hello my name is Marco I'm using an esp866 in which I use an http request but I have a problem
'class SoftwareSerial' has no member named 'connect'
I send the code below
#include <WiFiEspClient.h>
#include <WiFiEspServer.h>
#include <WiFiEspUdp.h>
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(10,11); // RX, TX
#endif
char ssid[] = "Kioru 2.4"; // your network SSID (name)
char pass[] = "K10RU!!!"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char server[] = "192.168.100.50";
// Initialize the Ethernet client object
WiFiEspClient client;
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(115200);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data
Serial.println("You're connected to the network");
printWifiStatus();
Serial.println("Starting connection to server...");
// if you get a connection, report back via serial
if (client.connect(server, 8080)) {
Serial.println("Connected to server");
// Make a HTTP request
String content = "un mensaje de post";
client.println("POST /testPost HTTP/1.1");
client.println("Host: 192.168.100.50:8080");
client.println("Accept: /");
client.println("Content-Length: " + content.length());
client.println("Content-Type: application/json");
client.println("Cache-Control: no-cache");
client.println(content);
// if there are incoming bytes available
// from the server, read them and print them
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client
if (!client.connected()) {
Serial.println("Disconnecting from server...");
client.stop();
// do nothing forevermore
while (true);
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
