Hello everyone. I'm trying to setup a basic MQTT communication scheme that enables a user to control a servo motor (that acts as a simple ramp). The code worked perfectly on my local WiFi up until yesterday when i tried to run it again, and found that my NodeMCU ESP8266 disconnects from WiFi exactly every 15s or so, which messes with the MQTT broker connection so the whole project does not work as it should. The code used is as follows:
#include <Servo.h>
#include "EspMQTTClient.h"
#define LED_RED D2
#define LED_GREEN D1
#define SERVO D4
Servo servo;
EspMQTTClient client(
"mySSID", // WiFi SSID
"myPassword", // WiFi Password
"myServerIP", // MQTT Broker server ip
"myClientName", // Client name that uniquely identify your device
1883 // The MQTT port, default to 1883. this line can be omitted
// This function is called once everything is connected (Wifi and MQTT)
void onConnectionEstablished() {
client.publish("USprojekat/Konekcija", "Device Online", true);
client.publish("USprojekat/ZelenoSvjetlo", "0");
client.publish("USprojekat/CrvenoSvjetlo", "1");
// Subscribe to "USprojekat/Servo" to work with all the functionalities
client.subscribe("USprojekat/Servo",
[](const String & payload) {
Serial.println(payload);
if(payload == "1") {
// Set LEDs to GO
client.publish("USprojekat/ZelenoSvjetlo", "1");
client.publish("USprojekat/CrvenoSvjetlo", "0");
digitalWrite(LED_RED, LOW);
digitalWrite(LED_GREEN, HIGH);
// Raise the ramp
Serial.println("Podizem rampu...");
client.publish("USprojekat/Info", "Podizem rampu...");
int pos = 0;
for(pos; pos <= 180; pos += 3)
servo.write(pos);
// Wait 5s for the car to pass
Serial.println("Rampa podignuta!");
client.publish("USprojekat/Info", "Rampa podignuta!");
delay(5000);
// Set LEDs to GO
digitalWrite(LED_RED, HIGH);
digitalWrite(LED_GREEN, LOW);
// Lower the ramp
Serial.println("Spustam rampu...");
client.publish("USprojekat/Info", "Spustam rampu...");
for(pos = 180; pos >= 0; pos -= 2)
servo.write(pos);
Serial.println("Rampa spustena.");
client.publish("USprojekat/Info", "Rampa spustena.");
client.publish("USprojekat/Servo", "0");
Serial.begin(74880);
client.enableLastWillMessage("USprojekat/Konekcija", "Device Offline", true);
servo.attach(SERVO); // Set the pin for the servo
servo.write(0); // Set the servo to 0 position
pinMode(LED_RED, OUTPUT); // Set the pin for STOP LED
pinMode(LED_GREEN, OUTPUT); // Set the pin for GO LED
// Set LEDs to STOP position on start
// Scan for new messages every 250ms
client.loop();
delay(250);
As you can see, the code also includes control for a couple of LEDs that are signaling if the ramp is being raised or lowered. The MQTT client sends some Info and Status messages as well. What could be the problem?
Thanks in advance!
