Hi, i have an explora and original lcd, no matter what example i upload, with ide 1.0.5 or 1.5 I always get things like this.
i lso have an arduino robot, i swapped the lcd and it works.
Someone had the same problem?
Tnx
Tnx
by the way, the example that you can see in the picture is "Improved Esplora TFT Horizon", i can see the line is doing something and reacting to movement.
Does your Esplora work with non-display demo sketches? Try to run it through it’s paces to see if it is Esplora itself and not the combo. If the display works 100% on your Robot, that should eliminate the display being bad.
Arduino support responded to me by mail some days ago. the library inside the ide is no good, here is the link to the correct library, now it works!
