ESP8266WiFi.h: No such file or directory
Hi, I am currently trying to connect my Arduino UNO + ESP8266 WiFi Shield to Firebase database. My WiFi shield is in UNO form, hence it is stacked on top of my Arduino UNO. However, when I upload my coding, an error keeps appearing which is :
Below is my coding. Is there anything wrong with my coding/libraries? because I followed and installed all the libraries from this tutorial https://electropeak.com/learn/connect-arduino-esp8266-firebase-send-receive-data/amp/
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "example.firebaseio.com"
#define FIREBASE_AUTH "token_or_secret"
#define WIFI_SSID "SSID"
#define WIFI_PASSWORD "PASSWORD"
  // connect to wifi.
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
    Serial.print(".");
  Serial.print("connected: ");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
int n = 0;
  // set value
  Firebase.setFloat("number", 42.0);
  // handle error
  if (Firebase.failed()) {
      Serial.print("setting /number failed:");
      Serial.println(Firebase.error());
      return;
  // update value
  Firebase.setFloat("number", 43.0);
  // handle error
      return;
  // get value
  Serial.print("number: ");
  Serial.println(Firebase.getFloat("number"));
  // remove value
  Firebase.remove("number");
  // set string value
  Firebase.setString("message", "hello world");
  // handle error
      Serial.print("setting /message failed:");
      return;
  // set bool value
  Firebase.setBool("truth", false);
  // handle error
      Serial.print("setting /truth failed:");
      return;
  // append a new value to /logs
  String name = Firebase.pushInt("logs", n++);
  // handle error
      Serial.print("pushing /logs failed:");
      return;
  Serial.print("pushed: /logs/");
  Serial.println(name);
Exactly where on your PC is ESP8266WiFi.h ?
Tried run it again just now, and this new error message appears.
FirebaseRoom_ESP8266:1:10: fatal error: C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/ESP8266WiFi.h": Invalid argument
#include <ESP8266WiFi.h">
compilation terminated.
exit status 1
izzatazman9595:
So the complier it telling you with the second problems that there is some problem with that line of code.
How does that line compare with the same line of code in the first program ?
srnet:
How does that line compare with the same line of code in the first program?
Both <ESP8266WiFi.h"> and <ESP8266WiFi.h> gave same error message. Do
FirebaseRoom_ESP8266:1:10: fatal error: ESP8266WiFi.h: No such file or directory
exit status 1
Do the errors have something to do with the libraries? Do I need to make sure there is ESP8266WiFi.h file in a certain folder? Because I just install the libraries using Add Zip file in IDE
In the IDE, if you do Sketch->Include Library can you select the files that the compiler is complaining that it cannot find ?
Just checked all the libraries, and it seems that there is no ESP8266WiFi.h file. Not sure when I can find this file since I've installed all the zip files. U have any idea when I can get and install the required library?
I assume that you have asked "Mr Google"
izzatazman9595:
Both give an error but its not the same error, is it ?
and
