.readPressure();
  temperature = myPressure.readTempF();
  sumpRaw = analogRead(waterSensorPin);   // Read the water sensor channel, ADC
  if (sumpRaw <= 100) {
    sump = "Sump Empty";
  else if (sumpRaw > 100) {
    sump = "Sump Water Detected";
  const int station_elevation_m = 247; //Accurate for 14 Alcott
  pressure /= 100; //pressure is now in millibars
  float part1 = pressure - 0.3; //Part 1 of formula
  const float part2 = 8.42288 / 100000.0;
  float part3 = pow((pressure - 0.3), 0.190284);
  float part4 = (float)station_elevation_m / part3;
  float part5 = (1.0 + (part2 * part4));
  float part6 = pow(part5, (1.0 / 0.190284));
  float altimeter_setting_pressure_mb = part1 * part6; //Output is now in adjusted millibars
  baroin = altimeter_setting_pressure_mb * 0.02953;
void thingspeak() {
  pres = String(round(pressure * 100.00) / 100.00);
  temp = String(round(temperature * 100) / 100.00);
  baro = String(round(baroin * 100) / 100.00);
  ThingSpeak.setField(1, temp);
  ThingSpeak.setField(2, pres);
  ThingSpeak.setField(3, sumpRaw);
  ThingSpeak.setField(4, baro);
  ThingSpeak.writeFields(CHANNEL_ID, WRITE_API_KEY);
void sendDweet() {
  client.stop();
  if (client.connect(SERVER, 80))
    client.print(F("GET /dweet/for/"));
    client.print(thing_name);
    client.print(F("?Pressure="));
    client.print(pres);
    client.print(F("&Temperature="));
    client.print(temp);
    client.print(F("&Barometer="));
    client.print(baro);
    client.print(F("&Sump="));
    client.print(sumpRaw);
    client.print(F("&Status="));
    client.print(sump);
    client.println(F("HTTP/1.1"));
    client.println(F("Host: dweet.io"));
    client.println(F("Connection: close"));
    client.println(F(""));
    delay(3000);
I'm not sure if I'm missing any INCLUDES such as http.
You can be quite sure that if the code compiles, you are not missing any #includes
AWOL:
Thanks for reminding me of that. I'll shift my focus away from the libraries.
A couple decent tutorials:
https://openhomeautomation.net/cloud-temperature-logger-esp8266/
mpeddi:
https://www.hackster.io/TechGuru/esp8266-geolocation-dweet-io-freeboard-io-google-api-334969
mpeddi, thanks. I took a look. It made me realize that I might be attempting to post variables (temp, pres, baro) within sendDweet() that were created within the thingspeak() function. I instead called directly on the variables created in sensorCalc() with no effect.
void thingspeak(){
  pres = String(round(pressure*100.00)/100.00);
  temp = String(round(temperature*100)/100.00);
  baro = String(round(baroin*100)/100.00);
void sensorCalc() {
    if (sumpRaw<=100){
    else if (sumpRaw>100){
The code will run constantly without hesitation, updating ThingSpeak while skipping the dweet. The issue may lie in the connection to the server not occurring for some reason.
Thanks again.
