Hello, I am using a ESP32 to tell another ESP32 via ESPNOW to turn on it's built-in LED. I need to put the first ESP32 into light sleep mode to conserve battery life. I put the wakeup cause for the first ESP32 to wakeup when one of its built-in touch-pins are pressed. I then put it into light sleep mode. I also turned off the wifi before I put it into light sleep mode and on after it woke up from light sleep mode. When I uploaded the code, the LED of the second ESP32 would not turn on. Here is my code...
Code for first ESP32:
#include <Arduino.h>
#include <WiFi.h>
#include <esp_now.h>
#include <esp_wifi.h>
uint8_t addressB2[] = {0xEC, 0x94, 0xCB, 0x4C, 0x76, 0x18};
touch_pad_t touchPin;
void callback() {}
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK)
Serial.println("Error initializing ESP-NOW");
return;
esp_now_peer_info_t peerInfo;
memcpy(peerInfo.peer_addr, addressB2, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
if(esp_now_add_peer(&peerInfo) != ESP_OK)
Serial.println("Failed to add peer");
return;
esp_wifi_stop();
touchAttachInterrupt(15, callback, 70);
esp_sleep_enable_touchpad_wakeup();
esp_light_sleep_start();
touchPin = esp_sleep_get_touchpad_wakeup_status();
int touch = 0;
if(touchPin == 3)
touch = 1;
touch = 0;
esp_wifi_start();
esp_now_send(addressB2, (uint8_t*) &touch, sizeof(touch));
Code for second ESP32:
#include <WiFi.h>
uint8_t addressB1[] = {0xEC, 0x94, 0xCB, 0x4C, 0xB2, 0xF0};
void OnDataRecv(const uint8_t * mac, const uint8_t *data, int len)
int * messagePointer = (int*)data;
if(*messagePointer == 1) { Serial.println("Touched"); digitalWrite(2, HIGH); delay(1000); }
else { Serial.println("Not Touched"); digitalWrite(2, LOW); }
pinMode(2, OUTPUT);
return;
esp_now_register_recv_cb(OnDataRecv);
Any advice for how to use ESPNOW and put it into light sleep mode too? Thanks in advance.
