ESP8266 unable to connect to WiFi
I am trying to make a smart bulb using ESP8266, Firebase and MIT app inventor. My problem is this: My esp8266 is unable to connect to WiFi. My router has a 5G band and a 2.4G band and I am trying to connect to the 2.4G band. My code is the following:
#include <FastLED.h>
#include <DHT.h>
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Firebase_ESP_Client.h>
#define LED_PIN     D8
#define NUM_LEDS    9
#define FASTLED_ESP8266_D1_PIN_ORDERz
CRGB l[NUM_LEDS];
DHT dht(D4, DHT11);
float t = 0.0;
float h = 0.0;
#include "addons/TokenHelper.h"
#include "addons/RTDBHelper.h"
// Insert your network credentials
#define WIFI_SSID "(redacted)"
#define WIFI_PASSWORD "(redacted)"
// Insert Firebase project API Key
#define API_KEY "(redacted)"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "https://desk123-default-rtdb.firebaseio.com/"
//Define Firebase Data object
FirebaseData fbdo;
FirebaseData fbdR;
FirebaseData fbdG;
FirebaseData fbdB;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
String intValue;
String red;
String green;
String blue;
float floatValue;
bool signupOK = false;
  FastLED.addLeds<WS2812, LED_PIN, GRB>(l, NUM_LEDS);
  dht.begin();
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
    Serial.print(".");
    delay(300);
  Serial.print("Connected with IP: ");
  config.api_key = API_KEY;
  config.database_url = DATABASE_URL;
  if (Firebase.signUp(&config, &auth, "", "")) {
    Serial.println("ok");
    signupOK = true;
  else {
    Serial.printf("%s\n", config.signer.signupError.message.c_str());
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
  if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 1000 || sendDataPrevMillis == 0)) {
    sendDataPrevMillis = millis();
    Serial.println("Initializing");
    t = dht.readTemperature();
    h = dht.readHumidity();
    if (isnan(t) || isnan(h)) {
      Serial.println("ERROR");
    if (Firebase.RTDB.setFloat(&fbdo, "Data/temp", t)) {
      Serial.println("PASSED");
      Serial.println("PATH: " + fbdo.dataPath());
      Serial.println("TYPE: " + fbdo.dataType());
    else {
      Serial.println("FAILED");
      Serial.println("REASON: " + fbdo.errorReason());
    if (Firebase.RTDB.setFloat(&fbdo, "Data/humidity", h)) {
    else {
    if (Firebase.RTDB.getInt(&fbdo, "/Data/led") && Firebase.RTDB.getInt(&fbdR, "/Data/red" && Firebase.RTDB.getInt(&fbdG, "/Data/green" && Firebase.RTDB.getInt(&fbdB, "/Data/blue")))) {
      Serial.println("Path existant");
      if (fbdo.dataType() == "int" || fbdo.dataType() == "float" || fbdo.dataType() == "string") {
        Serial.println(fbdo.dataType());
        intValue = fbdo.stringData();
        Serial.println(intValue);
        if (intValue == "1" || intValue == "1.00") {
          red = fbdR.stringData();
          blue = fbdB.stringData();
          green = fbdG.stringData();
          for (int i = 0; i <= NUM_LEDS; i++) {
            l[i] = CRGB(red.toInt(), green.toInt(), blue.toInt());
            FastLED.show();
            FastLED.clear();
            FastLED.show();
    else {
      Serial.println(fbdo.errorReason());
Does anyone know why this is happening? (I removed some variables values and replaced them with (redacted) because of privacy issues)
You might try setting it to station mode. From the example code...
 /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
try wifiscan
#include "ESP8266WiFi.h"
  WiFi.disconnect();
  delay(100);
  Serial.print("Scan start ... ");
  int n = WiFi.scanNetworks();
  Serial.print(n);
  Serial.println(" network(s) found");
  for (int i = 0; i < n; i++)
    Serial.println(WiFi.SSID(i));
  delay(5000);
I tried your code and the WiFi network is showing up as visible, but when I try to connect to it using this code:
#include <DHT.h>
#define LED_PIN     D8
#define NUM_LEDS    9
CRGB l[NUM_LEDS];
DHT dht(D4, DHT11);
float t = 0.0;
float h = 0.0;
//Provide the token generation process info.
//Provide the RTDB payload printing info and other helper functions.
#define WIFI_SSID "xxx"
#define WIFI_PASSWORD "xxx"
#define API_KEY "xxx"
FirebaseData fbdo;
FirebaseData fbdR;
FirebaseData fbdG;
FirebaseData fbdB;
FirebaseAuth auth;
String intValue;
String red;
String green;
String blue;
float floatValue;
  dht.begin();
    Serial.print(".");
    delay(300);
  /* Assign the api key (required) */
  /* Assign */
  /* Sign up */
    signupOK = true;
  else {
  /* Assign the callback function for the long running token generation task */
    else {
    else {
            FastLED.show();
            FastLED.clear();
            FastLED.show();
    else {
It is just printing a long row of dots. Any ideas as to what might be going wrong? I have double checked my WiFi password and it is correct, as is the SSiD
Try with something more simple for now.
#include <ESP8266WiFi.h>        // Include the Wi-Fi library
const char* ssid     = "SSID";         // The SSID (name) of the Wi-Fi network you want to connect to
const char* password = "PASSWORD";     // The password of the Wi-Fi network
  Serial.begin(115200);         // Start the Serial communication to send messages to the computer
  delay(10);
  Serial.println('\n');
  WiFi.begin(ssid, password);             // Connect to the network
  Serial.print("Connecting to ");
  Serial.print(ssid); Serial.println(" ...");
  int i = 0;
  while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
    Serial.print(++i); Serial.print(' ');
  Serial.println("Connection established!");
  Serial.print("IP address:\t");
  Serial.println(WiFi.localIP());         // Send the IP address of the ESP8266 to the computer
void loop() { }
@ZX80 @oldcurmudgeon Thank you for trying to help! In the end, it turned out that the 2.4G band had a different password than the 5G band. Thank you for your help!
