Here is the combined sketch.
The line that reads WiFiClient client = server.client(); origianlly read WiFiClient client = server.available(); it returned an error ' has no member named 'available'.
So I thought to try using both port assignments from both sketches together.
ESP8266WebServer server(90);
WiFiServer server(90);.
and of course there was a conflict with the name "server" so I changed one, was able to compile but as expected was unable to connect at all... no auth or page.
I see that each one assigns the port using different libraries. looking at the cpp files it made sense to try WiFiClient client = server.client(); and it works but with problems.
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#ifndef STASSID
#define STASSID "linksys"
#define STAPSK "abc123"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output5State = "off";
String output4State = "off";
// Assign output variables to GPIO pins
const int output5 = 5;
const int output4 = 4;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
//WiFiServer server(90);
const char* www_username = "admin";
const char* www_password = "admin";
// allows you to set the realm of authentication Default:"Login Required"
const char* www_realm = "Custom Auth Realm";
// the Content of the HTML response in case of Unautherized Access Default:empty
String authFailResponse = "Authentication Failed";
// Initialize the output variables as outputs
pinMode(output5, OUTPUT);
pinMode(output4, OUTPUT);
// Set outputs to LOW
digitalWrite(output5, HIGH);
digitalWrite(output4, HIGH);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi Connect Failed! Rebooting...");
ESP.restart();
ArduinoOTA.begin();
server.on("/", []() {
if (!server.authenticate(www_username, www_password))
//Basic Auth Method with Custom realm and Failure Response
//return server.requestAuthentication(BASIC_AUTH, www_realm, authFailResponse);
//Digest Auth Method with realm="Login Required" and empty Failure Response
//return server.requestAuthentication(DIGEST_AUTH);
//Digest Auth Method with Custom realm and empty Failure Response
//return server.requestAuthentication(DIGEST_AUTH, www_realm);
//Digest Auth Method with Custom realm and Failure Response
return server.requestAuthentication(DIGEST_AUTH, www_realm, authFailResponse);
// server.send(200, "text/plain", "Login OK");
server.begin();
Serial.print("Open http://");
Serial.print(WiFi.localIP());
Serial.println("/ in your browser to see it working");
ArduinoOTA.handle();
server.handleClient();
WiFiClient client = server.client(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
previousTime = currentTime;
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /5/on") >= 0) {
Serial.println("GPIO 5 on");
output5State = "on";
digitalWrite(output5, LOW);
} else if (header.indexOf("GET /5/off") >= 0) {
Serial.println("GPIO 5 off");
} else if (header.indexOf("GET /4/on") >= 0) {
Serial.println("GPIO 4 on");
output4State = "on";
digitalWrite(output4, LOW);
} else if (header.indexOf("GET /4/off") >= 0) {
Serial.println("GPIO 4 off");
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #77878A;}</style></head>");
// Web Page Heading
client.println("<body><h1>ESP8266 Web Server</h1>");
// Display current state, and ON/OFF buttons for GPIO 5
client.println("<p>GPIO 5 - State " + output5State + "</p>");
// If the output5State is off, it displays the ON button
if (output5State == "off") {
client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 4
client.println("<p>GPIO 4 - State " + output4State + "</p>");
// If the output4State is off, it displays the ON button
if (output4State == "off") {
client.println("<p><a href=\"/4/on\"><button class=\"button\">ON</button></a></p>");
client.println("<p><a href=\"/4/off\"><button class=\"button button2\">OFF</button></a></p>");
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
in firefox/PC - auth works - buttons work - but LED state change only when page refreshes - has error "Not found: /5/on." in upper left corner of page
in firefox/android - auth not working - goes straight to buttons - buttons work most times but sometimes also needs page refresh and has same error. Not found: /5/on.
it makes more sense that WiFiClient client = server.available(); is able to call 'available' from the original library of webserver with the buttons sketch.
Any help will be great
