ESPdebug showing random symbols
Latest Update
The code worked miraculously for some reason eventhough ESPdebug still outputs alien language! Apparently, this happened after I have executed this command: AT+UART_DEF=9600,8,1,0,0 in the serial monitor and change the baud rate of ESP to 9600 in the sketch.
Next step is to try the 4th solution in the link: ESP8266 wiring schemas - Yet Another Arduino Blog
I hope this topic is helpful to the Arduino newcomers who wants to try out ESP8266!
Hi Arduino peeps!
First off, I would like to apologize if this has been addressed a couple of times. I have tried most of the solutions given on the internet but none of them worked for me.
Situation
I am currently exploring on IoT platforms and came across an introductory project written on Thingsboard blog. Out of curiosity, I decided to try on this project: Temperature upload over MQTT using Arduino UNO, ESP8266 and DHT22 sensor | ThingsBoard Community Edition
Code
I copied the code exactly from the Thingsboard link above and made only four changes to it. They are:
  1. WiFi AP
  2. WiFi Password
  3. Device Access token
  4. Server
#include "DHT.h"
#include <WiFiEspClient.h>
#include <WiFiEsp.h>
#include <WiFiEspUdp.h>
#include "SoftwareSerial.h"
#include <ThingsBoard.h>
#define WIFI_AP "YOUR_WIFI_AP" //This is where I input my WIFI name
#define WIFI_PASSWORD "YOUR_WIFI_PASSWORD" //This is where I input my WIFI Pw
#define TOKEN "YOUR_ACCESS_TOKEN" //This is where I input the access token generated from demo.thingsboard.io
// DHT
#define DHTPIN 4
#define DHTTYPE DHT11 //I changed this from DHT22 to DHT11 since I am using DHT11
char thingsboardServer[] = "demo.thingsboard.io"; //I changed this to demo.thingsboard.io since I need to transmit temp and humidity data to the server
// Initialize the Ethernet client object
WiFiEspClient espClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
ThingsBoard tb(espClient);
SoftwareSerial soft(2, 3); // RX, TX
int status = WL_IDLE_STATUS;
unsigned long lastSend;
  // initialize serial for debugging
  dht.begin();
  InitWiFi();
  lastSend = 0;
  status = WiFi.status();
  if ( status != WL_CONNECTED) {
    while ( status != WL_CONNECTED) {
      Serial.print("Attempting to connect to WPA SSID: ");
      Serial.println(WIFI_AP);
      // Connect to WPA/WPA2 network
      status = WiFi.begin(WIFI_AP, WIFI_PASSWORD);
    Serial.println("Connected to AP");
  if ( !tb.connected() ) {
    reconnect();
  if ( millis() - lastSend > 1000 ) { // Update and send only after 1 seconds
    getAndSendTemperatureAndHumidityData();
    lastSend = millis();
  tb.loop();
void getAndSendTemperatureAndHumidityData()
  Serial.println("Collecting temperature data.");
  // Reading temperature or humidity takes about 250 milliseconds!
  float humidity = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float temperature = dht.readTemperature();
  // Check if any reads failed and exit early (to try again).
  if (isnan(humidity) || isnan(temperature)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  Serial.println("Sending data to ThingsBoard:");
  Serial.print("Humidity: ");
  Serial.print(humidity);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(temperature);
  Serial.println(" *C ");
  tb.sendTelemetryFloat("temperature", temperature);
  tb.sendTelemetryFloat("humidity", humidity);
void InitWiFi()
  // initialize serial for ESP module
  soft.begin(9600);
  // initialize ESP module
  WiFi.init(&soft);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  Serial.println("Connecting to AP ...");
  // attempt to connect to WiFi network
void reconnect() {
  // Loop until we're reconnected
  while (!tb.connected()) {
    Serial.print("Connecting to ThingsBoard node ...");
    // Attempt to connect (clientId, username, password)
    if ( tb.connect(thingsboardServer, TOKEN) ) {
      Serial.println( "[DONE]" );
      Serial.print( "[FAILED]" );
      Serial.println( " : retrying in 5 seconds" );
      // Wait 5 seconds before retrying
      delay( 5000 );
Problem
Currently, my DHT11 and Arduino UNO worked flawlessly (I tried it separately using a simple DHT11 code). However, ESP8266 failed to connect and keeps generating the following results on the serial monitor:
[WiFiEsp] Initializing ESP module
[WiFiEsp] >>> TIMEOUT >>>
[WiFiEsp] Cannot initialize ESP module
[WiFiEsp] No tag found
To troubleshoot the ESP8266 on an isolated manner, I opened up the default ESPdebug sketch and run the code.
Code
// EspDebug - Test sketch for ESP8266 module
#include "Arduino.h"
// Emulate Serial1 on pins 7/6 if not present
#ifndef HAVE_HWSERIAL1
SoftwareSerial Serial1(2, 3); // RX, TX
#endif
  Serial.begin(1200); // serial port used for debugging
  Serial1.begin(115200);  // your ESP's baud rate might be different
  if(Serial1.available())  // check if the ESP is sending a message
    while(Serial1.available())
      int c = Serial1.read(); // read the next character
      Serial.write((char)c);  // writes data to the serial monitor
  if(Serial.available())
    // wait to let all the input command in the serial buffer
    delay(10);
    // read the input command in a string
    String cmd = "";
    while(Serial.available())
      cmd += (char)Serial.read();
    // print the command and send it to the ESP
    Serial.print(">>>> ");
    Serial.println(cmd);
    // send the read character to the ESP
    Serial1.print(cmd);
What I've Tried
  1. Playing with different baud rates:
According to some forums, setting serial monitor baud rate to 1200 delivers the best result. I tried and it's by far displaying the most "readable" results. There were random symbols and I noticed that the version number was inconsistent (sometimes it displayed 1.1.0.0; other times 0.1.0.0)
As for the ESP's baudrate, I tried inputting the two following commands:
AT+UART=9600,8,1,0,0 (This did not work, so I reversed the process by inserting AT+UART=115200,8,1,0,0)
AT+UART_DEF=9600,8,1,0,0 (This felt irreversible. Once I entered this command, my serial monitor started behaving abnormally, generating more random symbols and kept generating inversed question marks. I tried to undo it by inserting a AT+UART_DEF=115200,8,1,0,0 but the system did not seem to acknowledge the input)
  1. Plugging in a 9V battery on top of the 3.3v from computer's USB port: Some said the 3.3v supplied by Arduino has a low current output and hence requiring additional external power source. Didn't work for my case.
  2. Interchanged Rx and Tx: Didn't work as well.
ESP8266 is not connecting most of the time.
Connecting to ThingsBoard node ...[DONE]
Humidity: 61.00 % Temperature: 24.00 *C
Connecting to ThingsBoard node ...[WiFiEsp] Connecting to demo.thingsboard.io
[FAILED] : retrying in 5 seconds
Connecting to ThingsBoard node ...[WiFiEsp] Disconnecting 0
[DONE]
What made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for "Improvements for the web system, applications to moderator, spam, etc."? I have suggested to the Moderator to move it to the Networking section.
This sort of carelessness makes unnecessary work for the Moderators.
Please read How to get the best out of the Forum
...R
Robin2:
...R
I am sorry if it has offended you. Thanks for suggesting to move this to the right section. Your help is much appreciated.
