Previous sketches that I have used for the last few months no longer compile. I have tried on 3 different computers with the same exact result. Also, I did a complete uninstall/reinstall including deleting Arduino15.
Is anyone else having issues?
Post your code and a full description of your hardware and the poblem
What does "no longer compile" mean ?
What error messages do you get ?
Are you using the correct COM port ?
Can you compile a simple program such as the Blink example ?
What have you changed recently ?
Please note that I have compiled blink and more involved programs. They all compile fine until I use ESP8266 boards. Also these ESP8266 programs have been used for 8 months now without issue. Two days ago I tried uploading to another ESP8266 board but I couldn’t get the compile to work.
I have attempted this on two windows platforms and a macbook. All get the same result.
I have followed previous suggestions of completely reloading Arduino IDE and Arduino15 folder and I still get the same failed result.
Here is the error message:
Used: C:\Users\Joe\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi
compilation terminated.
Multiple libraries were found for “DHT.h”
Used: C:\Users\Joe\Documents\Arduino\libraries\DHT-sensor-library-master
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
My code (from others):
#include <ESP8266WiFi.h>
#include <DHT.h>
// WiFi parameters
const char* ssid = "ssid";
const char* password = "password";
// Pin
#define DHTPIN 2 //GPIO2 -> D4
// Use DHT11 sensor
#define DHTTYPE DHT11
WiFiServer server(86);
DHT dht(DHTPIN, DHTTYPE, 30);
delay(10);
// Init DHT
dht.begin();
// Connect to WiFi network
WiFi.mode(WIFI_STA);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
// Wait a bit between measurements.
delay(300);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float humid = dht.readHumidity();
// Read temperature as Celsius (the default)
float temp = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float fahr = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(humid) || isnan(temp) || isnan(fahr)) {
Serial.println("Failed to read from DHT sensor!");
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(fahr, humid);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(temp, humid, false);
Serial.print("Dew PointFast (°C): ");
float dPt = dewPointFast(temp, humid);
WiFiClient client = server.available();
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE html>");
client.println("<html xmlns='http://www.w3.org/1999/xhtml'>");
client.println("<head>\n<meta charset='UTF-8'>");
client.println("<title>ESP8266 & DHT11 Sensor</title>");
client.println("<link href='https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css' rel='stylesheet'>");
client.println("</head>\n<body>");
client.println("<div class='container'>");
client.println("<div class='panel panel-default' margin:15px>");
client.println("<div class='panel-heading'>");
client.println("<H2>ESP8266 & DHT11 Sensor</H2>");
client.println("<div class='panel-body' style='background-color: green'>");
client.println("<pre>");
client.print("Humidity (%) : ");
client.println(humid, 2);
client.print("Temperature (°C) : ");
client.println(temp, 2);
client.print("Temperature (°F) : ");
client.println((float)fahr, 2);
client.print("Heat Index : ");
client.print(hic);
client.print(" (°C) ");
client.print(hif);
client.println(" (°F)");
client.print("Dew PointFast (°C): ");
client.println(dPt);
client.println("</pre>");
client.println("</div>");
client.print("</body>\n</html>");
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double t = (a * celsius) / (b + celsius) + log(humidity*0.01);
double Td = (b * t) / (a - t);
return Td;
[code]
If you did Read this before posting a programming question then you did not follow the instructions about posting code.
Please edit your post and add code tags
Thank you
Is that the full error message ?
jlosurdo:
Here is the error message:Used: C:\Users\Joe\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi
compilation terminated.Multiple libraries were found for “DHT.h”
exit status 1
That’s just the useless fragment of the output that happened to be visible on the console window. We need the whole thing.
Please do this:
If the text exceeds the forum’s 9000 character limit, save it to a .txt file and post it as an attachment. If you click the “Reply” button here, you will see an “Attachments and other settings” link.
You are using /* and / in your code, but there is one / without closing */ in the middle of the code:
So whatever comes after is not taken into account by the compiler, and the blocks (including the loop) have no closing curly brackets, hence the compilation problems.
If you remove this /*, check the following curly brackets as there is one too much.
Arduino: 1.8.10 (Mac OS X), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Multiple libraries were found for "SoftwareSerial.h"
Used: /Users/joelosurdo/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/libraries/SoftwareSerial
Multiple libraries were found for "ESP8266wifi.h"
Used: /Users/joelosurdo/Documents/Arduino/libraries/ESP8266WiFi
fork/exec /Users/joelosurdo/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: no such file or directory
Error compiling for board Generic ESP8266 Module.
option enabled in File -> Preferences.
/code]
After numerous attempts of un-installing Arduino and libraries on 3 machines I am still getting this issue for multiple libraries only when I use an ESP8266 board.
I have twice now used term to scrub the directories. I have deleted Arduino15, library folders and I still am getting these compiler failures.
As I have mentioned before none of the programs are new, I have an automated chicken coop door that I just reprogrammed the photocell setting on Monday. But now for the last 3 days I cant compile successfully anywhere on any machine.
I am not a programmer but I did assembly language for commercial products in the 80s. I could easily be missing the obvious but I am seeking your help.
Did you fix the issue in reply #7 ?
The last error message was for this program by Raul Santos. I have leveraged his work for the chicken coop door sensor.
/* by Raul Santos */
#include <ESP8266wifi.h>
// Replace with your network credentials
const char* ssid = "ssid”;
const char* password = "password”;
// Set web server port number to 80
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output5State = "off";
String output4State = "off";
// Assign output variables to GPIO pins
const int output5 = 5;
const int output4 = 4;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
// Initialize the output variables as outputs
pinMode(output5, OUTPUT);
pinMode(output4, OUTPUT);
// Set outputs to LOW
digitalWrite(output5, LOW);
digitalWrite(output4, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
previousTime = currentTime;
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /5/on") >= 0) {
Serial.println("GPIO 5 on");
output5State = "on";
digitalWrite(output5, HIGH);
} else if (header.indexOf("GET /5/off") >= 0) {
Serial.println("GPIO 5 off");
} else if (header.indexOf("GET /4/on") >= 0) {
Serial.println("GPIO 4 on");
output4State = "on";
digitalWrite(output4, HIGH);
} else if (header.indexOf("GET /4/off") >= 0) {
Serial.println("GPIO 4 off");
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #77878A;}</style></head>");
// Web Page Heading
client.println("<body><h1>ESP8266 Web Server</h1>");
// Display current state, and ON/OFF buttons for GPIO 5
client.println("<p>GPIO 5 - State " + output5State + "</p>");
// If the output5State is off, it displays the ON button
if (output5State=="off") {
client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 4
client.println("<p>GPIO 4 - State " + output4State + "</p>");
// If the output4State is off, it displays the ON button
if (output4State=="off") {
client.println("<p><a href=\"/4/on\"><button class=\"button\">ON</button></a></p>");
client.println("<p><a href=\"/4/off\"><button class=\"button button2\">OFF</button></a></p>");
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
}/code]
“The last error message was for this program by Raul Santos. I have leveraged his work for the chicken coop door sensor.”
Just as an experiment I got that code to compile. Go to sketch > include library and see if you see ESP8266WiFi in the drop down list, and if so, click it to include it. When I did a whole lot of library includes were added at the top of the code, with the needed ones red high lighted. I removed the dark ones and the code compiled with a wemos board selected as the board. Below is what compiled.
#include <ESP8266WiFiMulti.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiServerSecure.h>
#include <WiFiUdp.h>
String header;
// Current time
// Previous time
Serial.print(".");
Serial.println("");
server.begin();
void loop(){
header += c;
client.println();
// Web Page Heading
client.println();
currentLine = "";
header = "";
client.stop();
Serial.println("");
As explained in another discussion, “ESP8266wifi.h != ESP8266WiFi.h”. Capitalize the W and the F in the coop code and see if it makes a difference.
Thanks for your reply. I had tried that and it didn't work.
Things I am investigating are:
So i used an old work computer that has IDE 1.8.6 on it and had the ESP WiFi library loaded. I turned airplane mode on to prevent any updates. I compiled the 2nd program I have in this subject posts.
IT COMPILED immediately!!!!! So I am convince something in the ESP8266 board file has become corrupted.
Has anyone else successfully compiled an ESP8266 12E with the updated board files? Before anyone asks I did load older board files on the 3 other machines I tried.
Do any of the example programs that do not use ESP8266WiFi.h compile and work?
"1. All programs I am referring to were moved to the cloud...doesnt make sense that this would matter because the App is resident on the HDD"
Well, maybe like me, the arduino IDE has no clue as to what/where "the cloud" is. Kind of like trying to call somebody without knowing their number.
All other programs that are not ESP8266 work.
“Has anyone else successfully compiled an ESP8266 12E with the updated board files?”
See if the below code will compile for you with a wifi board selected.
String header;
// Current time
// Previous time
Serial.print(".");
Serial.println("");
server.begin();
void loop(){
header += c;
client.println();
// Web Page Heading
client.println();
currentLine = "";
header = "";
client.stop();
Serial.println("");
