Good,
I am using the ESP8266httpUpdate library with the php example to communicate with the server and if the .bin file has a different md5, install the new .bin.
I can't get it to work, in arduino the serial monitor I get:
I get HTTP_UPDATE_FAILD Error (-104): Wrong HTTP Code
13: 04: 55.613 -> CALLBACK: HTTP update fatal error code -104
This is my PHP code:
<?PHP
header('Content-type: text/plain; charset=utf8', true);
function check_header($name, $value = false) {
if(!isset($_SERVER[$name])) {
return false;
if($value && $_SERVER[$name] != $value) {
return false;
return true;
function sendFile($path) {
header($_SERVER["SERVER_PROTOCOL"].' 200 OK', true, 200);
header('Content-Type: application/octet-stream', true);
header('Content-Disposition: attachment; filename='.basename($path));
header('Content-Length: '.filesize($path), true);
header('x-MD5: '.md5_file($path), true);
readfile($path);
if(
!check_header('HTTP_X_ESP8266_STA_MAC') ||
!check_header('HTTP_X_ESP8266_AP_MAC') ||
!check_header('HTTP_X_ESP8266_FREE_SPACE') ||
!check_header('HTTP_X_ESP8266_SKETCH_SIZE') ||
!check_header('HTTP_X_ESP8266_SKETCH_MD5') ||
!check_header('HTTP_X_ESP8266_CHIP_SIZE') ||
!check_header('HTTP_X_ESP8266_SDK_VERSION')
header($_SERVER["SERVER_PROTOCOL"].' 403 Forbidden', true, 403);
echo "only for ESP8266 updater! (header)\n";
exit();
$localBinary = "/var/www/vhosts/domain.com/httpdocs/folder/arduino.bin";
// Check if version has been set and does not match, if not, check if
// MD5 hash between local binary and ESP8266 binary do not match if not.
// then no update has been found.
if(($_SERVER["HTTP_X_ESP8266_SKETCH_MD5"] != md5_file($localBinary)) {
sendFile($localBinary)
header($_SERVER["SERVER_PROTOCOL"].' 304 Not Modified', true, 304);
Maybe the problem is in the path of the localBinary .bin file, but I don't know how to solve it.
Thanks a lot
EDIT: acces_log file:
[`14/Aug/2021:13:16:14 +0200] "GET /folder/arduino_check_updates.php HTTP/1.0" 500 177 "-" "ESP8266-http-Update"`
