ESPAsync_WiFiManager(khoih-prog) and runing an AsyncWeberserver
Hello friends
I am using an ESP32. There i try to run an ASyncWebserver to display a Webpage. To manage my Wificonnections i am using the ESPAsync_WiFiManager(by khoih-prog).
I tried to run an example "hello World" on my Webpage but unfortunly with no sucsess.
Here is the whole code i am using
As far as i understand, when i type the URL "myIP/hello" i should get my hello world command.
My only result is: The connection has timed out
Can someone see my error?
Thank you very much
code 1/2
#if !( defined(ESP8266) ||  defined(ESP32) )
  #error This code is intended to run on the ESP8266 or ESP32 platform! Please check your Tools->Board setting.
#endif
// Use from 0 to 4. Higher number, more debugging messages and memory usage.
#define _ESPASYNC_WIFIMGR_LOGLEVEL_    3
// Default is 30s, using 20s now
#define TIME_BETWEEN_MODAL_SCANS          20000
// Default is 60s, using 30s now
#define TIME_BETWEEN_MODELESS_SCANS       30000
//Ported to ESP32
#ifdef ESP32
  #include <esp_wifi.h>
  #include <WiFi.h>
  #include <WiFiClient.h>
  #include <ESPAsyncWebServer.h>
  #include <AsyncTCP.h>
AsyncWebServer server(80);
  // From v1.1.1
  #include <WiFiMulti.h>
  WiFiMulti wifiMulti;
  #define USE_SPIFFS      true
  #if USE_SPIFFS
    #include <SPIFFS.h>
    FS* filesystem =      &SPIFFS;
    #define FileFS        SPIFFS
    #define FS_Name       "SPIFFS"
  #else
    // +Use FFat
    #include <FFat.h>
    FS* filesystem =      &FFat;
    #define FileFS        FFat
    #define FS_Name       "FFat"
  #endif
  #define ESP_getChipId()   ((uint32_t)ESP.getEfuseMac())
  #define LED_BUILTIN       2
  #define LED_ON            HIGH
  #define LED_OFF           LOW
#else
  #include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
  //needed for library
  #include <DNSServer.h>
  // From v1.1.1
  #include <ESP8266WiFiMulti.h>
  ESP8266WiFiMulti wifiMulti;
  #define USE_LITTLEFS      true
  #if USE_LITTLEFS
    #include <LittleFS.h>
    FS* filesystem =      &LittleFS;
    #define FileFS        LittleFS
    #define FS_Name       "LittleFS"
  #else
  #endif
  #define ESP_getChipId()   (ESP.getChipId())
  #define LED_ON      LOW
  #define LED_OFF     HIGH
#endif
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// From v1.1.1
// You only need to format the filesystem once
//#define FORMAT_FILESYSTEM       true
#define FORMAT_FILESYSTEM         false
#define MIN_AP_PASSWORD_SIZE    8
#define SSID_MAX_LEN            32
//From v1.0.10, WPA2 passwords can be up to 63 characters long.
#define PASS_MAX_LEN            64
typedef struct
  char wifi_ssid[SSID_MAX_LEN];
  char wifi_pw  [PASS_MAX_LEN];
}  WiFi_Credentials;
typedef struct
  String wifi_ssid;
  String wifi_pw;
}  WiFi_Credentials_String;
#define NUM_WIFI_CREDENTIALS      2
typedef struct
  WiFi_Credentials  WiFi_Creds [NUM_WIFI_CREDENTIALS];
} WM_Config;
WM_Config         WM_config;
#define  CONFIG_FILENAME              F("/wifi_cred.dat")
// Indicates whether ESP has WiFi credentials saved from previous session, or double reset detected
bool initialConfig = false;
// Use false if you don't like to display Available Pages in Information Page of Config Portal
// Comment out or use true to display Available Pages in Information Page of Config Portal
// Must be placed before #include <ESP_WiFiManager.h>
#define USE_AVAILABLE_PAGES     true
// From v1.0.10 to permit disable/enable StaticIP configuration in Config Portal from sketch. Valid only if DHCP is used.
// You'll loose the feature of dynamically changing from DHCP to static IP, or vice versa
// You have to explicitly specify false to disable the feature.
//#define USE_STATIC_IP_CONFIG_IN_CP          false
// Use false to disable NTP config. Advisable when using Cellphone, Tablet to access Config Portal.
// See Issue 23: On Android phone ConfigPortal is unresponsive (https://github.com/khoih-prog/ESP_WiFiManager/issues/23)
#define USE_ESP_WIFIMANAGER_NTP     false
// Use true to enable CloudFlare NTP service. System can hang if you don't have Internet access while accessing CloudFlare
// See Issue #21: CloudFlare link in the default portal (https://github.com/khoih-prog/ESP_WiFiManager/issues/21)
#define USE_CLOUDFLARE_NTP          false
// New in v1.0.11
#define USING_CORS_FEATURE          true
// Use USE_DHCP_IP == true for dynamic DHCP IP, false to use static IP which you have to change accordingly to your network
#if (defined(USE_STATIC_IP_CONFIG_IN_CP) && !USE_STATIC_IP_CONFIG_IN_CP)
// Force DHCP to be true
  #if defined(USE_DHCP_IP)
    #undef USE_DHCP_IP
  #endif
  #define USE_DHCP_IP     true
#else
  // You can select DHCP or Static IP here
  //#define USE_DHCP_IP     true
  #define USE_DHCP_IP     false
#endif
#if ( USE_DHCP_IP || ( defined(USE_STATIC_IP_CONFIG_IN_CP) && !USE_STATIC_IP_CONFIG_IN_CP ) )
  // Use DHCP
  #warning Using DHCP IP
  IPAddress stationIP   = IPAddress(0, 0, 0, 0);
  IPAddress gatewayIP   = IPAddress(192, 168, 2, 1);
  IPAddress netMask     = IPAddress(255, 255, 255, 0);
#else
  // Use static IP
  #warning Using static IP
  #ifdef ESP32
    IPAddress stationIP   = IPAddress(192, 168, 2, 232);
  #else
    IPAddress stationIP   = IPAddress(192, 168, 2, 186);
  #endif
#endif
#define USE_CONFIGURABLE_DNS      true
IPAddress dns1IP      = gatewayIP;
IPAddress dns2IP      = IPAddress(8, 8, 8, 8);
#include <ESPAsync_WiFiManager.h>              //https://github.com/khoih-prog/ESPAsync_WiFiManager
#define HTTP_PORT           80
AsyncWebServer webServer(HTTP_PORT);
DNSServer dnsServer;
void heartBeatPrint(void)
  static int num = 1;
  if (WiFi.status() == WL_CONNECTED)
    Serial.print(F("H"));        // H means connected to WiFi
    Serial.print(F("F"));        // F means not connected to WiFi
  if (num == 80)
    num = 1;
  else if (num++ % 10 == 0)
    Serial.print(F(" "));
void check_WiFi(void)
  if ( (WiFi.status() != WL_CONNECTED) )
    Serial.println(F("\nWiFi lost. Call connectMultiWiFi in loop"));
    //connectMultiWiFi();
void check_status(void)
  static ulong checkstatus_timeout  = 0;
  static ulong checkwifi_timeout    = 0;
  static ulong current_millis;
#define WIFICHECK_INTERVAL    1000L
#define HEARTBEAT_INTERVAL    10000L
  current_millis = millis();
  // Check WiFi every WIFICHECK_INTERVAL (1) seconds.
  if ((current_millis > checkwifi_timeout) || (checkwifi_timeout == 0))
    check_WiFi();
    checkwifi_timeout = current_millis + WIFICHECK_INTERVAL;
  // Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
  if ((current_millis > checkstatus_timeout) || (checkstatus_timeout == 0))
    heartBeatPrint();
    checkstatus_timeout = current_millis + HEARTBEAT_INTERVAL;
void loadConfigData(void)
  File file = FileFS.open(CONFIG_FILENAME, "r");
  LOGERROR(F("LoadWiFiCfgFile "));
  if (file)
    file.readBytes((char *) &WM_config, sizeof(WM_config));
    file.close();
    LOGERROR(F("OK"));
    LOGERROR(F("failed"));
code 2/2
void saveConfigData(void)
  File file = FileFS.open(CONFIG_FILENAME, "w");
  LOGERROR(F("SaveWiFiCfgFile "));
  if (file)
    file.write((uint8_t*) &WM_config, sizeof(WM_config));
    file.close();
    LOGERROR(F("OK"));
uint8_t connectMultiWiFi(void)
#if ESP32
  // For ESP32, this better be 0 to shorten the connect time
  #define WIFI_MULTI_1ST_CONNECT_WAITING_MS       0
#else
  // For ESP8266, this better be 2200 to enable connect the 1st time
  #define WIFI_MULTI_1ST_CONNECT_WAITING_MS       2200L
#endif
#define WIFI_MULTI_CONNECT_WAITING_MS           100L
  uint8_t status;
  LOGERROR(F("ConnectMultiWiFi with :"));
  if ( (Router_SSID != "") && (Router_Pass != "") )
    LOGERROR3(F("* Flash-stored Router_SSID = "), Router_SSID, F(", Router_Pass = "), Router_Pass );
  for (uint8_t i = 0; i < NUM_WIFI_CREDENTIALS; i++)
    // Don't permit NULL SSID and password len < MIN_AP_PASSWORD_SIZE (8)
    if ( (String(WM_config.WiFi_Creds[i].wifi_ssid) != "") && (strlen(WM_config.WiFi_Creds[i].wifi_pw) >= MIN_AP_PASSWORD_SIZE) )
      LOGERROR3(F("* Additional SSID = "), WM_config.WiFi_Creds[i].wifi_ssid, F(", PW = "), WM_config.WiFi_Creds[i].wifi_pw );
  LOGERROR(F("Connecting MultiWifi..."));
  WiFi.mode(WIFI_STA);
#if !USE_DHCP_IP
  #if USE_CONFIGURABLE_DNS
    // Set static IP, Gateway, Subnetmask, DNS1 and DNS2. New in v1.0.5
    WiFi.config(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
  #else
    // Set static IP, Gateway, Subnetmask, Use auto DNS1 and DNS2.
    WiFi.config(stationIP, gatewayIP, netMask);
  #endif
#endif
  int i = 0;
  status = wifiMulti.run();
  delay(WIFI_MULTI_1ST_CONNECT_WAITING_MS);
  while ( ( i++ < 20 ) && ( status != WL_CONNECTED ) )
    if ( status == WL_CONNECTED )
      delay(WIFI_MULTI_CONNECT_WAITING_MS);
    LOGERROR1(F("WiFi connected after time: "), i);
    LOGERROR3(F("SSID:"), WiFi.SSID(), F(",RSSI="), WiFi.RSSI());
    LOGERROR3(F("Channel:"), WiFi.channel(), F(",IP address:"), WiFi.localIP() );
    LOGERROR(F("WiFi not connected"));
  return status;
  while (!Serial);
  Serial.print("\nStarting Async_AutoConnectAP using " + String(FS_Name));
  Serial.println(" on " + String(ARDUINO_BOARD));
  if (FORMAT_FILESYSTEM)
    FileFS.format();
  // Format FileFS if not yet
#ifdef ESP32
  if (!FileFS.begin(true))
#else
  if (!FileFS.begin())
#endif
    Serial.print(FS_Name);
    Serial.println(F(" failed! AutoFormatting."));
#ifdef ESP8266
    FileFS.format();
#endif
  unsigned long startedAt = millis();
  //Local intialization. Once its business is done, there is no need to keep it around
  // Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
  //ESPAsync_WiFiManager ESPAsync_wifiManager(&webServer, &dnsServer);
  // Use this to personalize DHCP hostname (RFC952 conformed)
  ESPAsync_WiFiManager ESPAsync_wifiManager(&webServer, &dnsServer, "AutoConnectAP");
  ESPAsync_wifiManager.setDebugOutput(true);
  //reset settings - for testing
  //ESPAsync_wifiManager.resetSettings();
  //set custom ip for portal
  ESPAsync_wifiManager.setAPStaticIPConfig(IPAddress(192, 168, 100, 1), IPAddress(192, 168, 100, 1), IPAddress(255, 255, 255, 0));
  ESPAsync_wifiManager.setMinimumSignalQuality(-1);
  // From v1.0.10 only
  // Set config portal channel, default = 1. Use 0 => random channel from 1-13
  ESPAsync_wifiManager.setConfigPortalChannel(0);
#if !USE_DHCP_IP
    ESPAsync_wifiManager.setSTAStaticIPConfig(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
  #else
    ESPAsync_wifiManager.setSTAStaticIPConfig(stationIP, gatewayIP, netMask);
  #endif
#endif
  // New from v1.1.1
#if USING_CORS_FEATURE
  ESPAsync_wifiManager.setCORSHeader("Your Access-Control-Allow-Origin");
#endif
  // We can't use WiFi.SSID() in ESP32 as it's only valid after connected.
  // SSID and Password stored in ESP32 wifi_ap_record_t and wifi_config_t are also cleared in reboot
  // Have to create a new function to store in EEPROM/SPIFFS for this purpose
  Router_SSID = ESPAsync_wifiManager.WiFi_SSID();
  Router_Pass = ESPAsync_wifiManager.WiFi_Pass();
  //Remove this line if you do not want to see WiFi password printed
  Serial.println("Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
  if (Router_SSID != "")
    ESPAsync_wifiManager.setConfigPortalTimeout(120); //If no access point name has been previously entered disable timeout.
    Serial.println("Got stored Credentials. Timeout 120s");
    Serial.println("No stored Credentials. No timeout");
  String chipID = String(ESP_getChipId(), HEX);
  chipID.toUpperCase();
  // SSID and PW for Config Portal
  String AP_SSID = "ESP_" + chipID + "_AutoConnectAP";
  String AP_PASS = "MyESP_" + chipID;
  // From v1.1.0, Don't permit NULL password
  if ( (Router_SSID == "") || (Router_Pass == "") )
    Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
    // Starts an access point
    //if (!ESPAsync_wifiManager.startConfigPortal((const char *) ssid.c_str(), password))
    if ( !ESPAsync_wifiManager.startConfigPortal(AP_SSID.c_str(), AP_PASS.c_str()) )
      Serial.println("Not connected to WiFi but continuing anyway.");
      Serial.println("WiFi connected...yeey :)");
    // Stored  for later usage, from v1.1.0, but clear first
    memset(&WM_config, 0, sizeof(WM_config));
      String tempSSID = ESPAsync_wifiManager.getSSID(i);
      String tempPW   = ESPAsync_wifiManager.getPW(i);
      if (strlen(tempSSID.c_str()) < sizeof(WM_config.WiFi_Creds[i].wifi_ssid) - 1)
        strcpy(WM_config.WiFi_Creds[i].wifi_ssid, tempSSID.c_str());
        strncpy(WM_config.WiFi_Creds[i].wifi_ssid, tempSSID.c_str(), sizeof(WM_config.WiFi_Creds[i].wifi_ssid) - 1);
      if (strlen(tempPW.c_str()) < sizeof(WM_config.WiFi_Creds[i].wifi_pw) - 1)
        strcpy(WM_config.WiFi_Creds[i].wifi_pw, tempPW.c_str());
        strncpy(WM_config.WiFi_Creds[i].wifi_pw, tempPW.c_str(), sizeof(WM_config.WiFi_Creds[i].wifi_pw) - 1);
        LOGERROR3(F("* Add SSID = "), WM_config.WiFi_Creds[i].wifi_ssid, F(", PW = "), WM_config.WiFi_Creds[i].wifi_pw );
        wifiMulti.addAP(WM_config.WiFi_Creds[i].wifi_ssid, WM_config.WiFi_Creds[i].wifi_pw);
    saveConfigData();
    wifiMulti.addAP(Router_SSID.c_str(), Router_Pass.c_str());
  if (!initialConfig)
    // Load stored data, the addAP ready for MultiWiFi reconnection
    loadConfigData();
    if ( WiFi.status() != WL_CONNECTED )
      Serial.println("ConnectMultiWiFi in setup");
      connectMultiWiFi();
  Serial.print("After waiting ");
  Serial.print((float) (millis() - startedAt) / 1000L);
  Serial.print(" secs more in setup(), connection result is ");
    Serial.print("connected. Local IP: ");
    Serial.println(ESPAsync_wifiManager.getStatus(WiFi.status()));
server.on("/hello", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(200, "text/plain", "Hello World");
server.begin();
  // put your main code here, to run repeatedly
  check_status();
There are several possible issues
  1. You have to use the correct webServer (not just server) as declared in the code
  webServer.on("/hello", HTTP_GET, [](AsyncWebServerRequest * request)
  webServer.begin();
 check_status();
  1. You have to use the correct IP settings for staticIP or use DHCP. Then verify if IP is OK by checking the debug terminal
For example
    #undef USE_DHCP_IP
  #endif
#else
  #define USE_DHCP_IP     true                                 <=========== Use DHCP
  //#define USE_DHCP_IP     false
#endif
  // Use DHCP
  IPAddress gatewayIP   = IPAddress(192, 168, 2, 1);         <============ Modify if DHCP IP to gateway IP
#else
  // Use static IP
  #ifdef ESP32
  IPAddress stationIP   = IPAddress(192, 168, 2, 232);          <============ Modify if static IP
  #else
  #endif
  IPAddress gatewayIP   = IPAddress(192, 168, 2, 1);            <============ Modify if static IP  to gateway IP
#endif
  1. This is the debug terminal. Static IP address is 192.168.2.232 according to the local network
Starting Async_AutoConnectAP using SPIFFS on ESP32_DEV
[WM] RFC925 Hostname = AutoConnectAP
[WM] setAPStaticIPConfig
[WM] setSTAStaticIPConfig for USE_CONFIGURABLE_DNS
[WM] Set CORS Header to :  Your Access-Control-Allow-Origin
Stored: SSID = HueNet1, Pass = 12345678
[WM] LoadWiFiCfgFile
[WM] OK
[WM] * Add SSID =  HueNet1 , PW =  12345678
[WM] * Add SSID =  HueNet2 , PW =  12345678
[WM] ConnectMultiWiFi with :
[WM] * Flash-stored Router_SSID =  HueNet1 , Router_Pass =  12345678
[WM] * Additional SSID =  HueNet1 , PW =  12345678
[WM] * Additional SSID =  HueNet2 , PW =  12345678
[WM] Connecting MultiWifi...
[WM] WiFi connected after time:  1
[WM] SSID: HueNet1 ,RSSI= -33
[WM] Channel: 2 ,IP address: 192.168.2.232
After waiting 2.73 secs more in setup(), connection result is connected. Local IP: 192.168.2.232
[WM] freeing allocated params!
HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH
