espresso machine & arduino
I'd like to "automate" an espresso machine using an arduino board. The task is not easy. I'm wandering which sensor should I use to measure the pressure. I heard about the freescale's products....I don't know which one to select. Thank you very much, I really appreciate your help
I've not worked with pressure sensors, but there are quite a few resources here on espresso machines. The site search is pretty weak (useless) but a the following Google search of the site has some pretty good results.
http://www.google.com/search?hl=en&as_q=espresso&as_epq=&as_oq=&as_eq=&num=10&lr=&as_filetype=&ft=i&as_sitesearch=arduino.cc&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=images
