ESP8266HTTPUpdateServer taking only 'const char *' correctly as argument
I am a little stumped here, in trying to create a webbrowser update for my esp boards i ran into something.
When i use the 'SecureWebUpdater.ino'
  To upload through terminal you can use: curl -u admin:admin -F "image=@firmware.bin" esp8266-webupdate.local/firmware
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
const char* host = "esp8266-webupdate";
const char* update_path = "/firmware";
const char* update_username = "admin";
const char* update_password = "admin";
const char* ssid = "...";
const char* password = ".......";
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
void setup(void) {
  Serial.println("Booting Sketch...");
  WiFi.mode(WIFI_AP_STA);
  WiFi.begin(ssid, password);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi failed, retrying.");
  MDNS.begin(host);
  httpUpdater.setup(&httpServer, update_path, update_username, update_password);
  httpServer.begin();
  MDNS.addService("http", "tcp", 80);
  Serial.printf("HTTPUpdateServer ready! Open http://%s.local%s in your browser and login with username '%s' and password '%s'\n", host, update_path, update_username, update_password);
void loop(void) {
  httpServer.handleClient();
it all works perfectly and when i go to the webpage i get the requestAuthentication() and when i enter the standard credentials (eg "admin" & "admin" ) i get to the page. Great, just what i needed, except that i want to use my unit specific password, which i have implemented within the same sketch, using the same requestAuthentication() from ArduinoOTA, where it works just fine, i can create user accounts with their own password and set permissions for parts of the webpage. But somehow the moment i pass a variable (char array) to httpUpdater.setup(&httpServer, update_path, update_username, update_password); instead of the const char * it somehow doesn't accept my credentials anymore and gets stuck in this loop (from ESP8266HTTPUpdateServer-impl.h)
void ESP8266HTTPUpdateServerTemplate<ServerType>::setup(ESP8266WebServerTemplate<ServerType> *server, const String& path, const String& username, const String& password)
    _server = server;
    _username = username;
    _password = password;
    // handler for the /update form page
    _server->on(path.c_str(), HTTP_GET, [&](){
      if(_username != emptyString && _password != emptyString && !_server->authenticate(_username.c_str(), _password.c_str()))
        return _server->requestAuthentication();
      _server->send_P(200, PSTR("text/html"), serverIndex);
Now i suspect that it is caused by the type of the argument requested (const String&) and the conversion back to c-string, but i don't know hay !?
authenticate(_username.c_str(), _password.c_str()takes char * (char arrays) which is what i am originally providing. Anybody have a clue on how to solve this riddle ?
Oh man, it took me 2 hours of looking and trying, and i post this topic, get up from my chair, take a few steps and think "Maybe it goes out of scope ?" and so i move the declaration for the char array i am passing as the argument for the password , to my global variables (rather than the local where i would normally put it) and bam ! now it does work.
Okay, just one more time and see if i can explain it a little clearer[code
void setup(void) {
httpServer.begin();
void loop(void) {
}[/code]This is from the original code (that works) i can log in admin, admin. If i just dohttpUpdater.setup(&httpServer, update_path, "username", "password"); i can login (username, password.) but if i do
String password = PasswordGenarator();
char pw[password.length()+1];
password.toCharArray(pw, password.length()+1);
httpUpdater.setup(&httpServer, update_path, "username", password);
login fails, but when i globally declare char pw[7];  // i do know the length of the password, but if i would create a bigger buffer i doubt it would matter Then i can login ! What happens to the pointer ? it is the only function relating to the ArduinoOTA so far where i have this issue, what happens in this callback function
void ESP8266HTTPUpdateServer::setup(ESP8266WebServer *server, const char * path, const char * username, const char * password)
    _server = server;
    _username = (char *)username;
    _password = (char *)password;
    _server->on(path, HTTP_GET, [&](){
      if(_username != NULL && _password != NULL && !_server->authenticate(_username, _password))
(from ESP8266HTTPUpdateServer.cpp) that make '_password' not point to the 'char pw[]' anymore ? I mean i got a fix, but what is going on ?
