Hi friends,
I am interfacing esp8266 wifi module with arduino, using below cpde i am not able to toggle led, please can anybody have code for esp8266 to control led using html and using mobile tcp client app
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(2,3); // make RX Arduino line is pin 2, make TX Arduino line is pin 3.
// This means that you need to connect the TX line from the esp to the Arduino's pin 2
// and the RX line from the esp to the Arduino's pin 3
//here you do cross connection now in this code it able join two networks using tcp client.
esp8266.begin(9600); // your esp's baud rate might be different
pinMode(11,OUTPUT);
digitalWrite(11,LOW);
pinMode(12,OUTPUT);
digitalWrite(12,LOW);
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
sendData("AT+RST\r\n",2000,DEBUG);
sendData("AT+CWMODE=2\r\n",1000,DEBUG); // configure as access point
// delay(100);
sendData("AT+CWLAP\r\n",1000,DEBUG); // configure as access point
// delay(100);
sendData("AT+CWJAP=vajramuni,12121313\r\n",1000,DEBUG); // configure as access point
// delay(100);
sendData("AT+CIFSR\r\n",1000,DEBUG); // get ip address
// delay(100);
sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
// delay(100);
sendData("AT+CIPSERVER=1,8888\r\n",1000,DEBUG); // turn on server on port 80
if(esp8266.available()) // check if the esp is sending a message
if(esp8266.find("+IPD,"))
delay(1000); // wait for the serial buffer to fill up (read all the serial data)
// get the connection id so that we can then disconnect
int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
// the ASCII decimal value and 0 (the first decimal number) starts at 48
esp8266.find("pin="); // advance cursor to "pin="
int pinNumber = (esp8266.read()-48)*10; // get first number i.e. if the pin 13 then the 1st number is 1, then multiply to get 10
pinNumber += (esp8266.read()-48); // get second number, i.e. if the pin number is 13 then the 2nd number is 3, then add to the first number
digitalWrite(pinNumber, !digitalRead(pinNumber)); // toggle pin
// make close command
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId; // append connection id
closeCommand+="\r\n";
sendData(closeCommand,1000,DEBUG); // close connection
* Name: sendData
* Description: Function used to send data to ESP8266.
* Params: command - the data/command to send; timeout - the time to wait for a response; debug - print to Serial window?(true = yes, false = no)
* Returns: The response from the esp8266 (if there is a reponse)
String sendData(String command, const int timeout, boolean debug)
String response = "";
esp8266.print(command); // send the read character to the esp8266
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
For html i used this code
<html>
<head>
<title>ESP8266 LED Control</title>
</head>
<body>
<!-- in the <button> tags below the ID attribute is the value sent to the arduino -->
<button id="11" class="led">Toggle Pin 11</button> <!-- button for pin 11 -->
<button id="12" class="led">Toggle Pin 12</button> <!-- button for pin 12 -->
<button id="13" class="led">Toggle Pin 13</button> <!-- button for pin 13 -->
<script src="jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$(".led").click(function(){
var p = $(this).attr('id'); // get id value (i.e. pin13, pin12, or pin11)
// send HTTP GET request to the IP address with the parameter "pin" and value "p", then execute the function
$.get("http://192.168.4.1:80/", {pin:p}); // execute get request
</script>
</body>
</html>
