Esplora TinkerKit Outputs as Inputs
I was wondering if it would be possible to use the output ports as input ones. i want to add 4 additional push buttons but the t?inkerkit inputs are already taken.
the question would be whether it would be possible to use the outputs as inputs without redesigning the pcb?
I know you can use them to supply power but i dont know about that
I finally pulled out my Esplora to some experimenting with it.
This is an old subject, but the previous Reply didn’t answer the question.
The Answer, though, is: Yes .
[And I figure the same for any of the Digital pins on the “LCD” strip as well.]
I proved it with the following sketch –
#include <Esplora.h>
void setup ()
  pinMode(3, INPUT_PULLUP);
  if (digitalRead(3) == LOW)
     Esplora.writeRGB(0,0,125);
     Esplora.writeRGB(0,0,0);
(The OP didn’t engage, the question remained unanswered. Henceforth, it’s settled.)
