ESPNow empfängt keine Daten (... gibt keine Daten aus)
Hallo Gemeinde,
ich habe, da alle aus dem Netz kopierten Codes Fehlermeldungen liefern (selbst die unter ESPNow mitgelieferten Beispielcodes), (bitte nicht lachen) mir von ChatGPT einen Sketch schreiben lassen, der anstansdslos kompiliert wird.` Der Sketch wird ausgeführt auf einem ESP32.
#include <esp_now.h>
#include <WiFi.h>
#define CHANNEL 1
// MAC address of the receiver
uint8_t receiver_mac[] = {0x9c,0x9c,0x1f,0xe1,0xf7,0x94};
// Create a struct for the data to send
struct DataStruct {
  int randomNumber;
DataStruct myData;
// Callback function when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  if (status == ESP_NOW_SEND_SUCCESS) {
    Serial.println("Sent with success");
    Serial.println("Error sending the data");
// Callback function when data is received
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *data, int data_len) {
  memcpy(&myData, data, sizeof(myData));
  Serial.print("Received data: ");
  Serial.println(myData.randomNumber);
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to track the status
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  esp_now_peer_info_t peerInfo;
  memcpy(peerInfo.peer_addr, receiver_mac, 6);
  peerInfo.channel = CHANNEL;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
  // Random seed initialization
  randomSeed(analogRead(0));
  // Generate a random number between 1 and 100
  int randomNumber = random(1, 101);
  // Send the data to the receiver
  myData.randomNumber = randomNumber;
  esp_err_t result = esp_now_send(receiver_mac, (uint8_t *)&myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.print("Sent data: ");
    Serial.println(randomNumber);
    Serial.println("Error sending data");
  // Wait for 6 seconds
  delay(6000);
Nun werden auch die Zufallszahlen gesendet mit den entsprechenden Serialprints im Monitor, aber einen Empfang kann ich nicht registrieren. Ich habe in den anderen Beispiel-Sketchen geschaut, ob Anweisungen fehlen wie z.B. in der Loop-Funktion. Leider kann ich aber keine fehlenden Anweisungen feststellen.
Kann mir jemand einen Tip geben, was ich hier änderen muss?
Im Voraus vielen Dank!
:warning:
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden.
Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
Es tut mir leid zu hören, dass Sie Probleme mit Ihrer ESP-NOW-Kommunikation haben. Haben Sie die richtige MAC-Adresse angegeben?
Ich habe das Internet nach möglichen Lösungen durchsucht und einige nützliche Ressourcen gefunden, die Ihnen helfen könnten.
Sie benötigen einen Empfängercode, der die ESP32-Karte als Wi-Fi-Station einrichtet und eine Rückruffunktion registriert, um die eingehenden Daten zu verarbeiten. Sie müssen auch die MAC-Adresse des Absenders als Peer-Gerät hinzufügen und bei Bedarf die Verschlüsselung aktivieren.
Hier ist ein Beispiel für einen Empfängercode, der die empfangenen Daten auf dem seriellen Monitor ausgibt: Ich bin mir aber nicht sicher, ob dieser Code funktioniert:
#include <WiFi.h>
// Create a structure for the data to receive
struct DataStruct {
      int random number;
DataStructure myData;
      memcpy(&mydata, data, sizeof(mydata));
invalid setup() {
      // Set device as Wi-Fi station
      WiFi.mode (WIFI_STA);
      // Initialize ESP NOW
        come back
      // Register remote station
      // MAC address of the sender
      uint8_t sender_mac[] = {0x9c,0x9c,0x1f,0xe1,0xf7,0x94};
      memcpy(peerInfo.peer_addr, sender_mac, 6);
      peerInfo.channel = 1;
      // Add peer
        Serial.println("Could not add peer");
        come back
      // Registration for a callback function that WILL be called when data is received
      esp_now_register_recv_cb(OnDataRecv);
Unter 2 finden Sie auch ein Beispiel dafür, wie Sie mit ESP-NOW Daten von mehreren ESP32-Boards empfangen können.
Ich hoffe, das hilft Ihnen bei der Lösung Ihres Problems. Wenn nicht, lassen Sie es mich bitte wissen und ich werde versuchen, weitere Informationen für Sie zu finden.
Hallo Gemeinde,
ich habe mehrere Sketche aus dem Netz und auch aus den Beispielen des ESPNow-Menüs probiert, die auf meinen ESP32 einfach nicht kompiliert werden. Daraufhin habe ich mir, bitte nicht lachen, vom ChatGPT einen solchen Sketch schreiben lassen und er wird einwandfrei kompiliert. Es werden anstandslos Daten gesendet mit dem entsprechenden Ausdruck im seriellen Monitor, aber leider keine Daten empfangen. Ich habe meinen aktuellen Sketch mit den Beispielen verglichen, aber ich kann leider keine fehlenden Anweisungen entdecken.
#include <WiFi.h>
#define CHANNEL 1
struct DataStruct {
  int randomNumber;
DataStruct myData;
  // Init ESP-NOW
    return;
  // Register peer
  // Add peer
    return;
  // Wait for 1 second
  delay(6000);
Könnte es sein, dass ich einen anderen ESP32-Typ (jetzt WROOM-DA-Module) einsetzen muss?
Kann mir jemand einen Tip geben, was ich hier noch einfügen oder verbessern muss?
Dann musst du den Bot noch mal befragen.
Interessante Antwort, hilft mir sehr viel weiter!
:warning:
mfg ein Moderator.
Wo ist der Teil für dem Empfänger?
Die MAC Adresse stimmt auch?
Hier?
@ulrkr
du solltest den anderen Thread selbst einem Moderator melden damit dieser den anderen Thread mit dem Thread hier vereint.
Zwei Threads zur gleichen Frage aufmachen ist cross-posting und gegen die Foren-Regeln.
Du riskierst damit im Forum gesprerrt zu werden was dann das genau Gegenteil von dem wäre was du erreichen möchtest.
Hier ist ein Demo-Code der statt einer spezifischen MAC-Adresse die broadcast-adresse benutzt.
Damit müssten die Daten ankommen.
// keep this variable on top to have an easy to remember place to look up
// which board shall have this code-version /a short name is easier to remember as
// a MAC-Adress
char BoardName[] = "Bonny";
unsigned long SendDataInterval;
int Summand;
// at the end of this file there is an explanation that uses an analogy with
// sending / receiving postal letters to explain the several parts of ESP-NOW
// so if you would like to have an easy to understand overview read this
// explanation first.
#include <WiFi.h>
// For sending / receiving ESP-NOW-data on both sides sender and receiver;
// a structured variable has to be defined with the EXACT SAME structure
// the information that shall be sended/received is transmitted bytewise
// the ESP-NOW-functions know nothing about what the bytes mean
// it just transfers a specified number of bytes
// If the structures do not match 100% the data gets MIS-interpreted on the receiver-side
// in this demo-code a structure with an Array Of Char and an integer is used
// it is defined as follows
// ESP-NOW data-structure-definition
typedef struct MyESP_NOW_Data_type {
  char MyESP_NOW_MsgStr[128];
  int  MyESP_NOW_Int;
} MyESP_NOW_Data_type;
// After defining the structure two variables
// one for receiving one for sending data
// this demo wants to demonstrate send AND receive in both directions
MyESP_NOW_Data_type my_received_ESP_NOW_Data;
MyESP_NOW_Data_type my_READYtoSEND_ESP_NOW_Data;
// list of MAC-Adresses of all receivers:
// important note: ESP-NOW sending is based on the RECEIVERS Mac-adress.
// this means for every ESP-modul that shall receive an ESP-NOW-Messages
// you have to execute register a peer in the Setup-function
// Mac-Adress must be stored in an array of uint8_t
//uint8_t ESP_NOW_MAC_adrOfRecv[] = {0x78, 0xE3, 0x6D, 0x17, 0x3A, 0x20 };
uint8_t ESP_NOW_MAC_adrOfRecv[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
char MAC_adrOfRecv_as_AoC[18];
char Own_MacAdr_AoC[18];  //suffix _AoC for easier remembering variable-type is ArrayOfChar
char MySelfHeader[]   = "Myself: ";
char ReceivedHeader[] = "-------------->";
//ESP_NOW_functions
// callback function that will be executed when data is received
// Parameters:
// mac:          mac-adress of sender
// incomingData: the bytes that are received
// NoOfBytesRcv: number of bytes received
//void OnDataRecv(uint8_t * mac, uint8_t *incomingData, uint8_t NoOfBytesRcv) {
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int NoOfBytesRcv) {
  //char MacAdr[18];
  Serial.print(ReceivedHeader);
  Serial.print("ESP-NOW-Data received from Board with MAC-Adress#");
  Serial.print( strupr(hex02str(mac[0])));
  Serial.print(":");
  Serial.print( strupr(hex02str(mac[1])));
  Serial.print(":");
  Serial.print( strupr(hex02str(mac[2])));
  Serial.print(":");
  Serial.print( strupr(hex02str(mac[3])));
  Serial.print(":");
  Serial.print( strupr(hex02str(mac[4])));
  Serial.print(":");
  Serial.print( strupr(hex02str(mac[5])));
  Serial.print(":");
  Serial.println("#");
  // copy data bytewise from variable incomingData to variable my_received_ESP_NOW_Data
  memcpy(&my_received_ESP_NOW_Data, incomingData, sizeof(my_received_ESP_NOW_Data));
  Serial.print("No of Bytes received: ");
  Serial.println(NoOfBytesRcv);
  //these lines must match the variables inside the ESP_NOW-data-structure
  Serial.print("Received Msg: #"); // leading "#"
  Serial.print(my_received_ESP_NOW_Data.MyESP_NOW_MsgStr);
  Serial.println("#"); // trailing "#" makes it easy to see which bytes where received
  Serial.print("Int: ");
  Serial.println(my_received_ESP_NOW_Data.MyESP_NOW_Int);
// callback when data is sent. Gets executed when sending data has finished
  Serial.print(MySelfHeader);
  Serial.print(" OnDataSent Send Status: ");
    Serial.println("Success'");
  else {
    Serial.println("Failed'");
// attention! for some unknown strange reasons the variable
// for the peer-info has to be global otherwise you will
// get the error "ESPNOW: Peer Interface is invalid"
esp_now_peer_info_t MyPeerInfo;
void ESP_Now_setup() {
  Serial.println("WiFi.mode(WIFI_STA); done");
  WiFi.disconnect(); // for strange reasons WiFi.disconnect() makes ESP-NOW work
  Serial.println("WiFi.disconnect(); done");
  // Init ESP-NOW
    return;
  Serial.println("esp_now_init() was successful");
  // register callback-function that will be executed each time
  // function esp_now_send() has finished
  Serial.println("esp_now_register_send_cb(OnDataSent); done");
  // ESP-NOW-Data is received
  Serial.println("esp_now_register_recv_cb(OnDataRecv); done");
  // the ESP-NOW-Sender needs to "fill out" a list with informations about each receiver
  // this is called peer. Therefore you have to create a variable of type esp_now_peer_info_t
  //esp_now_peer_info_t MyPeerInfo;
  // then "fill out" peer-data-form
  memcpy(MyPeerInfo.peer_addr, ESP_NOW_MAC_adrOfRecv, 6);
  MyPeerInfo.channel = 0;
  MyPeerInfo.encrypt = false;
  // after setting up peer-info, add peer
  if (esp_now_add_peer(&MyPeerInfo) != ESP_OK){
    return;
  Serial.println("esp_now_add_peer(&peerInfo) was successful");
  // this setup peer-info and add peer has to be repeated for each receiver
  // that shall receive from this sender
  for (int i = 0;   i < 6;  i++) {
    strcat (MAC_adrOfRecv_as_AoC, hex02str(ESP_NOW_MAC_adrOfRecv[i])   );
    if (i < 6) {
      strcat (MAC_adrOfRecv_as_AoC, ":" );
  MAC_adrOfRecv_as_AoC[17] = 0;
  strupr(MAC_adrOfRecv_as_AoC); // make letters UPPERCASE
  Serial.print("MAC-Adress of Receiver is ");
  Serial.println(MAC_adrOfRecv_as_AoC);
void ESP_NOW_SendData()
  char AoC[10];
  // Set values to send
  strcpy(my_READYtoSEND_ESP_NOW_Data.MyESP_NOW_MsgStr, "HI I'M SENDING EVERY ");
  itoa(SendDataInterval,AoC,10);
  strcat (my_READYtoSEND_ESP_NOW_Data.MyESP_NOW_MsgStr,AoC );
  strcat (my_READYtoSEND_ESP_NOW_Data.MyESP_NOW_MsgStr, " Milli-SECONDS COUNTiNG UP ");
  itoa(Summand,AoC,10);
  my_READYtoSEND_ESP_NOW_Data.MyESP_NOW_Int = my_READYtoSEND_ESP_NOW_Data.MyESP_NOW_Int + Summand;
  // Send message via ESP-NOW
  esp_now_send(ESP_NOW_MAC_adrOfRecv, (uint8_t *) &my_READYtoSEND_ESP_NOW_Data, sizeof(my_READYtoSEND_ESP_NOW_Data));
  Serial.println("esp_now_send(ESP_NOW_MAC_adrOfRecv, (uint8_t *) &my_READYtoSEND_ESP_NOW_Data, sizeof(my_READYtoSEND_ESP_NOW_Data)); done");
  Serial.print("I am the board named '");
  Serial.print(BoardName);
  Serial.print("' with the MAC-Adress ");
  Serial.println(Own_MacAdr_AoC);
  Serial.print("and I try to send my ESP-NOW-Data to the board with MAC-Adress #");
  Serial.print(MAC_adrOfRecv_as_AoC);
  // if sending has finished function OnDataSent is called
/* nonblocking timing based on millis()
this function returns true each time the TimePeriod has expired and immediately
starts a new TimePeriod. So this function
example-use:
unsigned long myTimer;
  if (TimePeriodIsOver( myTimer,2000) ) {
    //the code here gets executed only every 2000 Milliseconds
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - expireTime >= TimePeriod )
    expireTime = currentMillis; // set new expireTime
    return true;                // more time than TimePeriod) has elapsed since last time if-condition was true
  else return false;            // not expired
unsigned long SendDataTimer;
everytime the compiler compiles the file new
the macros named "__FILE__",  "__DATE__", "__TIME__"
where replaced with what their names say  Filename with path
Date and time of the Computer the IDE is running on
// so by simply starting the device the uploaded code yells filename date and time at the serial interface
void PrintWiFiMacAdress()
  char HexByteDigits[3];
  for (uint8_t i = 0; i < 18; i = i + 1)
    Own_MacAdr_AoC[i] = WiFi.macAddress()[i];
  Own_MacAdr_AoC[17] = 0; // zero to terminate the string
  Serial.print("ESP32-Board's OWN MAC-Address is:  ");
  Serial.println("copy the line below and replace the codeline");
  Serial.println("uint8_t ESP_NOW_MAC_adrOfRecv[] = { .... };");
  Serial.println("inside the code with the copied line from the serial monitor");
  Serial.print("uint8_t ESP_NOW_MAC_adrOfRecv[] = {");
  for (uint8_t i = 0; i < 16; i = i + 3)
    HexByteDigits[0] = Own_MacAdr_AoC[i];
    HexByteDigits[1] = Own_MacAdr_AoC[i+1];
    HexByteDigits[2] = 0; // zero for terminating the string
    Serial.print("0x");
    Serial.print(HexByteDigits);
    if (i < 14) Serial.print(", ");
  Serial.println(" };");
char* hex02str(uint8_t b)  {
 static char str[]="FF"; // RAM für einen 2-Zeichen string reservieren.
  snprintf(str,sizeof(str),"%02x",b);
  return str;
void PrintFileNameDateTime()
  Serial.print("Code running comes from file ");
  Serial.println(__FILE__);
  Serial.print(" compiled ");
  Serial.print(__DATE__);
  Serial.print("  ");
  Serial.println(__TIME__);
  // Init Serial Monitor
  Serial.println();  // a carriage return to make sure serial-output begins in colum 1 of a new line
  PrintFileNameDateTime();
  PrintWiFiMacAdress();
  ESP_Now_setup();
  SendDataInterval = 5000;
  Summand = 6;
  // check if timer-intervall is over
  if (TimePeriodIsOver(SendDataTimer,SendDataInterval) )
     Serial.println("SendData");
     ESP_NOW_SendData();
     Serial.println("SendData done");
// explanation how ESP-NOW works:
// sending serial data is as easy as
// Serial.begin(baudrate);
// Serial.print("Hello World");
// This can be coded so easy because a lot of things are fixed
// IO-Pins used by Serial fixed
// Connection to other device: made of wire must not be programmed
// standard serial-connection does not care if receiver is connected
// send data and that's all
// with ESP-NOW more things are NOT fixed = are adjustable and MUST be adjusted
// the receiver is NOT defined by wire but through his MAC-Adress
// Data-transport can do only transporting one or multiple bytes
// That's not a real problem the user can define his own data-pattern (data-structure)
// ESP-NOW offers feedback if a datatransmission was successful or failed
// each ESP-modul can receive data from different senders
// so an information from WHICH sender the data was sended is useful
// this is identified by the senders MAC-Adress
// Analogy sending / receiving postal letters:
// if you want to SEND out a letter to somebody you have to write
// the receivers adress on the envelope.
// similar thing with ESP-NOW: the data is NOT guided by a wire its sended "Up in the air"
// with ESP-NOW this receiver-adress is the MAC-Adress of the receiver
// if the postman brings you a letter you don't have to be at home. He will put the letter
// into your letter-box and you can pick it out later.
// similar thing with ESP-NOW: there is some kind of "letter-box" the received data will be stored into
// the data-receiving into the "letter-box" runs in the backround similar to an interrupt
// The received data will be catched up and must be copied into some kind of "letterbox"
// any transporting service has some kind of procedure if you want to send a package or a letter
// fill out some kind of form (on paper or onnline) print out and glue a sticker
// with the transporting informations on the package/envelope put the package / envelope into the
// "send out" box or bring it to a pickup store
// so there are some things to do:
// - build a special designed "package" with multiple special designed compartments
//   where all parts of the data has its own compartment
//   defining a new variable type "structure"
// - build a "letter-box" designed expecially for the user-defined package
//   and "mount it in front of your house" so it can be easily found by the postman
// - write a list with receiver-adresses and handover this list to ESP-NOW (the "letter-department" of your "company"
// - setup if data shall be encrypted or not
// - setup transmission channel that shall be used for sending the data wireless
// - design your "sending-form"
// these are the reasons why ESP-NOW needs a bit more than just
// Serial.print("My Data");
// Your mobile phone has a lot of functions. It took you some time to learn them all
// Same thing with ESP-NOW it will take some time to learn it
// if you want it fully automated without learning anything
// use Alexa, Siri or google assistant instead
vgs
Threads vereint
[OT]
#3 liest sich wie eine Antwort von chatGPT
[/OT]
Du könntest ja versuchen, dein Gehirn anzustrengen und selbst programmieren lernen.
Ich habe den Thread nochmal geschrieben, da ich ihn nach Einfügen einer Änderung und einer falschen Tastenauslösung nicht wiedergefunden habe. Daher ist es wohl danach zu einem Doppelposting gekommen. War keine Absicht.
Vielen Dank, cloudDev,
die Zeile
hat gefehlt. Jetzt geht alles.
Noch eine Frage: Was ist gemeint mit "Unter 2 finden Sie auch ein Beispiel dafür, wie Sie mit ESP-NOW Daten von mehreren ESP32-Boards empfangen können."?
Entschuldigung, aber ich hab mir von der KI Hilfe geholt und dann den Code nochmal überprüft. "2" wäre eigentlich ein Link gewesen, den ich aber nur entfernt hab und dann vergessen hab, das mit dem Satz auch zu tun.
Falls Sie aber wissen wollen, wie man ESP-Now Daten von mehreren ESP32-Boards empfangen kann, können Sie mich gerne wieder anschreiben.
Ansonsten würde ich mich freuen, wenn Sie meine Antwort als Lösung markieren würden! Dann sehen die anderen Mitglieder auch, dass eine Lösung gefunden wurde.
Es ist aber nur eine Empfehlung, die Sie nicht unbedingt machen müssen.
Ein schönes Wochenende,
cloudDev
Meine Lieblingsseite zu diesem Thema Getting Started with ESP-NOW (ESP32 with Arduino IDE) zeigt die verschiedenen Möglichkeiten der Verbindungen mit ESP-NOW.
