All the verbose debug at startup ...
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4916
load:0x40078000,len:16436
load:0x40080400,len:4
ho 8 tail 4 room 4
load:0x40080404,len:3524
entry 0x400805b8
[ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400d983c
[ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x400d980c
[ 26][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x400d97dc
[ 39][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400d97ac
[ 53][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400d983c
[ 66][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x400d980c
[ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x400d97dc
[ 93][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400d97ac
[ 107][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400d983c
[ 120][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x400d980c
[ 134][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x400d97dc
[ 147][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400d97ac
[ 187][D][esp32-hal-cpu.c:263] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 224][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 3 successfully set to type UART_RX (2) with bus 0x3ffbdb74
[ 235][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 1 successfully set to type UART_TX (3) with bus 0x3ffbdb74
=========== Before Setup Start ===========
Chip Info:
Model : ESP32
Package : D0WD-Q5
Revision : 3.01
Cores : 2
CPU Frequency : 240 MHz
XTAL Frequency : 40 MHz
Features Bitfield : 0x00000032
Embedded Flash : No
Embedded PSRAM : No
2.4GHz WiFi : Yes
Classic BT : Yes
BT Low Energy : Yes
IEEE 802.15.4 : No
INTERNAL Memory Info:
Total Size : 336808 B ( 328.9 KB)
Free Bytes : 296580 B ( 289.6 KB)
Allocated Bytes : 32964 B ( 32.2 KB)
Minimum Free Bytes: 290708 B ( 283.9 KB)
Largest Free Block: 110580 B ( 108.0 KB)
Flash Info:
Chip Size : 4194304 B (4 MB)
Block Size : 65536 B ( 64.0 KB)
Sector Size : 4096 B ( 4.0 KB)
Page Size : 256 B ( 0.2 KB)
Bus Speed : 80 MHz
Bus Mode : QIO
Partitions Info:
nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
app0 : addr: 0x00010000, size: 1280.0 KB, type: APP, subtype: OTA_0
app1 : addr: 0x00150000, size: 1280.0 KB, type: APP, subtype: OTA_1
spiffs : addr: 0x00290000, size: 1408.0 KB, type: DATA, subtype: SPIFFS
coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
Compile Date/Time : Mar 17 2025 15:30:11
Compile Host OS : linux
ESP-IDF Version : v5.3.2-282-gcfea4f7c98-dirty
Arduino Version : 3.1.1
Board Info:
Arduino Board : ESP32_WROOM_DA
Arduino Variant : esp32da
Arduino FQBN : esp32:esp32:esp32da:PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=verbose,EraseFlash=none
============ Before Setup End ============
[ 741][V][esp32-hal-uart.c:421] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(3) txPin(1)
[ 750][V][esp32-hal-uart.c:510] uartBegin(): UART0 not installed. Starting installation
[ 761][V][esp32-hal-uart.c:575] uartBegin(): UART0 initialization done.
[ 795][V][NetworkEvents.cpp:113] _checkForEvent(): Network Event: 101 - WIFI_READY
[ 955][I][WiFiGeneric.cpp:799] setDualAntennaConfig(): TX Antenna will be automatically selected
[ 956][V][STA.cpp:186] _onStaEvent(): STA Started
[ 968][V][NetworkEvents.cpp:113] _checkForEvent(): Network Event: 110 - STA_START
[ 976][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 110 - STA_START
Connecting to WiFi ...[ 1034][V][STA.cpp:206] _onStaEvent(): STA Connected: SSID: SFR_A760, BSSID: cc:2d:1b:73:a7:66, Channel: 1, Auth: WPA_WPA2_PSK
[ 1046][V][NetworkEvents.cpp:113] _checkForEvent(): Network Event: 112 - STA_CONNECTED
[ 1054][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 112 - STA_CONNECTED
[ 1554][V][NetworkInterface.cpp:78] _onIpEvent(): sta Got New IP: 192.168.1.87 MASK: 255.255.255.0 GW: 192.168.1.1
[ 1565][V][NetworkEvents.cpp:113] _checkForEvent(): Network Event: 115 - STA_GOT_IP
[ 1572][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 115 - STA_GOT_IP
[ 1579][V][STA.cpp:171] _onStaArduinoEvent(): STA IP: 192.168.1.87, MASK: 255.255.255.0, GW: 192.168.1.1
192.168.1.87
RRSI: -45
=========== After Setup Start ============
Free Bytes : 245364 B ( 239.6 KB)
Allocated Bytes : 81420 B ( 79.5 KB)
Minimum Free Bytes: 242896 B ( 237.2 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
1 : UART_TX[0]
3 : UART_RX[0]
============ After Setup End =============
ESP32TEMP Ok
ESP32TEMP Ok
ESP32TEMP Ok
