Esptool error: link Blynk to an ESP32 Anyone to help me pls?
Hi, I just start using arduino software and I'm currently trying to connect my blynk app to an ESP32 dev module. I've adapted my code to my wifi datas, installed the good libraries... and everything seems to be OK but when I try to upload the code into the card, the following error message appears ! Could anyone help me ? Thanks a lot
"Traceback (most recent call last):
File "esptool.py", line 34, in
File "esptool_init.py", line 1004, in main
File "esptool
init
.py", line 646, in main
File "esptool_init_.py", line 895, in get_default_connected_device
File "esptool\loader.py", line 631, in connect
File "esptool\loader.py", line 572, in _connect_attempt
File "esptool\loader.py", line 435, in sync
File "esptool\loader.py", line 365, in command
File "esptool\loader.py", line 317, in write
File "serial\serialwin32.py", line 325, in write
serial.serialutil.SerialTimeoutException: Write timeout
[3108] Failed to execute
script 'esptool' due to unhandled exception!
Failed uploading: uploading error: exit status 1"
google is your friend
I took the last line of the error-message and googled
These two links seem to be promising
More information is required
Post your complete sketch as a Code-Section
Post the complete compiler-output as a Code-Section
best regards Stefan
@StefanL38 the problem has nothing to do with Blynk
So what do you recommend?
troubleshooting
done in many posts on this and other forums
@Juraj Hi, thanks for your help. Do you have any link to the process to follow in order to solve my problem?
@StefanL38 thanks for you help ! I will try to solve the problem with your links
show us the complete output of esptool
where can I find it ?
It can be found in many places depending upon what it is.
Images of error messages suck.
Include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Did the OP actually setup the IDE to use the ESP32?
you posted only the error, but not the progress of the esptool before the error
@Idahowalker @Juraj here is the whole error message and the whole response to the upload
Le croquis utilise 697505 octets (53%) de l'espace de stockage de programmes. Le maximum est de 1310720 octets.
Les variables globales utilisent 37792 octets (11%) de mémoire dynamique, ce qui laisse 289888 octets pour les variables locales. Le maximum est de 327680 octets.
esptool.py v4.2.1
Serial port COM3
Connecting...Traceback (most recent call last):
File "esptool_init_.py", line 1004, in main
File "esptool_init
[7324] Failed to execute script 'esptool' due to unhandled exception!
Do the same as described here
additionally
is your ESP-board really Serial port COM3??
The comport in the Ardiuno-IDE must exactly match with the com-port-number that gets added in the device-manager (windows ) If you use a mac. well another thing specialised for mac how to look up the com-port on a mac. mac-users are really "special"
Ok I'll do the same as described there and I tell you what happen :wink:
I tested both on the Mac and on Windows. COM3 is automatically detected as my "ESP32 DEV MODULE port" so I think it's the right one...
Thanks a lot for your help
Which Arduino-IDE are you using?
I don't think that the Arduino-IDE is able to automatically detect the right com-port
