Thanks for ur answer, I understood what the problem was:) so the joystick problem is now solved:
PS: I found a nice mouse woking sketch in the net:
Esplora Calibrated Joystick Mouse
WARNING: this sketch will take over your mouse movement. If you lose control
of your mouse do the following:
- unplug the Esplora.
- open the EsploraBlink sketch
- hold the reset button down while plugging your Esplora back in
- while holding reset, click "Upload"
- when you see the message "Done compiling", release the reset button.
This will stop your Esplora from controlling your mouse while you upload a sketch
that doesn't take control of the mouse.
Instructions:
Made by Michael on 16 May 2013
#include <Esplora.h>
int JoyX; // These Variables are global
int JoyY;
int activate = 0;
Esplora.writeRGB(0, 0, 10); // Signal Esplora is waiting to calibrate
int start = Esplora.readButton(SWITCH_3); // Read First Button
while(start == HIGH) { // Wait until button is pressed
JoyX = Esplora.readJoystickX(); // Set drift variable X
JoyY = Esplora.readJoystickY(); // Set drift variable Y
Esplora.writeRGB(10, 0, 0); // Calibration is done, waiting to run
int xValue = Esplora.readJoystickX(); // read the joystick's X position
int yValue = Esplora.readJoystickY(); // read the joystick's Y position
xValue = xValue - JoyX; // Remove drift on X position
yValue = yValue - JoyY; // Remove drift on Y position
int JoyButton = Esplora.readJoystickButton();
int button1 = Esplora.readButton(SWITCH_1); // Read Buttons
int button2 = Esplora.readButton(SWITCH_2); // Read Buttons
int button3 = Esplora.readButton(SWITCH_3); // Read Buttons
int button4 = Esplora.readButton(SWITCH_4); // Read Buttons
int slide = Esplora.readSlider(); // Read Slider Values
int mousespeed = map(slide, 0, 1023, 10, 0); // Max Mouse Speed is Calculated from slider
int mouseX = map( xValue,-512, 512, mousespeed, -mousespeed); // map the X value to a range of movement for the mouse X, Changes input range to include new values
int mouseY = map( yValue,-512, 512, -mousespeed, mousespeed); // map the Y value to a range of movement for the mouse Y, Changes input range to include new values
if(button3 == LOW){ // Check if the Enable/Disable button is pressed
if(activate == 1) activate = 0;
else activate = 1;
if(activate == 1){ // Check if mouse is enabled
Esplora.writeRGB(0 , 10, 0 ); // Set light to green
Mouse.begin(); // take control of the mouse
if(JoyButton == LOW || button2 == LOW) Mouse.press(MOUSE_LEFT); // Test if Left click is activated
else Mouse.release(MOUSE_LEFT);
if(button1 == LOW) Mouse.press(MOUSE_MIDDLE); // Middle Button
else Mouse.release(MOUSE_MIDDLE);
if(button4 == LOW) Mouse.press(MOUSE_RIGHT); // Right Button
else Mouse.release(MOUSE_RIGHT);
Mouse.move(mouseX, mouseY, 0); // move the mouse
else {
Mouse.end();
Esplora.writeRGB(255, 0, 0 );
delay(10); // a short delay before moving again
But I still have the temperature sensor problem:( how to solve it?
