Esp8266 water flow meter 0.96 OLED screen
hi,
i am new and trying hard to learn.
i have tested my board/OLED with a basic "hello world!" program and that works fine.
i am using the instructions/code from here: "IoT Water Flow Meter using ESP8266 & Water Flow Sensor" and have removed code relating to transmitting to a server as i just want to look at the screen. this is the code:
**1 #include <ESP8266WiFi.h>**
2 #include <SPI.h>
3 #include <Wire.h>
4 #include <Adafruit_GFX.h>
5 #include <Adafruit_SSD1306.h>
6
7 #define SCREEN_WIDTH 128    // OLED display width, in pixels
8 #define SCREEN_HEIGHT 64    // OLED display height, in pixels
9 #define OLED_RESET -1       // Reset pin # (or -1 if sharing Arduino reset pin)
10
11 Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
12
**13 String apiKey = "KBD1JSZTUKCXJ15V"; // Enter your Write API key from ThingSpeak**
**14 const char *ssid = "Alexahome";     // replace with your wifi ssid and wpa2 key**
**15 const char *pass = "loranthus";**
**16 const char* server = "api.thingspeak.com";**
17
18 #define LED_BUILTIN 16
19 #define SENSOR  2
20
21 long currentMillis = 0;
22 long previousMillis = 0;
23 int interval = 1000;
24 boolean ledState = LOW;
25 float calibrationFactor = 4.5;
26 volatile byte pulseCount;
27 byte pulse1Sec = 0;
28 float flowRate;
29 unsigned long flowMilliLitres;
30 unsigned int totalMilliLitres;
31 float flowLitres;
32 float totalLitres;
33
34 void IRAM_ATTR pulseCounter()
35 {
36   pulseCount++;
37 }
38
**39 WiFiClient client;**
40
41 void setup()
42 {
43   Serial.begin(115200);
44   display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
45   display.clearDisplay();
46   delay(10);
47
48   pinMode(LED_BUILTIN, OUTPUT);
49   pinMode(SENSOR, INPUT_PULLUP);
50
51   pulseCount = 0;
52   flowRate = 0.0;
53   flowMilliLitres = 0;
54   totalMilliLitres = 0;
55   previousMillis = 0;
56
57   attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
58 }
59
60 void loop()
61 {
62   currentMillis = millis();
63   if (currentMillis - previousMillis > interval)
64   {
65
66     pulse1Sec = pulseCount;
67     pulseCount = 0;
68
69     // Because this loop may not complete in exactly 1 second intervals we calculate
70     // the number of milliseconds that have passed since the last execution and use
71     // that to scale the output. We also apply the calibrationFactor to scale the output
72     // based on the number of pulses per second per units of measure (litres/minute in
73     // this case) coming from the sensor.
74     flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
75     previousMillis = millis();
76
77     // Divide the flow rate in litres/minute by 60 to determine how many litres have
78     // passed through the sensor in this 1 second interval, then multiply by 1000 to
79     // convert to millilitres.
80     flowMilliLitres = (flowRate / 60) * 1000;
81     flowLitres = (flowRate / 60);
82
83     // Add the millilitres passed in this second to the cumulative total
84     totalMilliLitres += flowMilliLitres;
85     totalLitres += flowLitres;
86
87     // Print the flow rate for this second in litres / minute
88     Serial.print("Flow rate: ");
89     Serial.print(float(flowRate));  // Print the integer part of the variable
90     Serial.print("L/min");
91     Serial.print("\t");       // Print tab space
92
93     display.clearDisplay();
94
95     display.setCursor(10,0);  //oled display
96     display.setTextSize(1);
97     display.setTextColor(WHITE);
98     display.print("Water Flow Meter");
99
100     display.setCursor(0,20);  //oled display
101     display.setTextSize(2);
102     display.setTextColor(WHITE);
103     display.print("R:");
104     display.print(float(flowRate));
105     display.setCursor(100,28);  //oled display
106     display.setTextSize(1);
107     display.print("L/M");
108
109     // Print the cumulative total of litres flowed since starting
110     Serial.print("Output Liquid Quantity: ");
111     Serial.print(totalMilliLitres);
112     Serial.print("mL / ");
113     Serial.print(totalLitres);
114     Serial.println("L");
115
116     display.setCursor(0,45);  //oled display
117     display.setTextSize(2);
118     display.setTextColor(WHITE);
119     display.print("V:");
120     display.print(totalLitres);
121     display.setCursor(100,53);  //oled display
122     display.setTextSize(1);
123     display.print("L");
124     display.display();
125   }
126
**127   if (client.connect(server, 80)) // "184.106.153.149" or api.thingspeak.com**
**128   {**
**129     String postStr = apiKey;**
**130       postStr += "&field1=";**
**131       postStr += String(float(flowRate));**
**132       postStr += "&field2=";**
**133       postStr += String(totalLitres);**
**134       postStr += "\r\n\r\n";**
**135**
**136     client.print("POST /update HTTP/1.1\n");**
**137     client.print("Host: api.thingspeak.com\n");**
**138     client.print("Connection: close\n");**
**139     client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");**
**140     client.print("Content-Type: application/x-www-form-urlencoded\n");**
**141     client.print("Content-Length: ");**
**142     client.print(postStr.length());**
**143     client.print("\n\n");**
**144     client.print(postStr);**
**145**
**146   }**
**147     client.stop();**
148 }
i also had to make one change to the remaining code as i could not get it to compile;
when line 34 has the IRAM_ATTR i get this: error: expected initializer before ‘pulseCounter’
void IRAM_ATTR pulseCounter() so i read and it seemed ok to remove it entirely. the other BOLD (so bold does not work in a scroll window- lines removed have ** surrounding them; they are 1, 13-16, 39, 109-147) text was also removed.
i also added the adafruit BusIO library to mine. here is what my library shows:
#include <Wire.h>
#include <SPI.h>
#include <splash.h>
#include <Adafruit_GrayOLED.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#include <Adafruit_BusIO_Register.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_I2CRegister.h>
#include <Adafruit_SPIDevice.h>
when i load it to the board, the screen looks like this:
water flow meter
many people mentioned having trouble with the IRAM_ATTR, but no one said their screen did this.
please let me know what is causing this if possible.
thank you
everette
Hi, have you copy-pasted the code correctly here?
https://arduino-esp8266.readthedocs.io/en/latest/mmu.html
The ESP8266 has a total of 64K of instruction memory, IRAM. This 64K of IRAM is composed of one dedicated 32K block of IRAM and two 16K blocks of IRAM. The last two 16K blocks of IRAM are flexible in the sense that it can be used as a transparent cache for external flash memory. These blocks can either be used for IRAM or an instruction cache for executing code out of flash, ICACHE.
Without going through the code logic, my guess is that the original programmer did not expect someone else to go commenting out sections of code.
I understand you do not want the webserver, but you should first attempt to compile the code as designed and if all sections of code work, then you can start to hack piece-by-piece.
Interrupt functions need that attribute. ESP8266 Interrupts and Timers using Arduino IDE (NodeMCU) | Random Nerd Tutorials
Hi, and thanks.
tepalia02- yes the code is copied straight from his site.
mrburnette- i did try the code complete as he posted it and it gave the same error (in addition to others about missing wifi, etc info) and would not compile
blh64- do u have an idea of what is missing? I searched extensively but can't find what "initializer" should be before the statement.
Thanks to all...
Your posted code contains actual line numbers in the code
After cleaning it up and commenting out the things you mentioned, it compiles just fine for a NodeMCU. As for all those other libraries, you shouldn't include them directly, just Adafruit_FX.h and it will include the others for you...
//#include <ESP8266WiFi.h>**
#include <SPI.h>
#include <Wire.h>
#if 0
#endif
#define SENSOR  2
byte pulse1Sec = 0;
float flowRate;
float flowLitres;
float totalLitres;
  pulseCount++;
//WiFiClient client;
  delay(10);
  pulseCount = 0;
  flowRate = 0.0;
  previousMillis = 0;
    pulseCount = 0;
    display.setCursor(10, 0); //oled display
    display.setCursor(0, 20); //oled display
    display.setCursor(100, 28); //oled display
    display.setCursor(0, 45); //oled display
    display.setCursor(100, 53); //oled display
    display.print("L");
    display.display();
#if 0
  client.stop();
#endif
@everette13,
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
blh64,
sorry i didn't know you meant the numbers. i made a printed copy to include them so i could reference line numbers. they are not actually in the code i put in IDE.
on Tools > include library, under "recommended libraries, i am just clicking on "adafruit GFX library" and "adafruit ssd1306", but in puts all those others in as well. i am obviously doing it wrong- should i be looking in a different location to add those libraries correctly? should i just delete the extra ones?
i put in your cleaned up code (thanks for the time) and deleted the extra libraries. here is what i put in and what happened. it still doesn't compile for me. i tried changing the board to "generic esp8266" and "nodemcu 1.0" and "nodemcu 0.9" versions and get same result.
#include <SPI.h>
#include <Wire.h>
#if 0
#endif
#define SENSOR  2
byte pulse1Sec = 0;
float flowRate;
float flowLitres;
float totalLitres;
  pulseCount++;
  delay(10);
  pulseCount = 0;
  flowRate = 0.0;
  previousMillis = 0;
    pulseCount = 0;
    display.print("L");
    display.display();
#if 0
  client.stop();
#endif
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Bedroom\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Bedroom\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Bedroom\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Bedroom\AppData\Local\Temp\arduino_build_231721 -warnings=none -build-cache C:\Users\Bedroom\AppData\Local\Temp\arduino_cache_583858 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\Bedroom\Documents\Arduino\water_flow_forum_test\water_flow_forum_test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Bedroom\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Bedroom\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Bedroom\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Bedroom\AppData\Local\Temp\arduino_build_231721 -warnings=none -build-cache C:\Users\Bedroom\AppData\Local\Temp\arduino_cache_583858 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\Bedroom\Documents\Arduino\water_flow_forum_test\water_flow_forum_test.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Using core 'esp8266' from platform in folder: C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Detecting libraries used...
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.6]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit_SSD1306@2.5.6]
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.11.3]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.11.3]
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.12.0]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.12.0]
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\Bedroom\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Wire" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bedroom\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp" -o "C:\\Users\\Bedroom\\AppData\\Local\\Temp\\arduino_build_231721\\sketch\\water_flow_forum_test.ino.cpp.o"
water_flow_forum_test:35:16: error: expected initializer before 'pulseCounter'
C:\Users\Bedroom\Documents\Arduino\water_flow_forum_test\water_flow_forum_test.ino: In function 'void setup()':
water_flow_forum_test:58:50: error: 'pulseCounter' was not declared in this scope
Using library SPI at version 1.0 in folder: C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\Bedroom\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\Wire
Using library Adafruit_SSD1306 at version 2.5.6 in folder: C:\Users\Bedroom\Documents\Arduino\libraries\Adafruit_SSD1306
Using library Adafruit_GFX_Library at version 1.11.3 in folder: C:\Users\Bedroom\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.12.0 in folder: C:\Users\Bedroom\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
and, PerryBebbington, i apologize for the location. i assumed, wrongly, that since the program did not work it would be in the "troubleshooting" section.
It compiles just fine for me as "generic ESP8266"
I see you are using IDE version 1.8.19 - same as me
The ESP8266 boards version I have is 3.0.2
tried again with "generic esp8266" and same result. i don't know what version the board is- when i click "get board info" it says "unknown board, vid: 10c4, pid:ea60, sn: upload any sketch to obtain it" and it says that after loading the "hello world!" sketch.
so, is that it then? it just will not work for me?
thanks for your time
addendum: finally solved- for any of the others in the original coder's site who were having the same problem if you ever make it here, it apparently is caused by the esp8266 library not being up to date in IDE. mine was 2.5.2 (blh64, i thought you meant the actual board was 3.0.2, not the version library installed in IDE) and IDE does not tell you an update is needed. once installed 3.0.2, all works well.
