ESP8266 - Writing on SD has timestamp w/o timelib
I came across a strange effect: If I connect my esp8266 to WiFi, next SD write operation gives an actual timestamp without any setTime operations in my code.
How does it come? I could not find any documentation about it.
Does this mean, that I have access to actual time information just by connecting to WiFi and without implementing any NTP stuff?
Uli
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <SPI.h>
#include <SD.h>
char dataBlock[100];
// WiFi connection
const char* ssid = "SSID";
const char* password = "PASS";
void WiFiStart();
// the setup routine
  // start serial
  //Serial.printf("Size %d\n",sizeof(struct_alles));
  Serial.println("Timestamp - Test");
  Serial.println("Build: " __TIME__ "  " __DATE__ );
  Serial.println(__FILE__);
  Serial.print("Initializing SD-Card...");
  if(!SD.begin(16))
    Serial.println("ERROR !!");
    Serial.println("OK.");
  write_FS("After_SD_Begin");
   // inital connect
  WiFi.mode(WIFI_STA);
  WiFi.hostname("Timestamp");
  WiFiStart();
  write_FS("After_WiFiStart");
void write_FS(String FileName)
   File mySDFile = SD.open(FileName,FILE_WRITE);
   if (!mySDFile)
      Serial.println(F("ERROR opening file on SD-card for writing!"));
      mySDFile.seek(0);
      mySDFile.write(dataBlock,sizeof(dataBlock));
      Serial.println(F("File written on SD-Card."));
      mySDFile.close();
// (re-)start WiFi
void WiFiStart()
  // Connect to WiFi network
  Serial.printf("Connecting to %s\n",ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.printf("\nWiFi connected\n");
  // Print the IP address
void  loop()
Network Time Protocol (NTP), the same way your PC keeps your system time synced to real-time.
I guess it's NTP, but I never read that this is implemented somewhere hidden in the WiFi library.
I had some projects with need for actual time and I always had to use WiFiUdp.h and include the NTP code.
Does WiFi update the system time like setting it with setTime() ?
I think it has to do with this line in SDFS.h:
sdfat::FsDateTime::setCallback(dateTimeCB);
FS.h and SDFS.h are included in SD.h
it seems that SDFS.h uses the ESP core function to get time.
Basically NTP is part of the ESP core already and for usual you don't need any self written UDP requests for NTP on the ESP.
Example: NTP for the ESP8266 including day light saving time (DST) without 3rd party library
Thanks for the explanation. I did not expect the platform to start external communication without explicit order to do so.
