Running Arduino 1.8.13 on Win10(64).
Compiling for LOLIN(WEMOS) D1 Mini Pro
Sketch will compile for Arduino Uno, but not for any ESP8266 board
I'm quite sure I have tested the SDWebServer.ino earlier.
All my ESP8266 libraryfiles are 3.0.2
I have taken the ESPWebServer/SDWebServer.ino at master · esp8266/ESPWebServer · GitHub
and stripped it down to these few lines:
#include <SPI.h>
#include <SD.h>
File uploadFile;
void setup(void) {
Serial.print("\n");
if (SD.begin(SS)) {
Serial.println("SD Card initialized.");
void loop(void) {
Error messages:
Arduino: 1.8.13 (Windows 10), Board: "LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
In file included from C:\Myprogs\Arduino\Source\libraries\SdFat/iostream.h:27,
from C:\Myprogs\Arduino\Source\libraries\SdFat/SdStream.h:27,
from C:\Myprogs\Arduino\Source\libraries\SdFat/SdFat.h:36,
from C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:36,
from C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:25,
from C:\Myprogs\Arduino\Source\ESP8266\Testb\Testb.ino:3:
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h: In member function 'ostream& ostream::operator<<(long int)':
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h:178:15: error: call of overloaded 'putNum(long int&)' is ambiguous
178 | putNum(arg);
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h:282:8: note: candidate: 'void ostream::putNum(uint32_t, bool)'
282 | void putNum(uint32_t n, bool neg = false);
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h:283:8: note: candidate: 'void ostream::putNum(int32_t)'
283 | void putNum(int32_t n);
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h: In member function 'ostream& ostream::operator<<(long unsigned int)':
C:\Myprogs\Arduino\Source\libraries\SdFat/ostream.h:186:15: error: call of overloaded 'putNum(long unsigned int&)' is ambiguous
186 | putNum(arg);
In file included from C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:25,
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: At global scope:
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:50:50: error: 'SD_SCK_MHZ' was not declared in this scope
50 | SDFSConfig(uint8_t csPin = 4, uint32_t spi = SD_SCK_MHZ(10)) : FSConfig(FSId, false), _csPin(csPin), _part(0), _spiSettings(spi) { }
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:232:5: error: 'sdfat' does not name a type
232 | sdfat::SdFat* getFs()
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:258:5: error: 'sdfat' does not name a type
258 | sdfat::SdFat _fs;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::exists(const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:85:27: error: '_fs' was not declared in this scope; did you mean 'fs'?
85 | return _mounted ? _fs.exists(path) : false;
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::rename(const char*, const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:91:27: error: '_fs' was not declared in this scope; did you mean 'fs'?
91 | return _mounted ? _fs.rename(pathFrom, pathTo) : false;
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::info64(fs::FSInfo64&)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:100:26: error: '_fs' was not declared in this scope; did you mean 'fs'?
100 | info.blockSize = _fs.vol()->sectorsPerCluster() * _fs.vol()->bytesPerSector();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::remove(const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:129:27: error: '_fs' was not declared in this scope; did you mean 'fs'?
129 | return _mounted ? _fs.remove(path) : false;
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::mkdir(const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:133:27: error: '_fs' was not declared in this scope; did you mean 'fs'?
133 | return _mounted ? _fs.mkdir(path) : false;
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::rmdir(const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:137:26: error: '_fs' was not declared in this scope; did you mean 'fs'?
137 | return _mounted ?_fs.rmdir(path) : false;
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSImpl::begin()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:154:20: error: '_fs' was not declared in this scope; did you mean 'fs'?
154 | _mounted = _fs.begin(_cfg._csPin, _cfg._spiSettings);
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:159:2: error: 'sdfat' has not been declared
159 | sdfat::FsDateTime::setCallback(dateTimeCB);
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'uint8_t sdfs::SDFSImpl::type()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:173:16: error: '_fs' was not declared in this scope; did you mean 'fs'?
173 | return _fs.card()->type();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'uint8_t sdfs::SDFSImpl::fatType()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:176:16: error: '_fs' was not declared in this scope; did you mean 'fs'?
176 | return _fs.vol()->fatType();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'size_t sdfs::SDFSImpl::blocksPerCluster()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:179:16: error: '_fs' was not declared in this scope; did you mean 'fs'?
179 | return _fs.vol()->sectorsPerCluster();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'size_t sdfs::SDFSImpl::totalClusters()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:182:16: error: '_fs' was not declared in this scope; did you mean 'fs'?
182 | return _fs.vol()->clusterCount();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'size_t sdfs::SDFSImpl::clusterSize()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:188:37: error: '_fs' was not declared in this scope; did you mean 'fs'?
188 | return blocksPerCluster() * _fs.vol()->bytesPerSector();
| fs
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In static member function 'static uint8_t sdfs::SDFSImpl::_getFlags(fs::OpenMode, fs::AccessMode)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:241:21: error: 'sdfat' has not been declared
241 | mode |= sdfat::O_CREAT;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:244:21: error: 'sdfat' has not been declared
244 | mode |= sdfat::O_AT_END;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:247:21: error: 'sdfat' has not been declared
247 | mode |= sdfat::O_TRUNC;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:250:21: error: 'sdfat' has not been declared
250 | mode |= sdfat::O_READ;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:253:21: error: 'sdfat' has not been declared
253 | mode |= sdfat::O_WRITE;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:267:48: error: 'sdfat' was not declared in this scope
267 | SDFSFileImpl(SDFSImpl *fs, std::shared_ptr<sdfat::File32> fd, const char *name)
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:267:61: error: template argument 1 is invalid
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:267:32: error: invalid template-id
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:267:48: error: 'sdfat' has not been declared
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:267:32: error: 'auto' parameter not permitted in this context
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:404:21: error: 'sdfat' was not declared in this scope
404 | std::shared_ptr<sdfat::File32> _fd;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:404:34: error: template argument 1 is invalid
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In constructor 'sdfs::SDFSFileImpl::SDFSFileImpl(sdfs::SDFSImpl*, const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:268:24: error: 'fd' was not declared in this scope; did you mean '_fd'?
268 | : _fs(fs), _fd(fd), _opened(true)
| _fd
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual int sdfs::SDFSFileImpl::availableForWrite()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:282:29: error: base operand of '->' is not a pointer
282 | return _opened ? _fd->availableSpaceForWrite() : 0;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual size_t sdfs::SDFSFileImpl::write(const uint8_t*, size_t)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:287:29: error: base operand of '->' is not a pointer
287 | return _opened ? _fd->write(buf, size) : -1;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual int sdfs::SDFSFileImpl::read(uint8_t*, size_t)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:292:29: error: base operand of '->' is not a pointer
292 | return _opened ? _fd->read(buf, size) : -1;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual void sdfs::SDFSFileImpl::flush()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:298:16: error: base operand of '->' is not a pointer
298 | _fd->sync();
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSFileImpl::seek(uint32_t, fs::SeekMode)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:309:27: error: base operand of '->' is not a pointer
309 | return _fd->seekSet(pos);
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:311:27: error: base operand of '->' is not a pointer
311 | return _fd->seekEnd(-pos); // TODO again, odd from POSIX
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:313:27: error: base operand of '->' is not a pointer
313 | return _fd->seekCur(pos);
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual size_t sdfs::SDFSFileImpl::position() const':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:324:29: error: base operand of '->' is not a pointer
324 | return _opened ? _fd->curPosition() : 0;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual size_t sdfs::SDFSFileImpl::size() const':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:329:29: error: base operand of '->' is not a pointer
329 | return _opened ? _fd->fileSize() : 0;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSFileImpl::truncate(uint32_t)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:338:19: error: base operand of '->' is not a pointer
338 | return _fd->truncate(size);
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual void sdfs::SDFSFileImpl::close()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:344:16: error: base operand of '->' is not a pointer
344 | _fd->close();
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSFileImpl::isFile() const':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:372:29: error: base operand of '->' is not a pointer
372 | return _opened ? _fd->isFile() : false;;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSFileImpl::isDirectory() const':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:377:29: error: base operand of '->' is not a pointer
377 | return _opened ? _fd->isDir() : false;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual time_t sdfs::SDFSFileImpl::getLastWrite()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:383:13: error: 'sdfat' has not been declared
383 | sdfat::DirFat_t tmp;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:384:21: error: request for member 'get' in '((sdfs::SDFSFileImpl*)this)->sdfs::SDFSFileImpl::_fd', which is of non-class type 'int'
384 | if (_fd.get()->dirEntry(&tmp)) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:384:38: error: 'tmp' was not declared in this scope; did you mean 'tm'?
| tm
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual time_t sdfs::SDFSFileImpl::getCreationTime()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:394:13: error: 'sdfat' has not been declared
394 | sdfat::DirFat_t tmp;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:395:21: error: request for member 'get' in '((sdfs::SDFSFileImpl*)this)->sdfs::SDFSFileImpl::_fd', which is of non-class type 'int'
395 | if (_fd.get()->dirEntry(&tmp)) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:395:38: error: 'tmp' was not declared in this scope; did you mean 'tm'?
| tm
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:412:70: error: 'sdfat' was not declared in this scope
412 | SDFSDirImpl(const String& pattern, SDFSImpl* fs, std::shared_ptr<sdfat::File32> dir, const char *dirPath = nullptr)
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:412:83: error: template argument 1 is invalid
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:412:54: error: invalid template-id
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:412:70: error: 'sdfat' has not been declared
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:412:54: error: 'auto' parameter not permitted in this context
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:521:21: error: 'sdfat' was not declared in this scope
521 | std::shared_ptr<sdfat::File32> _dir;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:521:34: error: template argument 1 is invalid
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In constructor 'sdfs::SDFSDirImpl::SDFSDirImpl(const String&, sdfs::SDFSImpl*, const char*)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:413:44: error: 'dir' was not declared in this scope; did you mean '_dir'?
413 | : _pattern(pattern), _fs(fs), _dir(dir), _valid(false), _dirPath(nullptr)
| _dir
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In destructor 'virtual sdfs::SDFSDirImpl::~SDFSDirImpl()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:423:13: error: base operand of '->' is not a pointer
423 | _dir->close();
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSDirImpl::next()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:487:13: error: 'sdfat' has not been declared
487 | sdfat::File32 file;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:488:13: error: 'file' was not declared in this scope
488 | file.openNext(_dir.get(), sdfat::O_READ);
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:488:32: error: request for member 'get' in '((sdfs::SDFSDirImpl*)this)->sdfs::SDFSDirImpl::_dir', which is of non-class type 'int'
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:488:39: error: 'sdfat' has not been declared
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:494:17: error: 'sdfat' has not been declared
494 | sdfat::DirFat_t tmp;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:495:36: error: 'tmp' was not declared in this scope; did you mean 'tm'?
495 | if (file.dirEntry(&tmp)) {
| tm
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h: In member function 'virtual bool sdfs::SDFSDirImpl::rewind()':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SDFS\src/SDFS.h:514:13: error: base operand of '->' is not a pointer
514 | _dir->rewind();
In file included from C:\Myprogs\Arduino\Source\ESP8266\Testb\Testb.ino:3:
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h: At global scope:
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:28:19: error: 'sdfat' has not been declared
28 | #define FILE_READ sdfat::O_READ
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:47:52: note: in expansion of macro 'FILE_READ'
47 | File open(const char *filename, uint8_t mode = FILE_READ) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:55:54: note: in expansion of macro 'FILE_READ'
55 | File open(const String &filename, uint8_t mode = FILE_READ) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h: In member function 'const char* SDClass::getMode(uint8_t)':
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:162:29: error: 'sdfat' has not been declared
162 | bool read = (mode & sdfat::O_READ) ? true : false;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:163:30: error: 'sdfat' has not been declared
163 | bool write = (mode & sdfat::O_WRITE) ? true : false;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:164:31: error: 'sdfat' has not been declared
164 | bool append = (mode & sdfat::O_APPEND) ? true : false;
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:187:24: error: redefinition of 'uint16_t FAT_DATE(uint16_t, uint8_t, uint8_t)'
187 | static inline uint16_t FAT_DATE(uint16_t year, uint8_t month, uint8_t day) {
In file included from C:\Myprogs\Arduino\Source\libraries\SdFat/SdFile.h:24,
from C:\Myprogs\Arduino\Source\libraries\SdFat/SdFat.h:35,
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:131:24: note: 'uint16_t FAT_DATE(uint16_t, uint8_t, uint8_t)' previously defined here
131 | static inline uint16_t FAT_DATE(uint16_t year, uint8_t month, uint8_t day) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:190:24: error: redefinition of 'uint16_t FAT_YEAR(uint16_t)'
190 | static inline uint16_t FAT_YEAR(uint16_t fatDate) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:139:24: note: 'uint16_t FAT_YEAR(uint16_t)' previously defined here
139 | static inline uint16_t FAT_YEAR(uint16_t fatDate) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:193:23: error: redefinition of 'uint8_t FAT_MONTH(uint16_t)'
193 | static inline uint8_t FAT_MONTH(uint16_t fatDate) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:147:23: note: 'uint8_t FAT_MONTH(uint16_t)' previously defined here
147 | static inline uint8_t FAT_MONTH(uint16_t fatDate) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:196:23: error: redefinition of 'uint8_t FAT_DAY(uint16_t)'
196 | static inline uint8_t FAT_DAY(uint16_t fatDate) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:155:23: note: 'uint8_t FAT_DAY(uint16_t)' previously defined here
155 | static inline uint8_t FAT_DAY(uint16_t fatDate) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:199:24: error: redefinition of 'uint16_t FAT_TIME(uint8_t, uint8_t, uint8_t)'
199 | static inline uint16_t FAT_TIME(uint8_t hour, uint8_t minute, uint8_t second) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:165:24: note: 'uint16_t FAT_TIME(uint8_t, uint8_t, uint8_t)' previously defined here
165 | static inline uint16_t FAT_TIME(uint8_t hour, uint8_t minute, uint8_t second) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:202:23: error: redefinition of 'uint8_t FAT_HOUR(uint16_t)'
202 | static inline uint8_t FAT_HOUR(uint16_t fatTime) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:173:23: note: 'uint8_t FAT_HOUR(uint16_t)' previously defined here
173 | static inline uint8_t FAT_HOUR(uint16_t fatTime) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:205:23: error: redefinition of 'uint8_t FAT_MINUTE(uint16_t)'
205 | static inline uint8_t FAT_MINUTE(uint16_t fatTime) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:181:23: note: 'uint8_t FAT_MINUTE(uint16_t)' previously defined here
181 | static inline uint8_t FAT_MINUTE(uint16_t fatTime) {
C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD\src/SD.h:208:23: error: redefinition of 'uint8_t FAT_SECOND(uint16_t)'
208 | static inline uint8_t FAT_SECOND(uint16_t fatTime) {
C:\Myprogs\Arduino\Source\libraries\SdFat/SdBaseFile.h:191:23: note: 'uint8_t FAT_SECOND(uint16_t)' previously defined here
191 | static inline uint8_t FAT_SECOND(uint16_t fatTime) {
Multiple libraries were found for "SD.h"
Used: C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Not used: C:\Myprogs\Arduino\Source\libraries\SD
Multiple libraries were found for "SdFat.h"
Used: C:\Myprogs\Arduino\Source\libraries\SdFat
Not used: C:\Users\Flemming\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266SdFat
exit status 1
Error compiling for board LOLIN(WEMOS) D1 mini Pro.
option enabled in File -> Preferences.
