Salve a tutti, ho collegato esp8266 secondo cio’ che c’è scritto nel codice che ho scaricato da internet, mettendo ovviamente nome della rete e password che ora ho cancellato (non capisco perchè mi chiede due volte SSID e PASSWORD), mi si accende un solo led sul modulo wifii e non vedo lampeggiare l’altro, poi ho impostato il Baud a 19200 ed entrambi (NL e CR) e quando apro il monitor seriale mi dice:
AT + RST
module have no response
Begin error
Init error.
qualcuno potrebbe aiutarmi?
Grazie in anticipo
ESP8266 library
Connection:
When you use it with UNO board, the connection should be like these:
ESP8266_TX->RX(D10)
ESP8266_RX->TX(D11)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you want to output the debug information, please use DebugSerial. For example,
DebugSerial.println("hello");
Note: The size of message from ESP8266 is too big for arduino sometimes, so the library can't receive the whole buffer because
the size of the hardware serial buffer which is defined in HardwareSerial.h is too small.
Open the file from \arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h.
See the follow line in the HardwareSerial.h file.
#define SERIAL_BUFFER_SIZE 64
The default size of the buffer is 64. Change it into a bigger number, like 256 or more.
//#define SSID ""
//#define PASSWORD ""
#define SSID ""
#define PASSWORD ""
#include "uartWIFIUNO.h"
#include <SoftwareSerial.h>
WIFIUNO wifi;
extern int chlID;
// set pin numbers:
const int ledPin = 13; // the number of the LED pin
const int relay1 = 2;
const int relay2 = 3;
const int relay3 = 4;
const int relay4 = 5;
boolean device1 = false;
boolean device2 = false;
boolean device3 = false;
boolean device4 = false;
void setup(){
pinMode(ledPin, OUTPUT);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
//pinMode(ESP8266_CHPD, OUTPUT);
//digitalWrite(ESP8266_CHPD,LOW);
digitalWrite(relay1,LOW);
digitalWrite(relay2,LOW);
digitalWrite(relay3,LOW);
digitalWrite(relay4,LOW);
DebugSerial.println("ESP8266 Server v0.21");
if(!wifi.begin())
DebugSerial.println("Begin error");
bool b = wifi.Initialize(STA, SSID, PASSWORD);
if(!b)
DebugSerial.println("Init error");
delay(8000); //make sure the module can have enough time to get an IP address
String ipstring = wifi.showIP();
DebugSerial.println(ipstring); //show the ip address of module
wifi.confMux(1);
delay(100);
if(wifi.confServer(1,80))
DebugSerial.println("Server is set up");
char buf[500];
int iLen = wifi.ReceiveMessage(buf);
if(iLen > 0)
DebugSerial.print(buf);
//delay(300);
if (strncmp(buf, "GET /?status1=1", 15) == 0) {
//DebugSerial.print("RELAY 1 ON");
digitalWrite(relay1, HIGH);
device1 = true;
else if (strncmp(buf, "GET /?status1=0", 15) == 0) {
//DebugSerial.print("RELAY 1 OFF");
digitalWrite(relay1, LOW);
device1 = false;
if (strncmp(buf, "GET /?status2=1", 15) == 0) {
//DebugSerial.print("RELAY 2 ON");
digitalWrite(relay2, HIGH);
device2 = true;
else if (strncmp(buf, "GET /?status2=0", 15) == 0) {
//DebugSerial.print("RELAY 2 OFF");
digitalWrite(relay2, LOW);
device2 = false;
String cmd;
cmd = "HTTP/1.1 200 OK\r\n";
cmd += "Content-Type: text/html\r\n";
cmd += "Connection: close\r\n";
//cmd += "Refresh: 15\r\n";
cmd += "\r\n";
//cmd += "<!DOCTYPE HTML>\r\n";
cmd += "<html>\r\n";
//cmd += "<header><title>ESP8266 Webserver</title><h1>\"ESP8266 Web Server Control\"</h1></header>";
if(device1){
cmd +=("
Device1 : ON");
else{
cmd +=("
Device1 : OFF");
if(device2){
cmd +=("
Device2 : ON");
else{
cmd +=("
Device2 : OFF");
if(device3){
cmd +=("
Device3 : ON");
else{
cmd +=("
Device3 : OFF");
if(device4){
cmd +=("
Device4 : ON");
else{
cmd +=("
Device4 : OFF");
wifi.Send(chlID,cmd);
//delay(200);
wifi.closeMux(chlID);
//delay(1000);
