Greetings.
I recently bought an Esp8266 grove wifi module to replace the current expensive Arduino official wifi shield.
I've tested the ESP8266 with this code using AT commands and it works fine.
Serial1.begin(115200);
while (Serial1.available()) {
Serial.write(Serial1.read());
while (Serial.available()) {
Serial1.write(Serial.read());
however when i used this library and code, i failed to get connected.
* @example ConnectWiFi.ino
* @brief The ConnectWiFi demo of library WeeESP8266.
* @author Wu Pengfei<pengfei.wu@itead.cc>
* @date 2015.03
* @par Copyright:
* Copyright (c) 2015 ITEAD Intelligent Systems Co., Ltd. \n\n
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version. \n\n
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#include "ESP8266.h"
#define SSID "FreeWifi"
#define PASSWORD "b1tchpl3AS3"
ESP8266 wifi(Serial1);
void setup(void)
Serial.print("setup begin\r\n");
Serial.print("FW Version: ");
Serial.println(wifi.getVersion().c_str());
if (wifi.setOprToStation()) {
Serial.print("to station ok\r\n");
Serial.print("to station err\r\n");
if (wifi.joinAP(SSID, PASSWORD)) {
Serial.print("Join AP success\r\n");
Serial.print("IP: ");
Serial.println(wifi.getLocalIP().c_str());
Serial.print("Join AP failure\r\n");
Serial.print("setup end\r\n");
void loop(void)
setup begin
FW Version:
to station err
Join AP failure
setup end
kindly advise where did i go wrong. I wired the EspRx to Mega Tx(pin 18) and ESpTx to megaRx(pin19)
