Does anyone know what's the issue here?
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 286960 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 29025 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1616 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1692 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 26392 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 319293 bytes (30%) of program storage space. Maximum is 1044464 bytes.
Global variables use 29700 bytes (36%) of dynamic memory, leaving 52220 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM6
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: e8:db:84:98:ac:d9
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 323440 bytes to 234839...
Writing at 0x00000000... (6 %)
Writing at 0x00004000... (13 %)
Writing at 0x00008000... (20 %)
Traceback (most recent call last):
File "C:\Users\User\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3604, in main
operation_func(esp, args)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2987, in write_flash
esp.flash_defl_block(block, seq, timeout=DEFAULT_TIMEOUT * ratio * 2)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 113, in inner
return func(*args, **kwargs)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 762, in flash_defl_block
self.ESP_FLASH_DEFL_DATA, struct.pack('<IIII', len(data), seq, 0, 0) + data, self.checksum(data), timeout=timeout)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 413, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 386, in command
p = self.read()
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 331, in read
return next(self._slip_reader)
File "C:/Users/User/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
