I have a set up using the ESP8266-01 + FTD232 which was working perfectly, then without warning I started to get the following error:
Arduino: 1.8.5 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Archiving built core (caching) in: C:\Users\***\AppData\Local\Temp\arduino_cache_264334\core\core_esp8266_esp8266_generic_CpuFrequency_80,ResetMethod_ck,CrystalFreq_26,FlashFreq_40,FlashMode_qio,FlashSize_512K0,led_2,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_115200_5bf1b45ea7a7f392dc7124516af61bc9.a
Sketch uses 259000 bytes (51%) of program storage space. Maximum is 499696 bytes.
Global variables use 33276 bytes (40%) of dynamic memory, leaving 48644 bytes for local variables. Maximum is 81920 bytes.
C:\Users\***\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd ck -cb 115200 -cp COM5 -ca 0x00000 -cf C:\Users\***\AppData\Local\Temp\arduino_build_548224/AP_Connect.ino.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM5
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
option enabled in File -> Preferences.
I have two ESP8266-01’s, both respond in the same way, although one of them, which I programmed as an AP earlier, is functioning as an AP, I just can’t re-flash it. I have tried AT+GMR in the IDE Monitor but get no response. I have tried dismantling the wiring and reconstructing several times so I’m pretty sure it’s not a bad connection, or incorrect wiring. I’m wondering if I have damaged the circuit boards, but I ca’t see how.
