ESP8266+UNO to display data on webpage.
Hi all.
I have a sketch , that for the most part is working, the only part that is not is the data display on the web page.
The code is an example that i found that turns a LED on and off from the web page and is supposed to display a message when a hardware button is pressed on the UNO.
The LED works fine, I can go and type in 192.1**../ON and turn the LED on (OFF for off) and I have thoroughly tested the ESP8266 AT codes successfully.
#include <SoftwareSerial.h>
#define TIMEOUT 5000 // mS
#define LED 5
SoftwareSerial mySerial(7, 6); // RX, TX
const int button = 11;
int button_state = 0;
 pinMode(LED,OUTPUT);
 pinMode(button,INPUT);
 mySerial.begin(9600);
 SendCommand("AT+RST", "Ready");
 delay(5000);
 SendCommand("AT+CWMODE=1","OK");
 SendCommand("AT+CIFSR", "OK");
 SendCommand("AT+CIPMUX=1","OK");
 SendCommand("AT+CIPSERVER=1,80","OK");
void loop(){
 button_state = digitalRead(button);
 if(button_state == HIGH){
    mySerial.println("AT+CIPSEND=0,28");
    mySerial.println("<h1>Button was pressed!</h1>");
    SendCommand("AT+CIPCLOSE=0","OK");
 String IncomingString="";
 boolean StringReady = false;
 while (mySerial.available()){
   IncomingString=mySerial.readString();
   StringReady= true;
  if (StringReady){
    Serial.println("Received String: " + IncomingString);
  if (IncomingString.indexOf("LED=ON") != -1) {
    digitalWrite(LED,HIGH);
  if (IncomingString.indexOf("LED=OFF") != -1) {
    digitalWrite(LED,LOW);
boolean SendCommand(String cmd, String ack){
  mySerial.println(cmd); // Send "AT+" command to module
  if (!echoFind(ack)) // timed out waiting for ack string
    return true; // ack blank or ack found
boolean echoFind(String keyword){
 byte current_char = 0;
 byte keyword_length = keyword.length();
 long deadline = millis() + TIMEOUT;
 while(millis() < deadline){
  if (mySerial.available()){
    char ch = mySerial.read();
    Serial.write(ch);
    if (ch == keyword[current_char])
      if (++current_char == keyword_length){
       return true;
 return false; // Timed out
This is the area that contains the message to be sent when the button is pressed:-
mySerial.println("
Button was pressed!
"); //this is apparently Header format..new to me
The message is displayed in the Serial Monitor but fails to appear on the web page.
The example site shows a successful "send" picture with the message text in place on the web screen.
I am new to this side of things...is there code missing or something else?
Thanks
Doug
Would that be www.example.site.com? If not, perhaps you would be good enough to post a link to the mysterious site.
