ESP8285 Stuck on Wi-Fi Connect
Hi everyone,
I'm working on a project using an Arduino Uno to control an ESP8285 module (running AT firmware) for MQTT.
I am completely stuck on the very first step: The ESP8285 will not connect to my Wi-Fi network.
The module is silent and times out after sending the connection command.
My Setup & Problem
• Module: ESP8285 with AT Firmware (controlled by Arduino Uno). Fails to connect.
• Command: AT+CWJAP="SIDD","Pass"
• Result: Returns Timeout (no OK or FAIL response).
• Communication: Hardware Serial (Pins 0/1) set to 9600 baud. Confirmed stable and reliable.
• Power: Dedicated external 3.3V supply used. Confirmed stable (ruled out the main cause).
// --- Global Configuration ---
// Using Hardware Serial (Pins 0 and 1) for ESP8285 communication (Most reliable)
#define ESP_SERIAL Serial
#define DEBUG_SERIAL Serial
const int LED_PIN = LED_BUILTIN; // Pin 13 on Arduino Uno for visual status
// Global flag to track connection status
bool isConnected = false;
// Network Credentials (Check these CAREFULLY for typos and case-sensitivity)
const char* WIFI_SSID = "Mena";
const char* WIFI_PASSWORD = "12341234xwz";
// MQTT Broker Details (Your Mac/Mosquitto)
const char* MQTT_SERVER_IP = "192.168.1.5";
const int MQTT_PORT = 1883;
const char* MQTT_TOPIC = "esp/sensor/data";
const char* MQTT_CLIENT_ID = "ESP_Client_1";
const char* MQTT_USER_CFG_CMD = "AT+MQTTUSERCFG=0,1,\"ESP_Client_1\",\"\",\"\",0,0,\"\"";
// Sensor Data (Example values - replace with actual sensor reading logic)
float temperature = 25.10;
float humidity = 43.20;
// --- Function Prototypes ---
void sendATCommand(const char* command, int waitTime, const char* expectedResponse);
bool connectWiFi();
void configureAndConnectMQTT();
void publishSensorData();
// --- Setup ---
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, LOW); // LED off initially
  // CRITICAL CHANGE: Using 9600 baud for stability with Arduino Uno and ESP8285
  DEBUG_SERIAL.begin(9600);
  ESP_SERIAL.begin(9600);
  DEBUG_SERIAL.println("--- Starting ESP8285 Setup for MQTT (Baud: 9600) ---");
  // Flash LED twice to confirm setup started
  digitalWrite(LED_PIN, HIGH); delay(100); digitalWrite(LED_PIN, LOW); delay(100);
  digitalWrite(LED_PIN, HIGH); delay(100); digitalWrite(LED_PIN, LOW); delay(500);
  // 1. Permanently set ESP8285 firmware to 9600 baud for reliable communication
  DEBUG_SERIAL.println("Setting ESP Baud Rate to 9600...");
  sendATCommand("AT+UART_CUR=9600,8,1,0,0", 500, "OK");
  // 2. Initial AT commands
  sendATCommand("AT", 200, "OK");
  sendATCommand("AT+RST", 2000, "ready");
  sendATCommand("AT+CWMODE=1", 200, "OK"); // Set to station mode
  // Attempt the Wi-Fi connection and set the global flag
  isConnected = connectWiFi();
  if (isConnected) {
    DEBUG_SERIAL.println("--- Wi-Fi Connected. Proceeding to MQTT ---");
    digitalWrite(LED_PIN, HIGH); // SUCCESS: LED ON SOLID
    DEBUG_SERIAL.println("!!! FAILED TO CONNECT WI-FI. LED blinking error. !!!");
    // FAILURE: LED blinks fast, handled in loop()
// --- Main Loop ---
  if (isConnected) {
    // If connected, LED is solid. Send data every 10 seconds.
    digitalWrite(LED_PIN, HIGH); // Keep LED on
    delay(10000);
    // If not connected, blink the LED rapidly to show error state.
    delay(200);
    delay(200);
    // After blinking for a while, retry connection every 10 seconds
    static unsigned long lastRetry = 0;
    if (millis() - lastRetry > 10000) {
        DEBUG_SERIAL.println("!!! Connection failed in setup. Retrying Wi-Fi... !!!");
        if (isConnected) {
        lastRetry = millis();
// --- Core Communication Functions ---
bool connectWiFi() {
  char command[64];
  sprintf(command, "AT+CWJAP=\"%s\",\"%s\"", WIFI_SSID, WIFI_PASSWORD);
  DEBUG_SERIAL.print(">>> Command: ");
  DEBUG_SERIAL.println(command);
  ESP_SERIAL.println(command);
  // Set a 30-second timeout for robust connection
  long startTime = millis();
  String response = "";
  while (millis() - startTime < 30000) {
    if (ESP_SERIAL.available()) {
      char c = ESP_SERIAL.read();
      DEBUG_SERIAL.write(c);
      response += c;
      // Look for the success messages
      if (response.indexOf("WIFI GOT IP") >= 0) { // More specific success check
        return true;
      // Look for the specific failure message
      if (response.indexOf("FAIL") >= 0 || response.indexOf("ERROR") >= 0) {
        return false;
  DEBUG_SERIAL.println("\n[Wi-Fi Connection Timeout]");
  return false;
void configureAndConnectMQTT() {
  DEBUG_SERIAL.println("--- Configuring MQTT Client ---");
  // 1. Configure the Client (ID, No Auth)
  sendATCommand(MQTT_USER_CFG_CMD, 500, "OK");
  // 2. Connect to the Broker
  char connect_command[64];
  sprintf(connect_command, "AT+MQTTCONN=0,\"%s\",%d,0", MQTT_SERVER_IP, MQTT_PORT);
  DEBUG_SERIAL.println(connect_command);
  // Wait for +MQTTCONNECTED and OK
  sendATCommand(connect_command, 5000, "+MQTTCONNECTED");
  sendATCommand("", 500, "OK"); // Check for final OK
void publishSensorData() {
  char payload[32];
  sprintf(payload, "T:%.2f,H:%.2f", temperature, humidity);
  char publish_command[128];
  sprintf(publish_command, "AT+MQTTPUB=0,\"%s\",\"%s\",0,0", MQTT_TOPIC, payload);
  DEBUG_SERIAL.print("Attempting to send: ");
  DEBUG_SERIAL.println(payload);
  DEBUG_SERIAL.println(publish_command);
  sendATCommand(publish_command, 1000, "+MQTTPUB:OK");
  DEBUG_SERIAL.println("--- Data Send Attempt Complete ---");
void sendATCommand(const char* command, int waitTime, const char* expectedResponse) {
  if (strlen(command) > 0) {
  while (millis() - startTime < waitTime) {
      response += c;
    if (expectedResponse != NULL && response.indexOf(expectedResponse) >= 0) {
    if (response.indexOf("ERROR") >= 0 || response.indexOf("FAIL") >= 0) {
      DEBUG_SERIAL.println("\n[AT ERROR Detected]");
Just checking that it responds correctly to most other commands ?
Using an UNO to control an ESP is a bit like buying a Ford Mustang and putting a Horse in front to pull it (rather than putting the horse in a trailer and let the Mustang do the pulling) but it can be done.
You should not use the same port for both, that will result in double messages to the ESP.
And you should always explicitly add the 2 terminating characters "\r\n" after every AT-command or the ESP won't recognize the command at all.
So rather something like
ESP_SERIAL.print(command);
ESP_SERIAL.print("\r\n");
Or
ESPSERIAL.println(command);
Nope ! Println() does not send both NL & CR
I stand corrected. Are you sure the order in which they are sent is correct ?
I thought it only sent a NEWLINE (and no CR)
  Serial.begin(19200);
  Serial.println("Hi Deva_R");
  delay(2000);
