[ESP8266Was soll das sein?
Fehlermeldung unverständlich (mein englisch reicht hier nicht (vor allem: vor wenigen Schritten ging es noch)):
Hier: >>>
das:
expected primary-expression before ')' token
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266mDNS.h>
#include <ESP8266WebServer.h> // Include the WebServer library
ESP8266WiFiMulti wifiMulti; // Create an instance of the ESP8266WiFiMulti class, called 'wifiMulti'
ESP8266WebServer server(80); // Create a webserver object that listens for HTTP request on port 80
void handleRoot(); // function prototypes for HTTP handlers
void handleNotFound();
void setup(void){
pinMode(4, OUTPUT);
pinMode(LED_BUILTIN,OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(4,LOW);
Serial.begin(115200); // Start the Serial communication to send messages to the computer
delay(10);
Serial.println('\n');
wifiMulti.addAP("Rx5dsT", "Eqb73nDfmPasWcCgqz81XtHReyuB"); // add Wi-Fi networks you want to connect to
Serial.println("Connecting ...");
int i = 0;
while (wifiMulti.run() != WL_CONNECTED) { // Wait for the Wi-Fi to connect: scan for Wi-Fi networks, and connect to the strongest of the networks above
delay(250);
Serial.print('.');
Serial.print("Connected to ");
Serial.println(WiFi.SSID()); // Tell us what network we're connected to
Serial.print("IP address:\t");
Serial.println(WiFi.localIP()); // Send the IP address of the ESP8266 to the computer
if (MDNS.begin("esp8266")) { // Start the mDNS responder for esp8266.local
Serial.println("mDNS responder started");
Serial.println("Error setting up MDNS responder!");
server.on("/", handleRoot); // Call the 'handleRoot' function when a client requests URI "/"
server.onNotFound(handleNotFound); // When a client requests an unknown URI (i.e. something other than "/"), call function "handleNotFound"
server.begin(); // Actually start the server#ff^
Serial.println("HTTP server started");
void loop(void){
server.handleClient(); // Listen for HTTP requests from clients
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000);
void handleRoot() {
server.send(200, "text/plain", "Hello world!"); // Send HTTP status 200 (Ok) and send some text to the browser/client
digitalWrite(4,HIGH);
delay(4000);
digitalWrite(4, LOW);
void handleNotFound(){
server.send(404, "text/plain", "404: Not found"); // Send HTTP status 404 (Not Found) when there's no handler for the URI in the request
Please excuse the german. But if english isnn't working until now it is no more working further
greeting
Manni
Hi Mani,
What do you think this is doing:
Please can you post your code in code tags </> so it is properly formatted?
Thanks
Hier: >>>
das:
void setup(void){
  pinMode(4, OUTPUT);
  delay(10);
  int i = 0;
networks above
    delay(250);
    Serial.print('.');
"handleNotFound"
void loop(void){
  delay(2000);
void handleRoot() {
  delay(4000);
greeting
Manni
Add: I found out what this was. An expression after the last bracket!
So Please be patient with me and ignore this.
greeting
Manni
Note: Every forum is different and so I had a lot of problems here at the beginning (the code brackets I just found ). Some problems will still be there.
