I'm trying to compile an example using the ESPAsymcWebServer library. The compile is successful, but the link fails with dozens of errors, most or all seem to be related to exception handling functions from std::. I've never used most of this stuff, so somewhat at a loss where to look.
I assume it's just some library version incompatibility, but the article I'm working from:
does not specify WHAT library version(s) to use.
Anyone have a clue what is missing, and where?
Here are the errors I'm getting:
E:\Users\RayL\Documents\AppData\Arduino\arduino-1.8.9\libraries\ESPAsyncWebServer\src/StringArray.h:75: undefined reference to `std::__throw_regex_error(std::regex_constants::error_type)'
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o: In function `std::__detail::_Scanner<char const*>::_M_eat_escape()':
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o:(.text._ZNSt8__detail8_ScannerIPKcE10_M_advanceEv[_ZNSt8__detail8_ScannerIPKcE10_M_advanceEv]+0x6e): undefined reference to `std::__throw_regex_error(std::regex_constants::error_type)'
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o: In function `std::__detail::_Scanner<char const*>::_M_scan_in_bracket()':
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o:E:\Users\RayL\Documents\AppData\Arduino\arduino-1.8.9\libraries\ESPAsyncWebServer\src/StringArray.h:75: more undefined references to `std::__throw_regex_error(std::regex_constants::error_type)' follow
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o: In function `std::_Function_base::_Base_manager<std::__detail::_EndTagger<char const*, std::regex_traits<char> > >::_M_init_functor(std::_Any_data&, std::__detail::_EndTagger<char const*, std::regex_traits<char> >&&, std::integral_constant<bool, false>)':
E:\Users\RayL\Documents\AppData\Arduino\arduino-1.8.9\libraries\ESPAsyncWebServer\src/StringArray.h:75: undefined reference to `std::__throw_bad_cast()'
C:\Users\RayL\AppData\Local\Temp\arduino_build_689415\libraries\ESPAsyncWebServer\WebServer.cpp.o: In function `std::__detail::_Compiler<char const*, std::regex_traits<char> >::_M_atom()':
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(istream-inst.o): In function `__check_facet<std::ctype<char> >':
/Users/igrokhotkov/e/ESPTools/crosstool-NG/.build/xtensa-lx106-elf/build/build-cc-gcc-final/xtensa-lx106-elf/libstdc++-v3/include/bits/streambuf_iterator.h:113: undefined reference to `std::__throw_bad_cast()'
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(istream-inst.o): In function `std::istream::operator>>(int&)':
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(locale-inst.o): In function `std::ctype<char> const& std::use_facet<std::ctype<char> >(std::locale const&)':
/Users/igrokhotkov/e/ESPTools/crosstool-NG/.build/xtensa-lx106-elf/build/build-cc-gcc-final/xtensa-lx106-elf/libstdc++-v3/include/bits/locale_classes.tcc:114: undefined reference to `std::__throw_bad_cast()'
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(locale-inst.o):/Users/igrokhotkov/e/ESPTools/crosstool-NG/.build/xtensa-lx106-elf/build/build-cc-gcc-final/xtensa-lx106-elf/libstdc++-v3/include/bits/locale_classes.tcc:114: more undefined references to `std::__throw_bad_cast()' follow
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(c++locale.o):(.literal._ZNSt6locale5facet18_S_create_c_localeERPiPKcS1_+0x4): undefined reference to `std::__throw_runtime_error(char const*)'
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(c++locale.o): In function `std::locale::facet::_S_create_c_locale(int*&, char const*, int*)':
/Users/igrokhotkov/e/ESPTools/crosstool-NG/.build/xtensa-lx106-elf/build/build-cc-gcc-final/xtensa-lx106-elf/libstdc++-v3/src/c++98/c++locale.cc:207: undefined reference to `std::__throw_runtime_error(char const*)'
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(ios-inst.o):(.literal._ZNSt9basic_iosIcSt11char_traitsIcEE5clearESt12_Ios_Iostate[_ZNSt9basic_iosIcSt11char_traitsIcEE5clearESt12_Ios_Iostate]+0x4): undefined reference to `std::__throw_ios_failure(char const*)'
C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2/tools/sdk/lib\libstdc++.a(ios-inst.o): In function `std::basic_ios<char, std::char_traits<char> >::clear(std::_Ios_Iostate)':
/Users/igrokhotkov/e/ESPTools/crosstool-NG/.build/xtensa-lx106-elf/build/build-cc-gcc-final/xtensa-lx106-elf/libstdc++-v3/include/bits/basic_ios.tcc:122: undefined reference to `std::__throw_ios_failure(char const*)'
collect2.exe: error: ld returned 1 exit status
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2\libraries\ESP8266WiFi
Using library ESPAsyncTCP at version 1.2.2 in folder: E:\Users\RayL\Documents\AppData\Arduino\arduino-1.8.9\libraries\ESPAsyncTCP
Using library ESPAsyncWebServer at version 1.2.3 in folder: E:\Users\RayL\Documents\AppData\Arduino\arduino-1.8.9\libraries\ESPAsyncWebServer
Using library Hash at version 1.0 in folder: C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2\libraries\Hash
Using library Wire at version 1.0 in folder: C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\RayL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0-rc2\libraries\SPI
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Regards,
Ray L.
