ESP8266 wifi module sending data via jQuery
Hey all I have the ESP8266 module and I have already set it up and it's working good. However, when I run this HTML page code here:
<html>
	<head>
		<title>ESP8266 LED Control</title>
	</head>
	<body>
	<button id="6894" class="led">Toggle Pin 13</button> <!-- button for pin 13 -->
	<script src="jquery.min.js"></script>
	<script type="text/javascript">
		$(document).ready(function(){
			$(".led").click(function(){
				var p = $(this).attr('id'); // get id value (i.e. pin13, pin12, or pin11)
				$.get("http://192.168.9.60:80/", {pin:p}); // execute get request
	</script>
	</body>
</html>
I have to send the number 6894 instead of 13 because for some reason its not sending out the correct number. If i send 13 then what it receive is 114. When i send 6894 i receive 689.
My arduino code is this:
//                                [The SSDI of the current wifi router]
//                                |              [The password of the current wifi router]
//                                V              V
String SSIDandPW    = "AT+CWJAP=\"xxxxxxwifi\",\"xxxxxx123\"\r\n";
//                                      [The STATIC IP of the wifi module]
//                                      |                [The main IP of the router]
//                                      |                |              [The default submask]
//                                      V                V              V
String eIPrIPmask   = "AT+CIPSTA_DEF=\"192.168.9.60\",\"192.168.9.1\",\"255.255.255.0\"\r\n";
const int ledDimmer = 5;         // Used to dim the LED strip (digital Pin 3)
SoftwareSerial esp8266(9,10);    // Pin D10 to=> TX on ESP8266 | Pin D9 to=> RX on ESP8266
//================================= End define WiFi Module =================================
  Serial.begin(19200);
  pinMode(13, OUTPUT); //Just for a wifi demo from html page
  //================================ Start Setup WiFi Module =================================
  esp8266.begin(19200);
  sendData("AT+RST\r\n",                    2000, true); // Reset module
  sendData("AT+CWMODE=1\r\n",               2000, true); // Configure as access point
  sendData(SSIDandPW,                       5000, true); // Pass of current wifi
  sendData("AT+CIPMUX=1\r\n",               2000, true); // Configure for multiple connections
  sendData("AT+UART_DEF=19200,8,1,0,0\r\n", 2000, true); // Set baud of COM
  sendData(eIPrIPmask,                      2000, true); // Default network mask IP
  sendData("AT+CIPSERVER=1,80\r\n",         2000, true); // Turn on server on port 80
  sendData("AT+GMR\r\n",                    2000, true); // Get firmware version
  sendData("AT+CIFSR\r\n",                  2000, true); // Get ip address
  Serial.print("Server is now running!");
  //================================ End Setup WiFi Module ===================================
  //=========================================== Start Loop WiFi Module ===========================================
  if(esp8266.available()) {                               // check if the esp is sending a message
    if(esp8266.find("+IPD,")) {
      int connectionId = esp8266.read() - 48;             // subtract 48 because the read() function returns
      esp8266.find("pin=");                               // advance cursor to "pin="
      int retunedNum = (esp8266.read() - 48) * 100;       // get first number (example: 123.. this would be "1")
      retunedNum += (esp8266.read() - 48) * 10;           // get second number (example: 123.. this would be "2")
      retunedNum += (esp8266.read() - 48);                // get last number (example: 123.. this would be "3")
      String closeCommand = "AT+CIPCLOSE=";               // make close command
      Serial.print("returned: ");
      Serial.print(retunedNum);
      Serial.print("----------");
      closeCommand += connectionId;                       // append connection id
      closeCommand += "\r\n";
      sendData(closeCommand,                250, true);   // close connection
      //digitalWrite(retunedNum, !digitalRead(retunedNum));   // toggle pin
      if (retunedNum == 6894) {
        Serial.print("OFF");
        digitalWrite(ledDimmer, LOW);
      } else if (retunedNum == 6904) {
        Serial.print("ON");
        digitalWrite(ledDimmer, HIGH);
      } else if (retunedNum == 689) {
        digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(1000);              // wait for a second
        digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
  //============================================ End Loop WiFi Module ============================================
//                     [The data/command to send]
//                     |                  [The time to wait for a response]
//                     |                  |                [Print to Serial window (true = yes | false = no)]
//                     V                  V                V
String sendData(String command, const int timeout, boolean debug) {
  String response = "";
  long int time   = millis();
  esp8266.print(command);          // send the read character to the esp8266
  while((time + timeout) > millis()) {
    while(esp8266.available()) {
                                   // The esp has data so display its output to the serial window
        char c = esp8266.read();   // read the next character.
        response += c;
  if (debug) { Serial.print('Returned: ' + response); }
  return response;
And the console output is this:
14880AT+RST
OK
14880
"qXÑ{ÂB!É
1±þ)ÒBÙa
+ò“H!a5)�#)ÒÂia%YakN‘	J!ÐCÊ!�
÷þˆ2ô
ready
14880AT+CWJAP="xxxxxxwifi","xxxxxx123"
OK
14880AT+CIPMUX=1
OK
14880AT+UART_DEF=19200,8,1,0,0
OK
14880AT+CIPSTA_DEF="192.168.9.60","192.168.9.1","255.255.255.0"
OK
14880AT+CIPSERVER=1,80
OK
14880AT+GMR
AT version:0.22.0.0(Mar 20 2015 10:04:26)
SDK version:1.0.0
compile time:Mar 20 2015 11:00:56
OK
14880AT+CIFSR
+CIFSR:STAIP,"192.168.9.60"
+CIFSR:STAMAC,"18:fe:34:9b:4e:68"
OK
returned: 689----------148804 HTTP/1.1
Host: 192.168.9.60
Connection: AT+CIPCLOSE=0
0,CLOSED
OK
What I really am wanting to do is have a way to send a 10 charater string to the arduino instead of the limited 3 numbers above. I just am not sure what i need to add/modify in order to make it see letters/numbers and only the first 10 that i send.
Any help would be great!
Hey Stealth,
I have a similar project where I want to turn on/off 12 LEDs attached to my Arduino Uno, by reading a string of 12 characters (0s or 1s for each LED). I see that you're turning the ESP into a server... my implementation unfortunately has to be a client that downloads the data (see http://coopx.org/esp8266.txt).
I'm not a programmer but I was able to download some code that let's me read the file from my server and print it to serial monitor, but I CANNOT for the life of me filter out the 12 characters.
Do you have any code or guidance that can help. I'd VERY MUCH appreciate it.
Thank you so much.
/Fred
See this thread for code and more info:
http://forum.arduino.cc/index.php?topic=353036.msg2433811
